Question about Pacific Bearing Pacific Dualie Tandem Bike
My front cranks wont stay tight. Whats the deal?
My new belt wont stay tight and i have all new pulleys, whats my problem
Recheck the routing of the belt because if you go the wrong way around a pulley the belt will be too long. Remember that with multi- groove pulleys the back of the belt goes around the idler pulley and the grooves go in the groves of the pulleys to be driven
Feb 19, 2014 | GMC Cars & Trucks
1992 caprice will start but wont stay running, if i disconnect the temperature control sensor it will start and idle perfectly for about 15v-20 seconds, then will stop. whats the deal???
Temp control sensor when disconnected goes full rich. But then computer senses open circuit and shuts down You need an ohm meter to test it. You need to find the values of that sensor
Oct 23, 2013 | 1992 Chevrolet Caprice
My 2007 dodge caliber wont start
You are dealing with 2 possible problem. The ignition switch,or the alarm, If you have a alarm problem the vehicle will crank then in 2 seconds shut down,this is because the key is recognized,now if this is the problem roll down a window and disconnect the negative battery terminal,put the key in the ignition but in the off position.After 5 minutes reconnect the battery and turn the ignition on but dont crank the engine leave for 1 minute. Then see if that resolved the issue.Now if its an ignition switch problem crank the engine and slowly let it go.try to keep the key in the position where it stays running. By the way there is a campaign of a recall dealing with a TIPM software update Re-configure ,anti-theft system. Customer satisfaction notice G42. You will have to see the dealer for this campaign.
Nov 02, 2011 | 2007 Dodge Caliber SXT Sport Hatchback
My husband is trying to fix my 04 dodge ram 1500 4.7l, the computer says to replace the crank sensor and or cam sensor. the crank sensor was replaced a month ago. it wont stay running. but he doesnt know...
On the 4.7L, the cam position sensor is located on the right cylinder head (thats the passenger side) toward the front below the valve cover gasket. Not on the front of the head but on the side where the exhaust manifold is attched at the forward end of the head. The crankshaft position sensor is located on the same side (right) but is at the opposite end of the engine between the bell housing and the block. The crankshaft position sensor can be replaced without removing the engine or transmission, it just looks tight. Also, on the crankshaft position sensor, it slides out of a rubber gromet. Here's a few pics to help. hotrodshop.gifhotrodshop_0.gif
Apr 17, 2011 | 2004 Dodge Ram 1500
My car wont start but all the lights and stuff come on it just wont crank or start whats the problem with my car??..2004 crysler crossfire
Check starter motor wires are connected and clean and tight.check the very thin wire at the starter is clean and tight.ALL WIRES ARE ON THE SOLINOID.
Jul 10, 2009 | 2004 Chrysler Crossfire
Wont charge
I had a similar problem with my nokia. The charger was faulty. Nokia replaced the charger (and upgraded the software) under warranty and it works fine now.
May 23, 2009 | AT&T Palm Centro Cell Phone - White
My lg scoop
my scoop wont let me set ringones that my buddies send me.....they just shoe up as song.....any suggestions?? But ringtones I buy can be set??
Aug 20, 2008 | LG VX8300 Cellular Phone
Pacific Bearing Pacific Dualie Tandem Bike Logo
29 people viewed this question
Top Pacific Bearing Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Pacific Bearing Cycling Expert? Answer questions, earn points and help others
