I have a CDA CI592WH washing machine and I need to replace the interlock plate. Is this an easy swap job or does there need to be dismantling work before you can access it
4 Suggested Answers
SOURCE: indesit wash machine drum bearing
Some models like the WE12 have sealed drums where the bearings can't be changed. You have to buy a complete unit for about £120.
Posted on Jun 23, 2008
  • 71 Answers
SOURCE: My Amana washing machine stopped spinning.
moz-screenshot.pngac4805b.gifhere is the image on how to change the belt......it's pretty easy to do as you can see by the diagram.PS2027742 is the part number on the belt.
Posted on Oct 03, 2009
  • 3 Answers
SOURCE: Washing Machine CDA CI392 Model Manual needed
if you goto www.cda.eu you can download 1 from their
Posted on Mar 15, 2010
How do i unlock the door as it will not open
As you know, the door is locked while the machine is working.
The most likely cause of your problem is that the 'interlock' has malfunctioned and needs to be replaced.
The problem is to get the door open.
Try to remember which way the latch hooks into the interlock.
It may be that a flexible kitchen knife slid behind the door can release the doorlock, or a length of thin strong string passed around the door and pulled towards the hinge side will release the latch.
N.B. Be careful not to damage the seal....!
If these actions don't work it would be best to call a technician to release the interlock from the inside of the machine and replace the interlock, which can be a slightly complicated job..
Good luck.
Nomess
Mar 08, 2015 | Hotpoint Aquarius WD640 Front Load...
What is the de error message
Hi Prasanthi.
On front load machines, some manufacturers us de as 'door error'. This generally relates to a fault with the interlock mechanism.
This is the door lock which prevents the door from being opened while the machine is working..
If the door won't lock and/or the machine won't run. OR the door is locked shut, then this is the most likely situation.
The interlock switch is part of the electrical circuit.
NOT recommended for a handyman.
It's not a big job for a technician, and you will probably need a new interlock.
Good luck.
Nomess
Interlock switches look like this.....
Feb 09, 2015 | Washing Machines
Door of Washing machine doesnot opened
the door interlock has failed
other then try to leave it off and struggle with the door
you need sometimes to release it from behind
not easy sometime with some machines
the replace the door lock interlock catch
it will work fine then
Sep 19, 2014 | Siemens Washing Machines
91 subaru pneumatic air suspension not working
The front struts from either sedan or wagon are interchangeable so either will work, back struts have to be from the same type (wagon or sedan) as top suspension mount plates are different. Just pull the air suspension out and replace with standard struts. There are plenty of people dismantling them so parts are easy to get and quite cheap.
It's easy to swap, just remove each strut and bolt in the standard one, Remove the switch from the dash and get a blanking plate from a dismantled vehicle and fit it into the hole.
Mar 13, 2012 | Cars & Trucks
Is it possible to change the drum bearings on a Hotpoint WF860 washing machine??
it is possible but not a job that could be called easy, you have to completely dismantle the machine to remove the inner drum and then the bearings. It all depends on your level of mechanical ability but will be a job that takes you a few hours at least.
Mar 02, 2012 | Hotpoint Washing Machines
Water will not drain from the machine. We washed a bathmat with a rubber backing and it came apart. Something is clogged, but the owner's manual just says to restart the DRAIN program. We've done that...
Draining problem is very common in Bosch washers. However, it is very easy to fix.
1) Remove the white circular plate, located on the bottom left. Push a small screwdriver or needle through it and simultaneously rotate the plate clockwise.
2) Open the drain valve. Rotate the circular black handle counterclockwise. Beware of residual water.
3) Clean it. Re-assemble in reverse order.
Thanks for contacting fixya.com
Nov 24, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
E40 on my washing machine
E40 is an error from the door locking mech (interlock).this is the bit behind the port hole door frame ,where the door striker pin goes through hole.hope this helps you.held on with 2 screws and you need to remove plastic clamp from door gasket to gain access.
E40.door not locking.door interlock faulty or triac faulty on pcb
hope this helps pls do let me know
Feb 20, 2009 | Zanussi ZWF1430W Front Load Washer
ZANUSSI ZWF1437W WASHING MACHINE
yes sounds like door interlock cheap and easy diy job goodluck and unplug regards jason
Jun 14, 2008 | Zanussi ZWF1430W Front Load Washer
Door Lock LED flashing
Hello, This depends on how old your machine is mine is now 7 years old so I do not want to invest in long term soltions. So I repaired my own, I bought a new interlock and replaced the old one that did not work. So I shorted out the three links that go to the interlock, the machine now shows the lock is always on and you can open the door during the wash cycle so BEWARE. Also if you have never wired a plug or fixed basic electrics DO NOT DO THIS. 1. Turn off power and unplug. (Very Important) 2. Remove lid you will need torx drivers. 3. Unscrew door interlock from the front of the machine. 4. Lift out interlock. Try replacing the interlock with spare first (about £15). 5. If new interlock does not work do the following. 6. Put Interlock back on without wires attched to it. 7. From car spares shop buy spade conectors and create a three way shorting link (insulate well). 8. Put shorting link into each of the wires that go to interlock. Safely tie up wire to a loom (do not let dangle) 9. Shut the door remove hands and try starting the machine. 10. If that works put the machine back together. And warn people that the DOOR CAN BE OPENED DURING WASH CYCLE and STARTED WITH DOOR OPEN. So check when the machine has stopped properly.
Oct 20, 2006 | Hotpoint WMA58 Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
