Question about Xerox Office Equipment & Supplies
Xerox phaser 8500 printer error message 19003,48 paper tray will not raise
  • 2072 Answers
SOURCE: xerox Phaser 8500 error code
That is a print head temperature fault.
Either your print head has failed, or the electronics module that supplies the power to heat the print head has failed.
Posted on Aug 26, 2008
eagle338
  • 4889 Answers
SOURCE: xerox phaser 8500 fault 37,008:44:11605 What is it?
The 37 series faults are usually due to the failure of one or more heaters in the print head. Usually a comparatively inexpensive fix if its just the electronics module(part no:119649580). You will definitely need a tech's assistance to fix it. If the printer is under warranty they XEROX should do it for you free of cost. Hope that helped.
Sai.
Posted on Jan 12, 2009
  • 4 Answers
SOURCE: Phaser 8400/8500/8560 maintenance kit
No, it will not work because the chip (CRUM) is not compatable.
Posted on Jan 13, 2009
SOURCE: Xerox Phaser 8200 false "Replace Paper Tray" message
I've had a similar problem with a client's 8200 printer, and looking at the right hand side of the tray someone had previously put some tape over the topmost 'slot' (above where the green slider goes across).
I put some new tape over the top slot and the 'replace paper tray' message went away.
Admittedly, the tape gets pushed in so I don't know how long it will be before the tape gets dislodged and the error re-appears.
The printer is well out of warranty and they don't want to pay anything to get it fixed... so this solution is fine with them.
Hope this helps someone else out there :-)
Posted on Jan 28, 2009
  • 7 Answers
SOURCE: error code 09.036.44:38950
09,03x 35 = Cyan 36 = Magenta 37 = Yellow 38 = Black The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error. Turn off the printer. Turn on the printer. As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display. Release the buttons, it will now come up in the service mode. Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok. Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Posted on Jun 10, 2009
My Phaser 8500 will not print and has error 08,045,43:75066 - Anyone know what this means?
The Xerox support site indicates there is a paper jam to the printer, so you should check the paper tray, front and exit cover for any jammed paper then power off and back on the printer. Have a look here: http://www.support.xerox.com/support/phaser-8500-8550/support/enus.html?operatingSystem=win7x64&fileLanguage=en
Feb 24, 2011 | Xerox Phaser 8500/DN Printer
Hi i have phaser 8560, it gives me a error 09,038,46:62248, plese who can solve me the problem.
Hi there
The onlty thing I can find close to this is.
Acording to the manual its a ink loader error like your loading the wrong type of ink like the puzzles pieces arent matching and hitting the sensor flags right. Yours by the 8 is referring to the black ink. Anyway go to troubleshooting on the control panel. then to service tools. when in service tools press and hold the up arrow while still pressing the up arrow press the down arrow. the display should say hidden menus. go to diagnostic mode press enter go to funtion menu. then go to clear ISC fault and enter. ISC=ink stick count fault. I hope that helps. Just to let you know Ive had nothing but problems with third party ink and once its in the system its hard to get out so I would watch what im doing with my expensive equipment
Feb 18, 2010 | Xerox Phaser 8500/DN Printer
My xerox 8500 will not read that I have paper in the tray and the screen is blank, I can't read anything.
Call Xerox at 1-800-835-6100 report that problem and they will send you a display. It is a known problem and they will correct it .
Nov 04, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8500 Error 09,005.40:100473
You don't have to take all the printer apart just the ink loader. Which is held mostly by the side covers. Get a flat head and break down the peaces left over on the cyan ink and flip upside down the ink loader and that should make it work again with no problem.
Jul 30, 2009 | Xerox Phaser 8500/DN Printer
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
XEROX ERROR CODE 09,008,43:10249 PLEASE HELP
What that normally means is you have one or more ink stucks not sliding down the ink loader properly.
Check to see if you have one or more ink sticks not moving freely in the loader. That is what that code means.
Here is the manual information.
  1. Remove any paper from the Output Tray.
  2. Raise the ink loader Top Cover to access the ink stick bins.
  3. Make sure the Ink Sticks are able to freely slide down the bin.
    CAUTION: Do not force an Ink Stick down the loading bin.
  4. Close the Top Cover.
Feb 05, 2009 | Xerox Phaser 8500/DN Printer
Xerox phaser 8500 error 13,327.42:31555
If you have Warranty Still, CALL XEROX!!!, That error message indicates that you have a failed temprature sensor inside the print-head, 90% chance Xerox will have to replace print-head. Print head is VERY expensive to replace out of pocket ($500-800+)
Jan 23, 2009 | Xerox Phaser 8500/DN Printer
Dear Sir, We have a Fujixerox Docuprint C2100 and we have a message error about our tray1. We try to print using tray1 (have paper inside) but the printer request paper.
I would remove the tray from the machine and all paper from that tray. Then turn it over and make sure and make sure that the paper slides are working correctly. The machine doesn't actually detect the paper just the fact that you have the paper slides up against it. So after you have put the tray back in the machine make sure the paper slides are firm up against the paper and it should be fine.
Also, while the tray is out of the machine make sure there is nothing in behind the tray blocking the sensors.
Jan 19, 2009 | Xerox Phaser 8500/DN Printer
43 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
