Question about Samson C03U Professional Microphone
Software doenst recognize mice
Software (Sonar LE, Cakewalk)doesn’t recognize microphone. C03U No option trough Input (as seen on dummies instruction vis from Samson) only “none” and “1 in, 1 out”. The last I can’t select for some reason. Vista/pc
    President:
  • 1,138 Answers
Try downloading ASIO4all and carefully following the directions.
Posted on Apr 29, 2009
Need serial number to sonar home studio 7
It is something you get when you purchase the software. If you have already purchased the software, contact Cakewalk support for assistance.
May 28, 2012 | Cakewalk SONAR Home Studio 7 XL for PC
Samson CO1U won't work - it's installed fine, the sonar LE cakewalk has installed aswell.. but for some reason it won't let me click on the Microphone to use as input. i am using windows 7 - will that have...
hmm that is strange, are you seleting the mic as an input in the source for audio? the software works on win 7. have you tried other mics in the input on your sound card?
Mar 19, 2011 | Samson C01U Consumer Microphone
I plug in my usb for the samson studio gt. and no software comes up. but the box says it comes with it. what do I do?
I believe you're referring to the Cakewalk® Sonar LE music production software which should be in the box. If not any recording software will do. Click the link below and go to the page that says "STUDIO GT QUICK START" and follow the instructions.
http://s3.amazonaws.com/samsontech/related_docs/Studio%20GT_OM_ENG_V1.1.pdf
Jan 13, 2011 | Samson Studio GT Active Studio Monitors...
No live sound using Samson CO3U and Windows 7 x64
I don''t think you can solve this problem. The problem is that the computer has to digitize the incoming audio, then echo it out. This conversion takes time and is also governed by the real time clock servicing of the devices. You could try upping the priority of the conversion process, but I don't think you are going to be satisfied with the result either.
You would be happier to use a mic and external mixer where the audio is true real time rather than having the conversion latency time.
Jan 29, 2010 | Samson Audio C03upak Co3u Microphone with...
I downloaded a sonar cakewalk program to my computer but there is no sound. How do i fix this?
First check your speakers with any media player. If this sounds OK then keep the volume level up/same sothat you can hear any sound from speaker. Now Check the input & output devices in sonar (Select the appropriate device). Put any audio file in a track in Sonar & check...
If you are not a regular user of Sonar then it is better to switch to another DAW which are better (at least in my openion) before you are used to Sonar.
I'd suggest "Nuendo" of Steinberg, it is highly professional, far better & far more user friendly than Sonar. I've used both...
Aug 16, 2009 | Cakewalk SONAR 4 Producer Edition for PC
Stuttering during audio playback in Sonar
The stuttering is caused by excessive CPU usage, in other words: you have too little CPU power to play the file with the inserted synth smoothly. You could try inserting a different synth or play with the rendering-options of the synth (like disabling aliasing, etc.) or increase the audio buffer size (under audio options ?), but the only longterm solution is upgrading to a much faster computer.
Even when you find some tweak which lets you play the file (just) smoothly, adding another effect or synth is likely to cause it to stutter again, since your computer doesn't meet the official (!) minimal requirements for running Cakewalk Sonar 6, which is at least a Pentium 4 1.3GHz computer (and you have a 1.0GHz computer).
I would recommend upgrading your computer to something which at least meets the "recommend requirements" of Cakewalk Sonar 6, which is a Pentium 4 2.8GHz or newer (like any Intel Core 2 system), when you're serious about composing music.
Aug 12, 2009 | Cakewalk SONAR Power Studio 660 Full...
Timing after recording. and midi composing
May I suggest you try to adjust your audio settings inside Sonar. Also it is a good idea to always keep your C drive well defragmented. I once had this problem using Sonar LE and the only way I got rid of it was after formatting my C drive and reinstalling the drivers and Sonar again. After that the problem came back and then I upgraded from the SB Live to Audigy SE.
Make sure you also have lots of free space on your C drive and have a decnt amount of ram.
May 11, 2009 | Cakewalk SONAR 4 Producer Edition for PC
Sonar LE: no playback b/c "NO MIDI OUTPUT" selected
You have to go in to the Sonar configuration and select what the default MIDI and WAV input and output devices are. That is usually handled by the ASIO driver. In your case you would select the USB mic for input, and for output you need to select your sound card. For midi you need to configure the midi controllers and the software synth or soft instrument you are using.
If you need any more detailed help I need to know what version of Sonar LE it is and what sound card. I am guessing it detected the mic and just needs the output device configured as I mentioned.
Dec 31, 2008 | Edirol UA-4FX External Sound System
Samson C03U Professional Microphone Logo
276 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Jerry Umali
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
