Question about Electrical Supplies
Pramac e4000 Hi I have a pramac E4000 generator running off the Honda gx200 motor and for it to have unough power to run a small angle grinder I need to turn the revs right up on the engine
freetek
  • 5568 Answers
SOURCE: neovo e-19a flat panel will not work with gateway e4000.
You may have to turn on the external video from inside the BIOS; not all systems are set up to feed video to the VGA port unless told to do so.
Posted on Oct 26, 2008
CarlGehrke
  • 169 Answers
SOURCE: Honda EM 2500 Generator
I posted a general tutorial on troubleshooting this problem here.
Rate me?
Carl
Posted on Dec 05, 2008
SOURCE: my honda ev6010 engine runs good, but stopped
I am looking for an EV6010 Honda generator. I know they stopped manufacturing them, but I would like to know if anyone has a leftover for sale?
rmhoch@hotmail.com
Posted on Aug 19, 2009
techno_svcs
  • 11 Answers
SOURCE: I need to replace the power button on a Gateway E4000 mid size to
I think you will find this site useful in assisting you with removing the cover. I think you can scan directly to pg 107 for the "mid-tower" http://nzr.mvnu.edu/facilities/items/gatewaye4000manual.pdf
Posted on Sep 12, 2009
SOURCE: I have a Coleman Vantage 3500 motor runs no generator output
This sound like a loss of residual magnetism in the generator. The field will need to be "flashed".This is also known as re-exciting the field of the generator.
The Coleman manual gives these steps:
1Use a 6 Volt lantern batters (dry cell) or a 12 Volt automotive battery.
2.Disconnect all loads from generator.
3. Remove the brush cover (that's the rectangular plastic cover on the end of the generator.)
4. Plug a lamp or light into the generator before starting the engine. The light will illuminlate when ?Voltage has returned.
5. Start the engine with no load connected to the generator.
6. Attach the "-" lead of the battery to the negative brush. Very briefly touch the "+" lead of the battery to the positive brush. Remove as soon as Voltage builds up.
Posted on Oct 09, 2009
Honda generator motor runs but no electricity.
You should open the back cover of the alternator, take a voltage meter and check for voltage if there is no voltage then check the brush if the brush is ok then change the avr .
May 12, 2011 | Pramac Commercial 5000 Watt Honda ...
When I turn on my nordictrack e4400 it runs for 1 second and then stops
hi,
There are two possibilities for this problem
1. Check the speed sensor on near the motor pulley. Remove the sensor and clean it and re-fix it. then make a try. if problem remains then
2. The motor speed controller is faulty. There is an IGBT for controlling the motor speed. If it get shorted the motor will run it its high speed.
Be sure before opening the treadmill remove the power.
ok
Mar 22, 2011 | NordicTrack E4000 Treadmill
Belt slipping and power supply making noise
Have you checked to make sure it is not the belt that drives the front roller from the motor slipping. Get somebody to watch while you are using the machine and determine if the motor is still spinning while the running belt has stopped.
Apr 18, 2010 | NordicTrack E4000 Treadmill
GATEWAY E4000 Desktop P4 1.8GHz ,768MB doesn't recognize monitor
Try pulling the ram chips out and see if it turns on.
pull out the cards and unplug the cd and hard drive and see if it turns on,,
If you have no luck then its a bad cpu or motherboard,
Apr 10, 2010 | Computers & Internet
Its on incline 12 and wont go down. When i try to decrease it imakes sound like its happening but its not declining!!! Please help!!!!
Open front cover to see if there are any visible broken parts. If not try recalibrating the incline. If it doesnt calibrate you will more than likely need an elevation motor. The guide for the gear on these sometimes will break. The motor runs but gears arent on track.
Jun 06, 2009 | NordicTrack E4000 Treadmill
Mar 26, 2009 | Computers & Internet
How to change oil and what kind to use on a es 5000 generator
you should have a drain plug at the side and bottom of the motor crank case its a small plug with a square head how old is your generator if new put 10w30 oil if old put sae30w if really bad add some lucas oil treatment also now a 9 h.p. should take less then 2 quarts
Mar 23, 2009 | Pramac Storm 5000 Watt Generator
Neovo e-19a flat panel will not work with gateway e4000.
Oct 26, 2008 | Neovo E-19A 19" LCD Monitor
Electrical Supplies Logo
53 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
