JL Audio fathem f112
NO POWER?? Is there a fuse inside?
    New Friend:
  • 25 Answers
Yes.
Posted on Oct 15, 2013
I have a jx jl 500/l, amp will not power down unless underhood fuse is removed
check your fuse on the battery and check the fuse on the amp or it might b loose connection of power line and the remote wire(the blue wire
Aug 27, 2013 | Jl Audio 500/1 Car Audio Amplifier
I blew the fuse inside the fuse block (60A). I replaced it so now I know I have power getting to the amp. I checked it with a meter and I show 12 volts passing throught the fuse block. I can not get the...
Sometimes there is a fuse inside but they are usually thermal and reset when they cool. You said u blew a 60 amp fuse. Is that what the manuf reccomends? Check your remote turn on wire (blue) make sure u have power on the remote wire when you turn the radio on. only thing really left are the grounds
Jun 11, 2011 | Jl Audio 1000/1 Car Audio Amplifier
Can you run a 8 gauge power wire to a jl audio 1000/1 amp and not have problems even though jl reccommends 4 gauge power wire?
Hi, if you're going to run a smaller wire, you also need to use a smaller fuse. A 50 amp fuse is needed for 8 gage wire. The fuse is there to keep the wire insulation from melting, which is what will happen if you run too much power thru the wire. If you don't plan to turn the amp up too high, this may work fine, but I would test it first with a 50 amp fuse before installing. You will need all of the speakers hooked up and the gain set to max to test the power draw. See the following link on wire sizing for more info: http://www.bcae1.com/wire.htm
Mar 14, 2011 | Jl Audio 1000/1 Car Audio Amplifier
The power light comes on then it give out
jl audio 12w7 with jl audio 1000.1
get a high volt capacitor 8 or more fared a breaker fuse 100amp .Best bet is to have an another battery hook up in back of truck for this kinda set up cause this amp really pulls alot of juice
May 20, 2010 | Jl Audio 1000/1 Car Audio Amplifier
Jl 1000/1 popping fuse
well you need to check to see if nt no shottage with the amp and also check if the fuse is not to low amp 20,,,, 25 if not put the amp in a separet 12 volt battery
Dec 10, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Clarification for jl amp problem
sounds very much like resistance was an issue and no they dont have an internal fuse sorry
Oct 12, 2008 | Jl Audio 500/1 Car Audio Amplifier
There are no fuses inside the amp.
Are any of the lights lighting up on the amp?
If so, which ones?
Jun 09, 2008 | Jl Audio 500/1 Car Audio Amplifier
Amp problem
you either have a bad ground or your power line is too small, the farther you go from the battery the larger wire you need.
Dec 18, 2007 | Jl Audio 1000/1 Car Audio Amplifier
54 people viewed this question
 Grubhead
Grubhead
