Question about Asrock P4AL-800 Motherboard
Will a raid drive work with this board - Asrock P4AL-800 Motherboard
    Sergeant:
  • 240 Answers
Here is the link to the manual for that board, it will tell you.
http://download.asrock.com/manual/P4AL-800.pdf
On first glance I did not see RAID listed but you may want to read in more detail.
Posted on Oct 10, 2013
Hard disk that was part of a RAID 0 has failed, but still spins up would swapping it's board with an identical one work
This is one of Seagates famous "Brick" drives. Swapping boards does not work due to the embedded firmware and serial numbers. However, it is a simple process to repair if you happen to have a $10,000 PC3000 in your shop.
I work in a data recovery lab and can recommend a lab near you if you wish to pursue this. Normally I would advise you to debrick and drop the data onto a new drive, however you will still need to rebuild your raid before you will have access in this case. De-bricking runs $300-$400 and recovering data from the raid costs anywhere form $300-$2000, depending on the size of the drives, number of drives and whether or not you know what position each held in the raid. If you decide to pursue this type of recovery, respond back here with your first name and location (Country, State, City). I will refer you to a nearby lab that can assist you.
Hope this helps,
Chris
Jan 10, 2011 | Seagate Barracuda ST3250824AS...
I cannot get the 2 x 4500Gb SATA drives to show up in the BIOS of a intel s875wp1 board. It is an older board and had the RAID setup in place - I just want the 2 x SATA drives as normal so turned off the...
ATA/IDE has nothing to do with SATA. Ignore.
Try plugging in the drives into the non RAID sata ports on the motherboard. I think when you disable raid you also disable the raid ports. You should have another set of sata ports on the motherboard, probably a different colour.
Nov 26, 2009 | Intel S875WP1-E Server Board Motherboard
Dell inspiron 1721 hard drive not recognized for Vista reinstall
ok, theres a small issue with the raid controller. You have to install a 3rd party raid driver (its on the dell cd) to continue, OR, you can set that BIOS's hard drive controls to ATA or LEGACY (legacy would likely work best, but youd have no 'raid' functions, but who sets up raid drives on a notebook?). Your last option is use the dell discs to restore, and inssert the windws disc when prompted
Nov 04, 2009 | Dell Inspiron 1721 Notebook
How can i save data to two different hard drives at the same time so they are backed up in case one goes down
THere are a number of different ways to do this depending on what type of computer you are using and how it is equipped.
Ideally, you would have a hardware RAID controller and would configure the two disks as a RAID 1 mirror. Any server should have the capability. Most engineering workstations also have it and an icnreasing number of desktop computers and even laptops now include SATA RAID controllers.
If this does not provide you enough information, please let us know more specifically what you have to work with and the answer will be more specfic as well.
Sep 14, 2009 | Maxtor Hard Drive
Unable to see RAID 5 config on Asus kfn32-D SLI/SAS MB
NVIDIA RAID does not support > 2TB (18xxGB) arrays. It will NOT show up properly in Windows.
Feb 20, 2009 | ASUS KFN32-D SLI /SAS Motherboard
Sata raid config
first check your bios & see what raid chips are enabled,usually there's 2. Your main raid is on the first 4 sata connectors, the other chipset probably controlls the remaining sata ports. So if there's an option to disable one raid chip,disable one,just not the one that you're using. I don't know what your bios screen looks like,so this is just a general view based on my experences with various boards,mainly asus.
Jul 13, 2008 | Abit AW9D-MAX Motherboard
Asus K8S-MS boot problem..
my understanding is that if you do not have other drives in a raid configuration you do not need the raid driver loaded ,have your hard drive plugged into the first sata slot, then format the hard drive ,instal o/s and all should be good.
hope this is of help
Terry
Mar 10, 2008 | ASUS K8S-MX Motherboard
HOW TO CONFIGURE RAID
I needed to see your board & can at this site. http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=493&DetailName=Manual&MenuID=1&LanID=0
This is good for you as well. It shows me & you that your board can handel 4 each DMA/ATA-133 (Ultra) IDE Hard drives/ CD/DVD drives IDE-1Primary & IDE-2 Primary Slave. Each can run 2 IDE drives. Also 4 each Serial ATA SATA's. Two separate SATA controllers with integrated PHYs, each supporting two
drives in master mode. In your manual on pg.32 & 33 will help you to setup a RAID if you wish. Or you can also set the RAID to IDE which will allow you to use all your SATA hard disks as a single drive without setting up a RAID system. The site above supplies all your drivers needed & manual. If you need more help please let me know here.
Luck!
Please vote......
Jan 13, 2008 | EliteGroup NFORCE4-A939 (NFORCE4A93910)...
Raid JMB363 RAID BIOS UTILITY
The P5K motherboard has a four port vanilla ICH9. There
Is no RAID on the Intel, when the chip has only four ports?
So S1, S2, S3, S4 are not RAID.
In the P5K manual, the RAID function exists on the Jmicron
Controller. One drive connector is internal (SATA_E2, on the
Left of the motherboard picture in the manual), and one
Drive connector is external (F_ESATA on the back I/O area).
This is not convenient for building a RAID0. (The intent is
To allow making RAID1 backup disks.) You'll have to snake
The SATA cable back into the computer, if you hope to use
It with two internal SATA disks.
The manual has full instructions for setting up RAID on the
Jmicron JMB363. The manual says to set the Jmicron to RAID
Mode in the BIOS. Two disks must be connected, in order to
Be able to press <control-J> at the start of the BIOS, to
Enter the Jmicron RAID setup in the BIOS. At that point, you
Can declare an array in the BIOS setup.
Then, when Windows is installing from the Microsoft install CD,
You’ll need to press F6 and offer the Jmicron RAID driver.
Section 5.5 of the Asus manual, describes how to make
A RAID driver floppy. The application in the mother board cd is available for make drivers disk
Dec 07, 2007 | Intel D101GGC Motherboard
Asrock P4AL-800 Motherboard Logo
47 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
