Question about 1971 Mercedes Benz 280SL Thermostat
1996 sl280. After battery replaced, roof mechanism didn't work. Light on roll bar button and roof control button stayed on after they should have gone out. After trying to reset ecu by holding roll bar button for 10sec, no instruments worked. How do I reset ecu?
  • 364 Answers
Disconnect battery for at least 24 hours, this should reset the system to default. hope it works for you, good luck.
Posted on Oct 20, 2013
My toyota sienna 2001 was opening by remot control now it is not working roof light not working warnnig
hello
Prius2 is not powering up after one person swapped ower polarityof battery while changing it. We changed Big fuse at the front of the car and couple of small fuses. Now when pressing power button we have engine light and power button orange light fore just one sec. After it just stays dead. While pressing power button you can hear couple relays clicking for a sec and dc to dc giving hi frequency noise for the same amount of time. Help us please. This prius was manufactured in 2003. Many Thanks
Feb 27, 2014 | 2001 Toyota Sienna
I HAVE A 1995 M B 500 SL THE SWITCH INDICATOR FOR THE TOP & ROLL BAR STAY IN A BLINKING POSITION. THE TOP, POWER WINDOWS AND ROLL BAR WILL NOT FUNCTION AT ALL... THANK YOU
The control module has set a fault and it will have to be reset. They are sensitive to voltage & must have 12 volts to operate properly.
The windows and top will need to be resync. I cannot find any information regarding the diagnostic procedure for the roof .. it states there is a procedure to diagnose the fault with the number of flashes the switch makes .. a dealer may be your best option on this fault .. I hope this helps some.
Aug 26, 2011 | Mercedes-Benz CL500 Cars & Trucks
My '96 Suburban 1500 4x4 won't shift into 4 wheel drive. When I push the button for 4 Hi the light just flashes and stays in 2 wheel drive.
the electric shift motor on transfer case is bad, replace and it will work great. if your at all mechanically inclined you can do this very easy. before unbolting motor disconnect battery to reset computer install part, should only take you 15 min maybe then hook up battery and you will have 4 wheel drive again. good luck
Jan 16, 2011 | 1996 GMC Suburban
I have a mercedes sl350 of 2004 I had the battery at the trunk almost drained (I don't drive it often) when I started the engine I had a message at the dashboard saying electric consumers are...
The top and roll bar are not working because of the consumer warning displayed in the instrument cluster. It will start working again once the battery is charged up again. Either let the car run for awhile til the light goes off or hook up a battery charger to it. Everything should be functional again once the battery is charged.
Dec 19, 2010 | Mercedes-Benz SL-Class Cars & Trucks
I left top half way up while cleaning rear galass. now top will not go down. got trunk working & roll bars go up and down. when i unlatch the top i hear nothing. normally you can tell the top is...
first try with disconnect battery ground cable, disconnect cable an leave 2 minute then fix it back and have a look, if not work now it's position uneven, you must close the roof slowly by hand up to locking position after that first operate the switch for closing and let it lock properly then till lock the boot lid to the right position with two flaps then switch off ignition let it stay 5 minute without doing any thing and, after that open the roof, if not work in this way you must fix Mercedes diagnose tool in to the car for manual activation through diagnose tool, and also would like to ask you to check the boot separation flap again is it in the right position if it not close properly it won't work,
Nov 15, 2010 | Mercedes-Benz CLK-Class Cars & Trucks
2002 cadillac escalade service ride control light
This happened to my 2002 EXT and two of my buddies Escalades. All 3 were AWD. All we did was replace the Front Hubs. I replaced both Front hubs and the speed sensors. Actually I replaced the speed sensors first because thats what code was coming up, and it didn't fix the problem. So after talking with a freind who is a big time GM Mechanic, he told me it's probably my barrings and since they are sealed I needed to replace the hubs. This is an easy job. I did them myself, and I am by no means a "mechanic".
Oct 18, 2009 | 2005 Cadillac Escalade Ext
I own a 1995 mercedes SL500 and recently started having trouble with the left front door window. While stopped in a construction zone, I rolled both windows down. After leaving the construction area, I...
The window position is monitered by the softop control module. It sounds like the glass is very dirty and drawing too much amperage during window operation. The soft top is electro hydraulic. The roll bar is operated normally with hydraulics but it is mechanically released in an emergency situation. 1st make sure your windows are clean and the express(one touch operation) is working-the soft top will not function properly if the windows are not synchronized. Next be sure your roll bar works-hold swith in up position to lock roll bar rams in if they have been deployed. next put your top all the way up. untill windows roll up and try it with the engine running and trans in nuetral- if it still does not work mechanically secre rear of top with tool provided in your tool kit the owner's manual will tell you how to do this. good luck
Jun 19, 2009 | 1995 Mercedes-Benz SL-Class
96 Buick roadmaster= interior lights stay on while driving
Check to see if the over head light has shorted to ground. EG: touching roof, from weight being put on the roof. EG: Cargo hauler.
Jun 01, 2009 | 1996 Buick Roadmaster
1971 Mercedes Benz 280SL Thermostat Logo
133 people viewed this question
Top Behr Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Behr Vehicle Part and Accessory Expert? Answer questions, earn points and help others
