Question about Belling BE808 Compact Refrigerator
How do I fit a Door seal to a belling BE808 fridge.
  • Peter Hill
    Peter Hill Oct 12, 2013
    I have looked at the fridge door and the seal appears to be moulded into the door stucture. doesb this mean the seal has to cut from the door and the new seal stuck to the door ? if so what adhesive should I ue.
2 Suggested Answers
AndrexT
  • 19065 Answers
SOURCE: i need a belling freezer door seal model be810 I can't seem to find one anywhere got told it may of been discontinued if so what can I do ? Is there another seal that would fit this ?
This is the only place I find them listed. Ask if stock is expected?
Otherwise, you could probably fix a split door seal with silicone.
http://www.spares4appliances.co.uk/fridge-freezer-spares-c11/various-refrigeration-parts-c1261/belling-fridge-freezer-door-seal-gasket-p161780
Posted on Jul 05, 2015
My fridge/freezer is frosting cos the rubbers shot x local repairman says he will not fix as "it never works"x can I replace them myself? difficult? x leroy
most places have a " seal-a fridge " type business that comes to your place and makes and fits door seals to fridges and freezers
check in the trade pages of the phone directory or go google and type in--- fridge door seals and repairs -- to see if there is a business close to you
the only problem that you may have is , if the door and seal edge area is badly rusted
if you can get a seal from a service agent spares and you have some ability you may be able to fit the new seal your self
Nov 22, 2016 | Refrigerators
How do i replace the door seal
First of all you need to buy a new seal. Once you have done that remove the door from the refrigerator. Lay it flat (inside up) on a soft item (like a carpet, blanket etc) to prevent scratching the door.
Next - gently pull away the old seal. Start from where the damage is and remove all the way round. Then thoroughly clean the area being careful to remove all traces of the old seal glue. Alow the area to dry completely.
Modern seals come with a pull back tab that removes the outer paper from the seal. A little like double sided sticky tape. DO NOT REMOVE THE WHOLE PAPER COVER IN ONE. Pull away a small section (either top or bottom) and gently line it into place. Gently line it up and when you are satisfied that it is lined up use a small amount of force to keep it in place. Do the same around the three remaining sides and when completed use a soft cloth and rub gently around the seal to fix it firmly in place.
When done, reaffix the door exactly as removed. Once on close door and gently press all the way around to complete the seal. Hope this helps and happy sealing.
May 24, 2014 | Belling BE808 Compact Refrigerator
Looking for a rubber to fit around the door of the fridge , do you know where in australia they can be bought . thanks . julie herring
Here is a link to an Australian supplier of Hoover fridge door seals:
http://www.doorseal.com.au/fridge-seals/hoover
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
Not sure if you can pick it up locally yourself, but you can certainly order one online and have it delivered. Just look for your specific model number at the above website.
Good luck.
Mar 21, 2011 | Hoover Refrigerators
My Miele freezer the alarm bell is bleeping but it is not defrosting what could be the problem please.
The beeping could be a low temperature warning. Check to make sure the temperature is staying cold enough and then check the door seal. Use a store bot fridge/freezer thermometer. Use a dollar bill to check seal. If you close door on the bill it should hold the bill tight but still let you pull it out. If it is loose then you need to adjust the door to fit tighter.
Sep 21, 2010 | Miele Freezers
New refrig deliverd today told not to turn on for 2 hrs to let gas settle as it reduces the lifespan. true or false.?
False . If it was delivered laying on its' side , back , or front , 24 hrs is necessary . If delivered standing up , no need to wait .
Nov 13, 2009 | Belling BE808 Compact Refrigerator
How to fit a Zanussi fridge door seal
You mean you have a door gasket. A good, step-by-step article on this pesky concept of "panel-screw" gasket installation is found on this handy page:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Appliance_Zone_Refrigerator_Install_A_Refrigerator_Door_Gasket.htm
This should help!
Brad
May 21, 2009 | Refrigerators
Tenant says fridge is not cold enough and that food has gone off
I would check to see if the heater is working? It would behind the plastic back wall of the freezer. if its all frozen up and ice all over, get a hair dryer and melt ice and get a new heating element. cost is about 50 dollars
Dec 06, 2008 | Belling BE808 Compact Refrigerator
Fitting an integrated fridge freezer!
Hi Gareth. I fitted a door to my Hotpoint hsz2321L today. I used self tapping screws through the brackets into the fridge door sides. Looking at the old fridge that came out showed that this was the method used previously. No seal is broken and so the fridge is working perfectly. I do have an issue re-fitting the door onto the new fridge though. The pivot hinge on my fridge doesnt give enough clearance and so it catches on the unit at the side of it. The old fridge (a Bosch) cad cabinet hinges that would sort of concertina out to give clearence. Anyway, good luck.
Nov 23, 2008 | GE Profile GCG1700LII 15" Built-In Trash...
Belling BE808 Compact Refrigerator Logo
79 people viewed this question
Top Belling Refrigerators Experts
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
Bill Boyd
Are you a Belling Refrigerator Expert? Answer questions, earn points and help others
