Question about Samsung Clp-365w WiFi Color Laser Printer 19 ppm Black 4 ppm Color 240
Samsung clp-365w, 2 problems. Firstly the paper often does not feed from the tray when printing. Have already tried cleaning the rubber roller but that didn't seem to work. Secondly I can't seem to set up to print wirelessly from my laptop, I have to use the usb cable. Can anyone help please?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 63 Answers
Hi, does the roller turn feeding? Wireless, please download Easy Wireless Setup from Samsung Website.
Posted on Oct 18, 2013
  • Luis Hurtado
    Luis Hurtado Sep 12, 2015
    Hi Lawrence, I have same problem, the roller turn is not feeding, the printer start to work, but this mechanism (pick UP roller) dont start. Some idea?
  • 5 Answers
SOURCE: Samsung CLP-300 Paper Feed Problem
I had same problem and it got resolved by lifting the front portion of the paper tray up. I put a spare USB drive under the paper tray for sufficient push upwards. It seems to be working fine now for me.
Posted on Dec 25, 2008
CompuFirm
  • 89 Answers
SOURCE: Samsung CLP-315 prints half a page and then stops
It sounds like your fuser is causing the jame,.
when you remove the paper can you wipe the toner off the page or does it adhear to the paper ?
If it does not the fuser is causing the jam, if the toner does not wipe off the paper then the feed tires would be the cause of your jam
The fuser is at the back of the printer and will be very hot, so be careful.
Posted on May 26, 2009
  • 1126 Answers
SOURCE: MP Tray Paper Empty
"MP" tray is refering to the top fold down tray on the front of printer (bypass tray) You might load paper in the bypass and see what it does?
Posted on Aug 18, 2009
  • 13 Answers
SOURCE: Samsung clp 300 paper jams after feeding about
Lift Machine up 4 inches at the front with a thick book.
Paper will now run downhill slightly,
Richard
Posted on Oct 29, 2009
tim30921
  • 6 Answers
SOURCE: Samsung CLP-300 click print and it starts to try
clean the rubber roller that pulls the paper from the tray with alcohol
Posted on Jan 10, 2010
Samsung CLP-300 printer not printing, the paper tray will not pick up the paper.
Often the rubber pickup roller is either worn or dirty. It is located just above the paper tray. Use a damp cloth and try to cleaning it, sometimes that helps. Otherwise you will need to replace the roller.
Jun 16, 2011 | Samsung CLP 300 Laser Printer
MY SAMSUNG PRINTER CLP300 IS NOT LOADING THE PAPER AT THE TIME TO PRINT HOW CAN I RESOLVE THE PROBLEM?
Remove the paper tray. Lift the printer and you have to see paper feed roller it is rubber, just clean of dirt with cloth and alcohol or water.
Feb 13, 2011 | Samsung CLP 300 Laser Printer
Samsung clp 300 starts to feed paper but stops feeding (jams?) midway
This is a common problem with both this and the Xerox phaser 6110 (a rebadged Samsung)
It is due to the pickup roller "tyre" that is the rubber roller that pulls the paper from the tray.
It gets shiny and slips on the paper.
The cure is to "rough up" the roller with some sand paper or emery cloth.
The best way is to remove the imager unit and store it in a cupboard or a box IN THE DARK.
This stops toner getting everywhere.
Remove the paper tray turn the printer on its side you will see the roller underneath, using some sand paper or similar carefully rough up the rubber roller all round.
now put the machine back together and try printing it should be ok, if the problem persists try repeating the process.
Jan 05, 2011 | Samsung CLP 300 Laser Printer
The paper is not feeding into the printer. I think there is a problem with the rollers.
If the paper does not make it out of the paper tray, this will be a pickup roller issue. This is the roller that initally feeds the paper up into the paper path. This can be replaced, but you may nee a tech to do it. It can also be cleaned. Turn off the printer, remove the paper tray, and look inside. The roller will be about 2 inches wide and is probably a grey color. Using distilled water only on a qtip, clean the roller, changing the qtip frequently. Allow to dry completely, or wipe gently dry with a lint free cloth. Reinstall the paper tray and try printing again. If this does not resolve the issue, contact a tech for replacement. Should probably cost about $50 total, including part.
Sep 30, 2010 | Samsung CLP 300 Laser Printer
Not picking up paper
Most new printers and copiers will attempt to feed paper several times before failing and giving a jam condition. It sounds like that is what is happening to your printer.
Your tray rollers may be dirty. Remove the tray and use a clean cloth with mild detergent to clean the rubber rollers. Do not use alcohol this will dry the rollers out. If problem continues replace the tray rollers.
May 18, 2010 | Samsung CLP 300 Laser Printer
Samsung clp 300 won't pull paper out of paper tray, after several reloads, printer runs for 1 min, then shuts down (red status light), all rollers are clean, a jam did not start this problem it just quit...
I understand the rollers are clean but are they viable to pick up single sheets. I dont think it can due to no matenance to the rubber on the rollers themselves.
Go to fixyourownprinter.com and purchase the "rejuvination roller" jar. With this product, you must use a qtip and dip some of the solution on it. Then rub down all rubber rollers and let it sit dry for about 14 minutes. After that, you can do a test and you will see that the rollers gained their feel to print single sheets again or pull out paper again
Mar 05, 2010 | Samsung CLP 300 Laser Printer
Samsung CLP-300 paper feed
Clean the feed roller.
Remove the paper tray, from the bottom there is a grey rubber semi wheel in the middle front of where the paper tray would be. Use a cloth with WD-40, brake cleaner, or lighter fluid to lightly wipe the rubber clean. Put the paper tray back in and it should print.
Jan 24, 2009 | Samsung CLP 300 Laser Printer
Dec 18, 2008 | Samsung CLP 300 Laser Printer
I have a Samsung CLP-600N. When I try to print I get a Paper Jam Tray 1. There is no paper jam. The paper is not feeding. I tried to hold up the Sensor arm and tried to print again. The feed does not...
hmcoul,
In my experience, very rearly is the sensor bad, the sensor is a simple optical sensor activated by a flag. All this sensor does is indicate if there is paper in the tray or not. The most likely problem is that your paper feed roller,(the rubber roller at the back of the printer in the paper tray area) is embedded with paper dust as is very comon on these units. try getting some water or even better still some eucalyptus oil and clean the roller. try to print again and see waht happens.
Gremlin11
Dec 11, 2008 | Samsung CLP-600N Laser Printer
Samsung Clp-365w WiFi Color Laser Printer 19 ppm Black 4 ppm Color 240 Logo
501 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
