Question about Dell PE2800 Server
Error poweredge system R510
Server quit has this error E1229 CPU2 Vcore Regulator Failure Reset CPU. I reseated the cpu but still wont post
    Sergeant:
    Champion:
  • 272 Answers
Reset bios, test with a different power supply, ensure all cables connected securely to the CPU FAN header, and then conatact DELL support.
Posted on Oct 21, 2013
4 Suggested Answers
  • 7 Answers
SOURCE: Adding a second processor to my 2600 server
I hope that you fixed your problem without troubles by now, but if you still have not, I can help. I added a second xeon processor to my Dell PowerEdge 2600 a couple of years ago.
Lay the server on its left side then loosen the three thumbscrews on the right front side and "slap" the cover off backwards.
You should have by now identified the current processor by running cpuid software that I think comes from Intel's website in order to buy an identical cpu. That was the hardest part, finding an identical one still for sale. If I remember the Poweredge 2600 could only use xeon processors with only up to 512 kb of cache or someother small amount and are not that available still new in the box.
You also have to get two identical voltage regulator modules (vrm). I was not able to get a second one for some reason and just bought two identical ones specifically for the xeon processors that I was using. Be sure to do your homework on this. MATCHING cpu's and MATCHING vrm's.
That's it. Each processor has two cores and you should see all four after you boot.
Another thing to think about would be setting the processor afinity to run your most intensive process to all four cores while only letting most applications to only use the first core.
I hope this helps if you haven't already had any success.
Posted on Jan 21, 2008
  • 101 Answers
SOURCE: Dell Poweredge 1800 server
Hi the Power Supply also needs to be upgraded for the additional RAM and new CPU . Please look into this aspect. My opinion a slightly Overrated PS would be better .
Posted on May 07, 2008
  • 13 Answers
SOURCE: DELL Poweredge 2600 Bios FREEZES After Cpu check and before SCSI Drives check HELP!!!!
The BIOS check can freeze for many reasons.
Can you tell me if this is an existing system that was working fine and then had this problem, or is this a new (or new to you) system?
Can you give more information on what is actually showing on the screen?
Posted on Nov 06, 2008
Dell poweredge t300 server e1410 cpu 1 error
The e1410 is an error that is reporting an interruption to the CPU processes. It isn't identifying an issue with the processor specifically, it is just saying its processes were interrupted. Normally when you see the E1410 you will see another error listed with it in the hardware log. Do you see any other errors in the log? Also, what is the BIOS and Drac versions at currently? I ask because the server being very out of date can cause issues like this as well.
Let me know what you see.
Aug 30, 2014 | Dell PowerEdge T300 Server
Dell Poweredge 600SC running WIN SBS 200 boots to a black screen
The failed boot could be from a number of issues, mostly hardware failure. I would start with the processors. If the system is using 2 cpu, I would remove the 2nd cpu, reboot checking to see if you still get the black screen. If you do, remove cpu 1 and put cpu 2 in cpu 1 slot are retry. If the system boot, replace cpu 1. If not, move to check ALL the memory cards installed.
This could be a lengthy process. What hardware/software changes was made before the issue started? Worse case, the server may have reached its end life and need to be replace all together. I would also recommend reaching out to HP support for more information about your system.
Good Luck
N.I.T.
Feb 21, 2014 | Dell PowerEdge 600SC (Refurbished)...
Error code 5800:041A
5800 usually points to a processing issue but most likely its the Motherboard
Feb 17, 2014 | Dell PowerEdge R900 Server (146GB4GB)...
E1229 CPU2 vcore regulator failure on Dell R510
It means the voltage reg on the motherboard has failed or the monitor for it is failing. Typically, this is a warranty repair from Dell. If you're out of warranty, then you can either replace the mother board, or if you're brave, replace the regulator and all the broken caps that probably caused it to fail.
Oct 10, 2013 | Dell PE2800 Server
I have XEON Core Duo processors with Dynatron heatsink fans attached. One of my CPUs is running about 8-10 degrees hotter than the other one and if I let it idle they both heat up until the alarm sounds...
Hello try to download the manual here:
http://www.supermicro.com/products/motherboard/xeon1333/5000x/x7dae.cfm
The fault could be a wrong setting in the bios chipset or cpu option.
Maybe one of the cpu has a wrong mhz setting ( overclocking )
This will make the system unstable.
75 degrees celcius is too hot even for a intel cpu.
Try to reset the bios to factory settings.
And look also for an bios upgrade.
WARNING!
Please do not download / upgrade the BIOS/Firmware UNLESS your system has a BIOS/firmware-related issue. Flashing the wrong BIOS/firmware can cause irreparable damage to the system.
Remember to add new cooling paste, not much, when removing the cooling element and fan.
Good luck
Jul 31, 2013 | SuperMicro X7DAE Motherboard
Error message on server says to call support.
Disassemble Components an Clean the System with Air blower,
& Assemble Components Check it
Aug 26, 2012 | Dell PowerEdge T300 Server
Nov 05, 2008 | Dell PowerEdge 2600 Server
May 07, 2008 | Dell PowerEdge 1800 Server
Nov 16, 2007 | Dell PowerEdge 2600 Server
Dell PE2800 Server Logo
117 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
