Question about Kenmore Refrigerators
ER F1 error
I have a kenmore bottom freezer refigerator. I am very handy. I bought a new ice maker motor and plugged it in. The motor is not getting power. The control board is not sending power to the motor. Is there something that needed to be reset. I know my kemore oven has a reset switch on the board for the oven fan...which befuddled the experienced repair main. Please help with any advice?
  • Kenmore Master
  • 4,654 Answers
Model Number???
Sea
Breeze
Posted on Oct 10, 2013
Testimonial: "79577563600"
Vish2
  • 74 Answers
SOURCE: Kenmore Refigerator Ice maker
First, ensure that you have water connected to the intake tube at the back. The water filter needs to be checked also. It is in the cooling section(not the freezer), at the top. If it looks old or water does not flow, it will need replacing. Depending on the model, there is a switch inside the freeze section behind the ice tray. Turn that on, and ice should be available after a few hours. Some models don't have a switch, but a wire hanger, that needs to be in the down position for the ice maker to work.
Posted on Aug 30, 2007
SOURCE: Kenmore Elite Trio
How to remove the speaker from a Kenmore Elite Refrigerator.
Our Kenmore Elite fridge has been beeping since we bought our house 9 months ago. There's nothing apparently wrong with it, the filters have been replaced etc. Sears said it would be a minimum of $300 to replace the electric panel (and my thought was that whatever is causing it could happen again!). We were ready to buy a new fridge.
Tools:  thin spatula or hand held flat razor (for scraping paint) flat screwdriver  soldering iron
I pried open the water dispenser with a razor thin spatula (i began with just my hands). the electronics then turned off. When the dispenser came completely off an electronic board dangled down.
On the board is the word 'buzzer' with two soldered points, underneath was a round black object, obviously the speaker. My husband and decided that if we pried the speaker off with just a screw driver, it may break the whole board. So we got out the soldering iron and one at a time, heated both soldering points labeled "buzzer." As each heated we used the screwdriver to pry the speaker off the board.
The speaker gently slipped off the board into our hands. We placed the board back in its place and snapped the water dispenser cover back into place. The whole thing took 2 minutes. The electronic lights all came back on the dispenser. Everything works perfectly. There's one less beep in our house!
Posted on Mar 10, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have a Kenmore model 795 77563600 refrig side
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
blueextc3221
  • 15935 Answers
SOURCE: Help....kenmore trio refrigerator, error message "er co"
The Er Co error code signifies a communication error between the display control board on the freezer door and the main power board on the outer back panel of the refrigerator.
Check the wiring and connections between the low voltage interface and the main high voltage board.
If you are able to unplug the refrigerator and remove the cover over the control board on the back of the refrigerator,
you can check the wiring connection on the main control board.
If this wiring connection is okay, check the wire harness connection under the hinge cover on the top of the left hand refrigerator door.
If these connections are okay, then you will need access the wire harness connection in the dispenser.
Posted on Sep 25, 2010
blueextc3221
  • 15935 Answers
SOURCE: Problems for Refrig. Kenmore Elite
The Er DH error code indicates the temperature sensor on the evaporator coil did not reach 50 degrees within one hour.
This would indicate the control board did put the refrigerator through a defrost cycle.
This problem could be caused by a defective relay on the control board, a defective defrost heater, a broken wire to the heater, or a stopped up drain on the defrost pan causing ice to form on the evaporator coil.
Before replacing the control board, someone should remove the food from the freezer, remove the freezer drawer, and remove the evaporator cover to expose the evaporator coil, heater, and defrost sensor.
The voltage to the defrost heater should be 120 volts ac.
The defrost heater is part of the evaporator coil and is not replaceable as a separate part.
You can test the operation of the defrost system by pressing "Ultra Ice" and "colder freezer temp" for 3 seconds.
The first time you press and hold the buttons the board will test the compressor, fan, and open the damper.
All displays should be on.
The second time you press and hold the buttons the board will test the compressor, fan, and close the damper.
The third time you press and hold the buttons, the board will turn the compressor and fan off and turn the defrost heater on for around 25 minutes. This would let you know if the defrost system is working.
http://knol.google.com/k/fixing-the-er-dh-code-on-kenmore-elite-trio#
Kenmore Refrigerator reads a code on door ER IF how do I clear this code out and what does it mean?
IF fault code usually for ice maker fan motor. Check in the freezer on left side beside ice maker
Jun 26, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have an error code er if on my Kenmore Bottom Drawer Freezer 79577573600. Everything works except the ice maker. Is this a part that can be easily replaced or should I go ahead with the service call I...
Jun 28, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Er if code on display
ER means Error code......
The If error message indicates that the fan for the ice maker has failed. The main control board receives a feedback signal from this fan motor for the ice maker. If the feedback signal is abnormal or missing, then the error message will be displayed. The fan motor for the ice maker could be bad. You could also have a bad wiring connection between the motor and the control board. A remote possibility would be that the control board is bad. This is not likely since you noticed the ice melting in your storage bucket.
I recommend calling a service technician to diagnose and repair this failure.
Sep 20, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
We have the kenmore elite trio bottom freezer refrigerator model 795.7756 - we have error message ER IF, we know the ice maker will not come on and have tried resetting it. How can we get the icemaker to...
Sep 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My kenmore elite bottom freezer unit displays an "er IF" message and water is leaking from the ice maker door. what does this mean? the manual doesn't help
Jun 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Apr 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
MY ICE MAKER WON'T WORK
Dec 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice Maker; Kenmore Elite
you have an bad fan motor or wire connection to the fan that is used for the ice maker..hope it helps
Aug 30, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Er If
IF is a bad ice fan motor or connection to the ice fan motor
Aug 04, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
76 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
