Question about Dell VOSTRO 3700 CI5 226G 3GB 320GBSYST173IN W7P NVIDIA CAM BT (4685926) PC Notebook
I used to have a touchpad settings program but can't find it any more
    Problem Solver:
  • 12 Answers
Usually all dell system are provided with ALPS touchpad. First check whether ALPS is installed or not from (control panel -> programs). If installed go to (control panel -> mouse) then you will see a tab called "dell touchpad". click on the image, you will see touchpad window settings. There check the checkbox (Display icon in taskbar).
If the ALPS touchpad is not installed please go to dell driver download site and download and install that.
Posted on Oct 20, 2013
Gateway the touch pad not function why?
Adjusting the touchpad sensitivity on a Gateway laptop lets you fix and prevent annoying touchpad problems.
Often the touchpad is accidentally brushed while typing, which causes the cursor to move out of place.
Or you may find yourself having to tap too hard or too often on the touchpad to open windows and programs.
These problems can be fixed by simply adjusting the touchpad's sensitivity settings.
Click the "Start" button and double-click "Control Panel."
Double-click "Hardware & Sound" and choose "Mouse" to open the mouse properties box.
Choose the "Device Settings" tab. Highlight "Synaptic Touchpad" in the Devices box by clicking on it. Click the "Settings" button underneath the Devices box.
Choose "Sensitivity" in the properties settings box.
Click "PalmCheck" to adjust the sensitivity of the touchpad to accidental brushes against the pad while typing, which causes the cursor to move.
Click and hold the pointer to adjust the setting on the sensitivity scale.
Click "Touch Sensitivity" to adjust the sensitivity of the touchpad to tapping.
A higher rating on the scale means less tapping pressure will be needed.
Click "OK" to save your touchpad settings.
May 15, 2013 | Acer Aspire Computers & Internet
My scrollbar will not work. I can use my touchpad just right and right click and left click, but I cannot scroll on a page I have to use my arrow keys, how do I fix this?
Most modern laptops with touchpads offer vertical scrolling, horizontal scrolling or both. These features are located along the right-hand and bottom edges of the touchpad, respectively, and are activated when you swipe your finger along the touchpad edge. Scrolling functionality is nearly always enabled by default, but some users find the feature an annoyance and elect to turn it off. In most cases you can simply turn the feature back on using the Windows Control Panel.
Click the Windows Start button, select "Settings," and then click "Control Panel." Double-click the icon labeled "Mouse." Select the Touchpad properties tab. The labeling of this tab varies, depending on your computer manufacturer, operating system version and the device drivers installed on your machine. Common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see this option, you may not be able to turn on scrolling for your laptop; skip the remaining steps and refer to the "Warnings" section below. Click the "Settings" button within the Touchpad Properties menu and look for the section labeled "Scrolling Settings" or similar. Enable scrolling within this section and define other scroll settings, such as scroll zone width and scrolling speed. Click "OK" to confirm your changes, and then close the Control Panel windows opened in the previous steps. The scrollbar on your laptop is now enabled.
Scroll Is Not Working With Windows 7 b> Certain computer touchpads have a vertical section on the pad itself that is used to scroll through the page or program window that you are currently viewing on your computer. If the scroll functionality suddenly stops working but the actual touchpad is still fine, this means that the part of the software for the device that controls the ability to use the scroll has been disabled. You can enable it again in the Control Panel.
Click "Start." Click "Control Panel." Click "Mouse." Select the "Enable Scroll" option (or whatever similarly named option is available on your specific model of laptop computer). Click "Apply." The scroll bar on your touchpad will now work again.
b>
Feb 03, 2013 | Acer Aspire 5750-6438 - 25519
Scroll bar
Feb 03, 2013 | Acer Aspire Computers & Internet
Touch screen not working
The touchpad on the Acer Aspire is built into the notebook itself, which makes the device much harder to troubleshoot or replace. While you can connect a universal serial bus mouse to the notebook if the touchpad becomes unresponsive, attaching any external device reduces the notebook's portability. Although hardware failure can cause the touchpad to stop working, most device-related problems are due to software settings or other conflicts.
Hardware Conflict
Peripheral devices connected to the Aspire can interfere with the integrated touchpad. Disconnect all of the external devices, except for the power adapter, that are connected to the Aspire; then restart the computer. Test the touchpad after booting into Windows. If the touchpad responds, a hardware device is interfering with the pointing device. Reconnect each device one by one to the notebook, testing the touchpad throughout. If the pointing device stops responding after connecting a particular device, the component is interfering with the touchpad. Go to the device manufacturer's website and look up the product model. Check the bulletin board to see if the manufacturer has posted a notice or update addressing issues with device conflicts. If no such update is available, download the latest driver for the component and install it on the computer. b> Disabled Touchpad b> The Acer Aspire 5516 comes with a preset group of keyboard combinations, called hotkeys, that are used to enable or disable devices, configure sound volume and screen brightness, and control the notebook mode. The hotkeys "Fn" and "F7" turn the touchpad on and off. If the integrated mouse is unresponsive, hold down "Fn" and press "F7"; then test the touchpad to see if the device reactivates. If the touchpad still doesn't work, open Device Manager from within the Control Panel. Expand "Mice and Other Pointing Devices," then right-click the touchpad device. If the touchpad is disabled in Device Manager, you'll see the "Enable" option in the context menu. Click it to turn the touchpad back on; then restart the computer. Corrupt Driver b> Windows Vista talks to the touchpad through a program called a device driver. The driver enables Windows Vista to "see" the touchpad and send it instructions. Once the driver communicates these instructions to the touchpad, the touchpad informs the processor that it needs to perform a task, and a specific set of code is performed. If the driver for the touchpad is outdated or corrupt, or if the driver isn't compatible with the OS -- Acer offers touchpad drivers for Windows XP and Windows 7, but these drivers won't work with Windows Vista -- the touchpad becomes unresponsive. Expand the "Mouse and Other Pointing Devices" section from within Device Manager; if Windows detects a problem with the driver, it places a yellow exclamation point or red "X" next to the device. Double-click the touchpad driver to see the error message; then look up the message on the Microsoft Support website for further assistance. b> Touchpad Settings b> Mouse Properties, accessed through the Control Panel, contains several different configuration settings that can alter how the touchpad behaves on the Aspire 5516. On the "Device Settings" tab is the option "Disable Internal Pointing Device When External USB Pointing Device Is Attached." As the option states, if an external mouse is connected to the Aspire 5516, the touchpad will stop working; disable this option if you're using an external pointing device. Clicking the "Settings" button opens the "Properties for Synaptics Touchpad" window. On this screen are the "PalmCheck" and "Touch Sensitivity" options. If PalmCheck is set too high, or Touch Sensitivity too low, the touchpad won't respond to normal touch, making the device seem unresponsive. Hope this helps.
b>
Dec 31, 2012 | Acer Aspire Z3801 All-In-One Desktop Pc...
Touch pad malfunctioning
Inorder to fix the Touchpad issue, try the hard reset steps:
Sometimes it is necessary to do a hard reset to erase all of the information in the temporary memory and regain functionality of your PC when it stops responding. For example, doing a hard reset is helpful if your keyboard quits responding, you cannot get your PC to come out of hibernation or sleep mode, or if a software program causes the PC to freeze.
The hard reset will not delete saved files on the hard drive.
Hard Reset Procedure:
1. Disconnect the AC Adapter.
2. Remove the Battery pack.
3. Hold the Power button down for 2 minutes.
4. Reconnect the AC adapter and Battery.
5. Turn on the Notebook power.
Also make sure that touchpad button is On. It will be just above the touchpad area where you can see the white led which shows that touchpad is on. If the led is in orange, touchpad is off.
If these steps does not work, update the BIOS version from HP website .
In rare case if the issue still persists, you need to restore the notebook to factory settings using Recovery Manager or recovery discs.
Before performing recovery, you need to backup all your data to external hard drive because it will erase the data from the hard drive:
Vista F11 procedure:
1. Reboot the notebook PC.
2. Press F11 when the HP logo displays.
3. When the Recovery Manager appears, click Next .
4. When prompted to use the Microsoft System Restore program, select No and click Next .
5. When prompted to use the System Recovery, select Yes and click Next .
6. Select the option to perform the recovery without backing up files and click Next .
The recovery process will return your PC to the factory image.
or
On some notebooks, the TouchPad can be turned off by pressing an on/off button located near the TouchPad. If the notebook does not have such an on/off button, you can still disable the TouchPad in its settings control panel.
NOTE: You will need to use an external mouse or some other pointing device to control the cursor when the TouchPad is disabled.
To disable the TouchPad:
Click Start , enter mouse in the search field, and then select the Mouse control panel program from the search results.
On the Device Settings tab of the Mouse Properties panel, click the Disable button to turn off the TouchPad.
The TouchPad can be re-enabled when needed.
May 07, 2012 | HP Compaq 6735s Notebook
I have an Inspiron 6000 Laptop the inbuilt key board is what i use. in paticular programs like Google talk and Google Mail the cursor behaveserratically mostly going backwards and sometimes forwards. How...
Control Panel, Mouse, Touchpad settings. (Depending on the driver Synaptics or Alps), there are settings to disable the touchpad while typing (Enable Palmcheck, etc)
Dec 17, 2009 | Dell Inspiron 6000 Notebook
How can I change the settings on my Dell Inspiron E1405 touchpad? I don't find "Mouse" or "Printers and Other Hardware" listed in the Control Panel. I want to speed up the movement of the touchpad but I...
I think that the E1405 uses the Synaptics Touchpad, so the settings should be found under Start > Programs > Synaptics. However, if it is not there, then try C:\Program Files\Synaptics. The application that controls the settings should be found in one of those two places. Good luck!
Oct 22, 2009 | Dell Inspiron E1405 Notebook
Touchpad does not work
in such case you can restore your program to old date...such as 5 days before.. hope your touhpad will work like before..
restore your program to the early date from when your touchpad was working...
reinstall touchpad driver....
otherwise you have to reinstall your Operating System...
Jun 23, 2009 | Acer Aspire One Netbook 8.9" Notebook
A shortcut or way to disable touchpad preasario m2000
You could disable it in Device Manager, but that has the downside of leaving you in a lurch if you are ever without your external mouse.
The latest drivers from Synaptics include a feature called "HandCheck" that will guard against unintentional movement when you are typing and your palm or other broad part of the hand is in contact with the surface.
http://www.synaptics.com/support/drivers (see the link for Features to get a full description).
But I saved the best for last. A little hotkey utility that does EXACTLY what you want: http://www.notouchpad.com/
There's a free trial, but it'll cost you $4.95 if you want to keep on using it.
Good Luck!
Jun 05, 2009 | Compaq Presario M2000 Notebook
Touchpad Not Working
If you has been installed the right drivers, it is hardware problem.
Try to use the factory touchpad program for your sony touchpad and see what happen (not only the driver, also the program touchpad software)
Oct 06, 2008 | Computers & Internet
Dell VOSTRO 3700 CI5 226G 3GB 320GBSYST173IN W7P NVIDIA CAM BT (4685926) PC Notebook Logo
82 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
