Question about Stud Welder Dent Pulling System 31041
Toyota vitz 2005 not pulling,it does not show any problem on the machine,i have tried changing the fuel filter and the pump no change
  • 28 Answers
Could be trans problem
Posted on Oct 10, 2013
Toyota Vitz 2007, 1.0 L, check engine light comes on at 100 km/h and goes off after turning off engine but comes back again at high acceleration like 100 km/h. change oxygen sensor as well.
That code is actually due to the fuel pressure being too low and causing a lean condition that the oxygen sensor picks up. It is common in that vehicle. Check the fuel pump pressure, filters etc.
Feb 08, 2017 | Toyota Cars & Trucks
Why does my fuel pump relay fuse keep blowing on my Volvo 2005 S40
use a meter and test the connections ,lines ,pump for damage or short
Nov 18, 2016 | 2005 Volvo S40
Hello I have 2005 Toyota Hiace, diesel, auto with the 2KD-FTV engine. had problem with the vehicle this morning, had not change the fuel filter in about 5 months, it was dirty. I replace the filter, t
The pump is probably ok from the tank but the injector pump may have been damaged if the filter failed and allowed particulate to enter the pump also the injectors themselves maybe clogged best way to check the pump is with an oscilloscope (lab scope) check the amperage waveform with the lab scope and calculate the rpm , also check the fuel pressure from the pump with an appropriate fuel gauge
Dec 02, 2014 | Toyota Cars & Trucks
Toyota vitz with 1sz engine when I put in to drive or reverse has no power
Scan for any stored error codes and check the code discription. If no code is present suspect lack of fuel. Try cleaning fuel filters. If cleanig filters dont solve change the fuel pump
May 08, 2014 | Cars & Trucks
How to change gas filter 2005 Kia Rio
Its recommended to disable the fuel pump to release pressure in the line before removing the filter. Either pull the fuse or pump relay.
Jan 24, 2014 | 2005 Kia Rio
I got a toyota sequoia 2005 suv, 8v, 4.7L. I need change the gas filter yes or no?
The fuel filter is located inside the gas tank, the filter should last the life of the pump. i work on many models with this design and never had a problem, i tell customers it lasts the life of the pump. your fuel filter doesnt need replacing, it will last the life of the pump, it gets replaced with the fuelpump when it goes,good day.
Apr 10, 2011 | Toyota Sequoia Cars & Trucks
Shop manual for 2005 Santa Fe 3.5L shows a fuel pump filter in the tank & a standard cylindrical fuel filter outside the tank. Manual states change the "fuel filter" at 45000 mi. Can't find outside...
Change to Exterior filter not the tank filter. The in tank filter is actually a sock located on the Fuel Pump in the tank. This is rarely a problem. The exterior filter is going to be in-line most likely on the passenger side of the vehicle toward the rear. Easiest way to locate it is to trace the fuel lines back tot eh front of the vehicle from the fuel tank.
Jun 25, 2010 | 2005 Hyundai Santa Fe
While driving my ford focus 1.6 TDCi dies out - it's now happening frequently. It has been put on the diagnostic machine and only shows up problems with fuel pressure so not sure what exactly to fix.
Cars now days run with very specific fuel pressures. If your car is showing a fuel code it is most likely the fuel pump. You need to find the pressure for you car and have the pressure actually check. Also if you change the pump you need to change the fuel filter.
Jun 13, 2010 | 2005 Ford Focus
Stud Welder Dent Pulling System 31041 Logo
Top Eastwood Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an Eastwood Vehicle Part and Accessory Expert? Answer questions, earn points and help others
