Question about Sharp MX-2700N Color Copier
Data light is flashing but will not print. all other functions working
When press print, the status light flashing orange. It print for a while then the paper light flash yellow, then it stop. The printer print up to half a page the it stop. Check printer and turn printer...
the flashing amber status light is normal indicating data going from computer to printer.the flashing paper light indicates a paper jam or out of paper. A sensor maybe not working properly or sticking. If your model number ends in a D check
Jul 16, 2014 | Brother HL 5140 Laser Printer
Printer ready light never comes on but printer works
I've had this fault myself, If memory serves me right the control panel ( small though it is) we found to be the problem, once replaced the unit the displayed correctly, weirdly all functions of the printer were still available even though we were unable to see the display.
we were able to get config pages etc, and like you say the indicator lights were working- sort of - when they wanted to.
replace the diplay PWB ( its small and reasonably cheap)
Mar 14, 2014 | HP LaserJet 1500L Printer
Our Data light keeps flashing and the printer won't print. How do we get the data light to stop flashing so we can use our copier again with our computers?
Sounds like a bad print job stuck in a print spooler.
Turn off copier. Go around to all computers that print to it and open the print queue. delete all print jobs. reboot each PC. Power up copier and see if it clears
Jan 15, 2013 | Sharp Mx-M450nb Digital Copier
We have a Zebra 105SL thermal printer. When I print to it with any application, the data light comes on, but it doesn't print. It has ribbon, media, calibrated, no error lights
The data light indicates that the printer is receiving data. Hold the cancel key for 10 seconds while powering on. This will print printer configuration. Use to troubleshoot. If the data or format is wrong it will not print as you send data. Make sure you are using the 105SL printer driver. To test the printer functionality you can go to www.teklynx.com and download a demo copy of labelveiw, select the 105SL printer and try to print a simple label. If you can print with labelveiw then it is not a printer problem. Double check your driver and label format.
Nov 12, 2010 | Zebra 105SL Thermal Label Printer
Light flashing green and yellow will not print
Hi this is only a try it may work
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Jan 14, 2010 | Canon i850 InkJet Photo Printer
Operator Error Canon i850 printer
2. Release RESUME
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i850)
Dec 09, 2008 | Canon BubbleJet i560 InkJet Printer
Epson stylus 600 non stop flashing light nonstop printing
Flashing light may indicate that it's receiving data to print.
What is it printing?
Cancel all print jobs.
Nov 19, 2008 | Epson Stylus Color 600 InkJet Printer
Epson AccuLaser CX11NF
I had this problem. Try unplugging any usb connection to the computer, turn off, then turn on and then try a stand alone copy. It was my USB connection to the computer which had locked up the copier.
After this it was fine.
Jan 23, 2008 | Epson ACULASER CX11NF All-In-One Printer
Printer will not print
This worked perfectly for my printer:
Waste Ink Counter Reset
Power off printer and covers closed
Hold down the Resume button then press and hold POWER, the Green Indicator will light. While holding down POWER , release RESUME
Double click (2 clicks) RESUME then release BOTH POWER and RESUME and wait still the printer stops blinking.
When the indicator lights steady, press RESUME three(3) times. The indicator should be ORANGE.
Press Power to set data
I got the solution from the Internet at the following link:
http://www.fixyourownprinter.com/forums/inkjet/15620
Hope this helps.
Mar 05, 2007 | Canon BJC 3000 InkJet Printer
Sharp MX-2700N Color Copier Logo
18 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
