Question about MTX Chevrolet Camaro/Pontiac Firebird 1993-2002 Thunderform Loaded with 10 Inch Subwoofer and Amplified,... Car Speaker
Fuse blown where I plug my cellphone to charge, where is the fuse located
  • 998 Answers
Probably and inline fuse if the phone holder was fitted after sales. If the car already had a holder (Factory fitted) the fuse will be in the fuse box. Normally in front of the Drivers position under the dash or under the bonnet. If its an inline fuse, you may have to remove any under dash covers and trace the "live" wire from the phone cradle back to its power supply. The fuse is usually in a cylindrical type holder that clips apart or 1 end unscrews.
Posted on Oct 18, 2013
Nuvi will not charge when plugged into car charger but will charge when plugged into house charger
  1. Check that the cigarette lighter socket is working. If not it may be a fuse blown in the fuse-board.
  2. In the charger plug, that goes into the cigarette lighter there is a fuse which may be blown. At the tip of the plug you'll see a ring. On most chargers it's silver but some are black. Unscrew the ring and the plug will come apart. Take care not to lose the small metal tip when you open it. Replace the fuse. If there's power going to the charger and this fuse is replaced your problem should be solved.
Dec 17, 2010 | Garmin Nuvi 770 Car GPS Receiver
I cigarette lighter has quit working. I do not smoke so that i not the problem. However I cannot charge my cellphone while driving which is a problem. I spend a great deal of time driving and I need my...
make sure nothing is inside of it, like coins... check the fuse, the fuse panel should indicate the correct one. a dead give away for a blown fuse would be the radio not working.
Nov 05, 2010 | 1995 Ford Crown Victoria
Garmin 255W 50 days old rearly used and very pleased with it. After I downloaded the europe update mup on the SD card just bought today I was in the process of checking the unit when the screen suddenly...
The fuse in located in the car adapter plug..... unscrew the silver tip of plug. be careful its spring loaded.. hope this works
You can also use a USB connector cord to plug in gps to computer to see if it charges, this will take about a couple hours to fully charge
Oct 26, 2010 | Garmin 255WT GPS Receiver
Garmin will not take a charge
Are you using the car charger adapter plug? If so the plug may have a blown fuse... I would unscrwew the silver end of plug and check fuse ...its spring loaded so be careful...
If the fuse is good try plugging the unit into your computer with the usb connector to see if it charges .... its a slow charge so may take a few hours to fully charge
It fuse is good and unit takes a usb charge the car plug needs replacing
Oct 25, 2010 | Garmin StreetPilot C330 GPS Receiver
Where is the fuse for cigarette lighter for BMW 2000 5 D series
The lighters frequently burn out after a couple of years but you may still have power to the socket. Plug the charger in and check that the charge indicator light comes on. If it does your fine. If not you'll need to remove the socket and check the wires attached to it.
Jul 30, 2010 | 2001 BMW 5 Series
Cigarette Lighter does not give out power when plugging in GPS, Cell Charger, iPod Charger, etc. How do I fix?
chances are that it is just a blown fuse, which is very common, it is fuse #46 and is a 15amp fuse, location of fuse panel is under drivers side, most garages will do for no charge, but if you would like to try yourself, ownersmanual will show you fuse layout and look for #46, pull and see if it is blown 44e3364.gif
Jul 26, 2010 | 2001 Ford Focus
When on charge only lasts a few seconds and then cuts out
Your charging fuse has blown. If you have a warranty i'd suggest using it to get it repaired, if not you can either take it to a local repair shop or try replacing it yourself.
You need to have fairly good soldering skills as the fuse you will be replacing is tiny (1.6mm x 0.8mm). You can buy the fuse you need from ebay (do a search for ds lite fuse). Taky your ds lite apart and locate the "f1" fuse (here is a link to the pic of the fuse location: http://m3wiki.com/index.php/Image:Usgcpu01fuses.jpg ). Remove the blown fuse by de soldering it and replace it with the new fuse and solder it into place, once this is done you can put your ds back together and test if the charger now works... if it does but the ds will not switch on you will have to also replace f2 (also shown on the picture).
If you want a more detailed explaination for the replacement of the fuses do a google search for "ds lite fuse replacement2 and you should get plenty of guides show up.
Some people say just to bridge this fuse if its blown but i'm strongly against this, the fuse is there for a reason and if you bypass it more serious damage can occur and that will be far more costly and dangerous.
Hope this helps and like to say I accept no responsibility for any damage that may occur whilst using my advice.
Regards,
SOD69
Feb 04, 2010 | Nintendo DS Lite Console
My cigarette lighter is not charging in my car what could it be?
You mean there seems to be no power to the vehicle's lighter unit outlet.
This lighter unit outlet is normally wired through its own fuse so check the fuse panel in the car for a blown fuse. If blown it must be replaced with a fuse of the correct amperage. The owner's manual will show you where the fuse is located.
Before you check the fuse just check the cigarette lighter outlet with another plug-in device if you have one such as a portable 12 volt tire compressor or a 12 volt plug-in auxiliary light. It could be that if you are using a charger from the outlet, the charger plug or wiring may be faulty rather than the car's power outlet itself. (These outlets don't usually give trouble unless the wiring has been messed with or the outlet itself has been damaged or abused).
If no device works from the lighter power outlet check the fuse as it may be blown.
Sean
Voluntary contributor.
Dec 27, 2009 | 2006 Ford Taurus
Mis. plug ins on center console wont work
sounds like blown fuse for accessories , look in owners manual , should have a fuse location and fuse location map , i have noticed a lot of fuses blown because of cell phone chargers
Feb 23, 2009 | 2006 Pontiac G6
Car Audio & Video Logo
37 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
RegWorts
Level 1 Expert
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
