Question about Ricoh Office Equipment & Supplies
Fuser low heat error
Fuser temperature too low or fuse FU107 on Aficio 551, 551P, 700, 700P
  • 624 Answers
SOURCE: Engine Fuser Low Heat Error
Basically the error message is telling you the printer cannot keep the fuser temperature at the proper temperature (too low). It could be a lot of things but typically it is due to a fuser assembly gone bad.
Posted on Feb 21, 2007
  • 186 Answers
SOURCE: Xerox Phaser 6100- Error message - "Fuser Error Low Temprature"
time to replace the fuser assembly.
Posted on Jun 21, 2007
J PENGUIN
  • 12 Answers
THERMO FUSE OR THERMISTOR DIRTY OR BAD
Posted on Dec 31, 2007
  • 9 Answers
SOURCE: Ricoh Aficio 2238c: Fuser Oil Unit
you really can not refill the bottle but I would recommend two things. One find a fuser oil unit on ebay and order it quickly. Next hit the yellow clear modes button, then hit the numbers 1 0 7 , then hold the red clear stop button till the display panel changes. hit copy sp, select 7 data log. now use the page down arrows located in the middle of the disply till you see 7804 push it then go to #10 oil supply and hit execute. this will reset the oil counter and allow you to use the machine till you get the new unit.
Posted on Dec 16, 2008
  • 406 Answers
SOURCE: fuser temperature error for xerox 3100mfp
kindly check externally the fuser is heating or not. i SUSPECT THE FUSER MIGHT BE FAILED.
Posted on Nov 16, 2009
How do iremove error of code sc542(ricoh aficio 1515mf)
542 Fusing temperature warm-up error (center)
The fusing temperature rises less than 7 degrees in 2 seconds, and this continues 5 times consecutively. The fusing temperature is not detected in 25 or 35 seconds. • Fusing thermistor defective or out of position • Fusing lamp open • Power supply board defective
This is the reason for the error code according to (printcopy.info) Might help you in some way, but not my area of expertise.
Jan 20, 2015 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh aficio 4850 emf
Most fuser problems have to do with the fuser lamp and or the thermistor, or the thermal fuse. If you can put you hand near, and I did say near, because the fuser is very hot and can burn you, you should feel heat. Use an inferred thermometer to pick up heat. Should be around 225 degrees F +- a few degrees. If no heat detected the lamp is bad or is not receiving voltage. The thermistor detects heat from the fuser roller, it lays on it, and sends a signal to the logic to turn up the voltage to the lamp or turn it down. The thermal fuse could be open hence not voltage to the lamp. Last but not least no power from power supply or no signal from logic board to turn up the juice. Hope that helps.
May 11, 2014 | Ricoh Aficio 450 Copier
How to reset fuser temperature SC542 RICOH Aficio SP C232SF
Fuser Temperature errors usually mean that one of the heating elements has failed inside the fuser. Time for a new fuser or, a good rebuilt one.
May 24, 2012 | Ricoh C232SF All-In-One Printer
Error sc 553
error SC533 is a problem in the fuser check/replace thermistors and check thermostat/fuse for broken circuits. then check the fuser if it is heating or hot then check the contact of the fuser and the machine there might be a loose contact on the fuser and connector of the machine. after checking it reset the machine by the way is this SC 533 for the aficio 2018 or other model?
Sep 16, 2011 | Ricoh Aficio 2018 Copier
Ricoh Aficio 1013 error code sc 544
Fusing low temperature error
Symptom: Detected fusing temperature
remained abnormally low for 1
second during fusing operation
(below 140°C) or during standby
mode
Possible Cause: Fusing thermistor defective
• PSU defective
• Bad connection between fuser and
machine
Dec 18, 2010 | Ricoh Aficio 1013 All-In-One Laser Printer
Gestetner 3225 error code SC544 - functional problem
SC544 indicates low fuser temperature during the warm up process. This means you have a problem with the fusing unit heating up. The fusing unit is located right where the paper exits the machine. Most common failure on these Ricoh's (Your Gestetner 3225 is made by Ricoh model aficio 250) is the fuser thermistor. This is a small electronic part that measures the temperature of the fusing roller. When they go bad they do not "see" the heat and therefor the code pops up. You are going to need to have a tech look at this for you as you will need to determine for sure which part is bad then you have to go into the service mode to reset this SC code before the machine will run.
Good Luck and Thank You for using Fixya.
Sep 07, 2010 | Gestetner Copier
ERROR SC545
This error code indicates a fuser unit malfunction. Most likely it will at least need new thermistors. Thermistors read the temperature of the fusing rollers. This code means the thermistors thought the unit was too hot. For this reason I am hesitant to give you the service mode reset procedure as you could do further damage.
Good Luck
Nov 27, 2009 | Ricoh Aficio 2022 Black and White Copier
Ricoh aficio 1022 sc 546
problema ricoh aficio 1022 copia en blanco aparece codigo
sc 193
Oct 20, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
Ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Oct 23, 2007 | Ricoh Aficio 2022 All-In-One Laser Printer
Feb 20, 2007 | Samsung ML-2551N Laser Printer
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
