I have washer/dryer Servis (Easy Logic 1500) model: M9505W-1. When is washing or drying there is no heating. Is it thermostat or heating element, or something else that I don't know of? Can I repair it by myself? Thanks.
  • 1462 Answers
SOURCE: Hoover nextra 5+5 washer dryer HNWF 3135 heating broken
it is seperate heaters for wash and dry and unlikely to be connected with blocked filter tho you should check filter regularly. take top off. on manifold running across top you will see stats. one of these at least is resettable by presssing a small knob in middle and if it has gone you will hear a slight click. then check dryer manifole for build up of lint as pooir air flow can cause stat to pop. for wash heating, start by checking continuity of the wash heater located at the bottom of the tub
Posted on Apr 19, 2007
  • 1003 Answers
SOURCE: washer dryer - dryer does not heat up
REPLACE HEAT ELEMENT TO SOLVE DRYER PROBLEM
Posted on Feb 02, 2008
SOURCE: My WVF 2402 washer/dryer washes clothes ok but doesn't dry them.
Sorry I'm way late with this but I've only just noticed it. Unplug the machine from the mains! Remove the lid (with a torx screwdriver) and you'll notice a small circular device with 2 leads attached on the top of the machine, in the centre there's a small button, press it and it should click......you've fixed it This is a thermal cutout safety device designed to switch the drying heater off if it becomes too hot. The probable cause for this is that you've over filled the machine and the air didn't circulate freely. as a rule of thumb, dry 1/2 as many clothes as you wash.
Posted on Apr 26, 2008
docjohn174
  • 943 Answers
SOURCE: Need to replace the heating element in stackable Kenmore model 417.98702891
hi thanks for the question just underneath the dryer on the front theres a panel remove this panel the element is on the right thanks for the question the appliance doc
Posted on Sep 15, 2008
SOURCE: Kenmore Stacked Washer / Dryer Model Number 417.97802792
can the rear bearing on the drier be oiled/greased though the back casing, any easy way of stopping sqeek!
Posted on Oct 14, 2008
I have a Servis M9409S washer dryer. The dryer isn't heating up at all, and I'm assuming it's the heating element. Does anyone know how to replace it?
There is only one place that I can find that part: http://www.partmaster.co.uk/servis/m9409/element/catalogue.pl?path=66991,61187:66997&model_ref=29129&refine=element
Jun 05, 2014 | Dryers
Fridgidaire high capacity stackable FEX831CSO/ washer/dryer no heat
If dryer tumbles but won't dry usually means the heating element has broke in two. It can also be a thermostat usually installed near outlet of blower assembly or a limit switch installed in element heater assembly.
Jun 16, 2012 | Washing Machines
Dryer running but will not dry clothes could it be the thermostat or heating element?
Almost always this means the heating Element has went out. They are not very expensive and are easy to replace.
Thumbs Up if helpful!!!
Jun 18, 2011 | Frigidaire Clothes Dryer Thermostat...
Its about my washer/dryer combo whirlpool model lte6234dqs: -the dryer don't produce hot air and therefore don't dry. -Anybody please?
check your breaker to the appliance you must have 220 volts before it will heat if you only have 110 volts it will run but not heat otherwise it could be a thermostat or heating element which is hard to say with out me being there to check it out with a meter
Nov 19, 2010 | Whirlpool LTE5243D Top Load Stacked...
Dryer not generating adequate heat. needing multiple cycles to dry. cleaned out the vent but no improvement. heating element??
I would check heating element also on the heating element box is a thermostat probably need to check that also take the wires off the heating element and use an ohm meter to check it out it should register and not go to infinity. Same for the heating thermostat.
Jul 15, 2010 | Maytag LSE7806A Top Load Stacked...
No heat during drying cycle
your heating element or the thermostats that control the heating element could be bad. research no heat for your make of dryer, it should show how to ohm the thermostats and element for fault. They should all read 000 when ohmed. 000 being a complete circuit. I have been having thermal fuse problems with my whirlpool dryer, so I'm learning as I go.
Oct 22, 2009 | Bosch Logixx WFT 2806 Front Load...
The machine heats up, ( the clothes are steaming), but they are not getting dry. It is to the point where you can dry one towel at a time ... don't know if it is an easy fix my husband can sort out, or if...
It sounds like the heating element is partially burned out. If the element is partially burned out, the dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it. Make sure all duct work is clean.
Although it is not a common problem, the cycling thermostat could be bad, one of the thermostats that controls the heat in the dryer may break and cause the dryer to heat poorly. The thermostat is usually a small, round, black device that is mounted to an oblong steel plate. The plate is mounted to the internal duct work with two screws. Hope this helped. Good luck.
Jul 16, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Haier Not Drying
most likly to be thermostat if you remove the lid you should see 2 little round thermostats on top somewhere some stats have a reset button on 1 of the thermostats if there is press it if it clicks try it on a dry to see if it works
Sep 21, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Tumble dryer not drying
Either dryer element has failed, thermostat for drying or the drying condenser fan not working.
There are two heating elements and the top one is for drying.
Apr 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Dryer - acquaviva 1300 - how it works?
the dryer has 2 thermostats if these are blown then the heater wont work but you can check to see if the element is burned out by unplugging your machine opening the top off it the wires that plug into the element replace with a plugged wire with bare wires on the end place each wire into the correct connector and turn the plug on this will either heat the element up or if it doesnt then the element is blown m8
Aug 21, 2007 | Candy AQW130 Front Load Washer / Dryer
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
