Question about HP LaserJet 4345mfp Printer
Reset document feeder kit - HP LaserJet 4345mfp Printer
2 Suggested Answers
  • 9 Answers
SOURCE: i need a manual for document feeder kit hp
Here is the hp link
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00236981/c00236981.pdf
Posted on Nov 11, 2009
Hp laserjet 1536 dnf MFP. How can I repair document feeder?
how to fix and repair the adf doc feeder Q5997A hp laserjet ...
? 1:36
https://www.youtube.com/watch?v=lpTj4jiLaY8
Dec 12, 2011 - Uploaded by BrokenPrinter1
Parts Available @ BrokenPrinter.com how to fix and replace the rollers on a hp laserjet 4345 mfp and color ...
Fixing Paper Pick-Up Issues - HP LaserJet Pro M1212nf ...
? 5:40
https://www.youtube.com/watch?v=ZXtAhSDYqyU
Jan 23, 2013 - Uploaded by HP Printer Support
Learn what to do if your HP printer does not pick up or feed paper from the ADF when you do have paper loaded, and a Doc feedermispick error message display... ... FIX YOUR PRINTER: ERROR: Printer Does not Grab Paper fromTray ... Kit m3027 mfp- Kit Hp m3027 mfp - Kit Mantenimiento m3027 mfp ...
'Document feeder mispick' Message Displays on the Control ...
Dec 13, 2015 | HP Office Equipment & Supplies
How to reset all originals in DP Kyocera km 2050
It just means take all the pages out of the document feeder on top and put the whole complete document in again
Jun 14, 2015 | Kyocera Mita KM-2050 Printer
My photocopier is just saying reset all originals in DP how do i reset
Open and close the document feeder (where you put your pages that you want copied), take out any papers on there and place them back in the document feeder. press the start button. Good luck !
Oct 18, 2012 | Copystar CS-2550 All-In-One Printer
Cannot clear error message "Document
Hi nigel_lester,
This error message "Document in ADF" that you are getting means that you need to remove foreign object from the Automatic Document Feeder (ADF). Kindly follow the procedure below in clearing document jams:
Document jams in the ADF (Document Tray)
1. First, press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF. 3. Then, open the Feeder Cover.
4. From under the roller to the Feeder Cover side, remove the jammed page.
5. If a document is not jammed, check the document feed area if there's foreign material. If there's any, carefully remove it.
6. Close the Feeder Cover.
NOTE:
  • If documents remain in the ADF after pressing during scanning, [Document in ADF] will appear on the LCD. Press so that the remaining document is automatically fed out.
  • When rescanning the document after clearing the error, rescan it from the first page.
Document jams in the ADF (inner side)
1. Press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF, then open the Feeder Cover.
3. Raise the paper release lever (A) then remove the jammed page from under the roller to the Feeder Cover side.
4. Open the Document Cover and pull out the document from the inner side.
5. Close the Document Cover.
Note: When rescanning the document after clearing the error, rescan it from the first page.
Hope it helps.
Thank you for using Fixya.
Apr 02, 2011 | Canon Office Equipment & Supplies
What should i do, my printer is requesting me to replace document feeder kit and i dont know what to do. help me out please. MIKE
Never mind, I noticed the model in the subject. Sorry, it is Monday morning. Ideally you need to order a new ADF Maintenance Kit and replace the parts in it to maintain optimal performance of your printer. It comes with a pickup roller, separation pad, mylar sheet and instructions. After you replace the kit, or if you just want to reset the message and ignore it for another 90k copies, do this:
1) Turn the machine off and back on. 2) When XXXMB appears on the control panel display, press and hold the 6 button until all three LEDs flash once and then stay on. (This could take about 20 secs to happen) 3) Release the 6 button and then press the 3 button twice. 4) Press the 6 button to select NEW DOCUMENT FEEDER KIT.
After doing this, the MFP will complete its initialization sequence and the counter will be automatically reset.
The part number for the maintenance kit is: Q5997A, Amazon has it for about $91
Hopefully that helps.
Feb 21, 2011 | HP LaserJet 4345mfp Printer
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
Error code c0410 what does it mean
This code occurs when the document feeder loses communication with copier. You can reset by powering down and unplugging. If it re-occurs you will have to replace the document feeder board with a new one. There is an updated kit related to this problem. See your local copystar dealer
Jun 28, 2010 | Kyocera Copier
HP Office jet 7210 All in One. When I feed paper
Lean the rollers in the automatic document feeder (ADF)
  1. Remove the document feeder tray from the product by gently pulling it.
  2. Lift the cover of the automatic document feeder by pulling it outward.
  3. Gently clean the rollers with a very damp cloth ansd a dab of dish detergent.
  4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
To clear the "scanner error" message do a
Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
If a partial reset did not work do the following: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, unit may need service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 11, 2009 | HP 7210 OfficeJet All-In-One Printer
Document feeder does not work
cleaned some sensors under the feeder, if possible, clean it with blower to solve the problem.
Aug 04, 2008 | Canon NP 6050 Copier
Paper Feeder Jams
Use this link and when you call ask for Britt. I do NOT work there but I have used them for a long time and they are greart.
Here is the URL ..
https://www.partsdrop.com/store/
Jul 09, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
HP LaserJet 4345mfp Printer Logo
29 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
