Question about Xerox Phaser 7400/N Printer
Xerox phaser 7400 printer color shift - colors shift from dark to lighter from front part of page to back. mulitple parts already replaced including imaging units and transfer belt.
    New Friend:
  • 63 Answers
Have you cleaned the LED's?
Posted on Oct 11, 2013
Testimonial: "Yes, LED's have been cleaned and also swapped between colors to see if anything changed and it didn't."
4 Suggested Answers
  • 208 Answers
SOURCE: Tranfer Unit
  1. Open the Top Cover on the printer.
    CAUTION: Do not leave the Top Cover open for more than 10 minutes without covering the Imaging Units as damage could result. Use the dark bag that came with the Imaging Unit or opaque paper as a cover.
  2. Remove all four Imaging Units (which includes removing the Toner (Dry Ink) Cartridges attached to the Imaging Units). To avoid Toner spills, hold the Imaging Unit in an upright position.
    CAUTION: Do not use warm water or cleaning solvents to remove Toner (Dry Ink) from your skin or clothing. This will set the Toner and make it difficult to remove. If any Toner gets on your skin or clothing, use a brush to remove the Toner, blow it off, or wash it off with cold water and mild soap. Do not attempt to use a standard shop vacuum or home vacuum to clean Toner spills in or near the machine. Shop and home vacuums are not equipped with correct filtration and will contaminate your environment.
  3. Raise the two gold colored latches (front and rear of printer) to unlock the Transfer Unit.
  4. Grasp both gold colored handles (center and right) to lift the Transfer Unit out of printer.
To install a new Transfer Unit:
  1. Remove the new Transfer Unit from its packaging or shipping materials.
  2. Grasp the two handles on the new Transfer Unit and place the left end into the frame alignment sockets.
  3. Lower the right end of the Transfer Unit down until it lays flat in the printer.
  4. Press down on both latches to secure the Transfer Unit into position.
  5. Make sure the Transfer Unit is latched into position. Lift up on the right handle to see if the Transfer Unit lifts up. If the unit does not lift it is latched correctly.
  6. Re-install the Imaging Units and Toner (Dry Ink) Cartridges.
  7. Lower the Top Cover.
  8. Dispose of the old Transfer Unit as normal office
Posted on Dec 04, 2007
  • 2072 Answers
SOURCE: Xerox Phaser 7760 Prints White Lines Diagonally Across Page
That is normally caused by a bad developer housing.
Posted on Jul 16, 2009
Semi-Driver
  • 434 Answers
SOURCE: Xerox Phaser 7300 color misregistration
Apparently, turning the unit off for 30 seconds, then back on will force the Phaser 7300 to do a color alignment procedure (according to Xerox support).
Then, if the problem persists, you are instructed to follow a very detailed troubleshooting procedure which I will leave with you in the following link:
Xerox Phaser 7300 Misregistration Issues
I hope this helps!
Posted on Mar 15, 2010
Why is my Phaser 7400 printing a solid pink page? The Transfer unit is half pink. Is this why?
This may be a high voltage problem.
Am not familiar with this machine but is a generic fault.
Ensure contacts to drum/cartridge are clean.
Next
If possible, unplug machine, open up and ensure all high voltage connections are good.
Good luck.
Jul 24, 2015 | Xerox Phaser 7400/DXF Laser Printer
I have a phaser 7400dx and the color alignment is off, I've heared people talk about that it is set in the main board and can be fixed. I was wondering how it is fixed?
Below is the link to 7400 documentation, the user guide on this page provides good info on color and image misregistration problems and some potential fixes ...
http://www.support.xerox.com/support/phaser-7400/documentation/enus.html
Alos, if it is a problem wioth your main PWB you may want to contact your Xerox service technician for assistance ......
I hope this helps.
Mar 09, 2015 | Xerox Phaser 7400/DX Laser Printer
Xerox phaser 7400 giving error - replace imaging unit- what solution now?
Did it specify a color you should replace? The machine has 4 image units (CMYK) each with a different part#. Replacing them is easy, no tools required. Open the top door, lift out the entire image unit, move the toner over to the new unit, and lower the image unit. Here are the part #'s for the 7400 for each color. Iteminc.com has these online.
C - 108R00647
M - 108R00648
Y - 108R00649
K - 108R00650
Good luck, hope this helps. Thanks for using FixYa!
Aug 05, 2011 | Xerox Phaser 6350/YDT Laser Printer
Printing
The Phaser 7400 starts at $2,799. see models and prices see cost per print Color: up to 36 ppm Black: up to 40 ppm First-page-out time as fast as 12 seconds 800 MHz PowerPC processor Maximum paper size: 12" x 18" All models come standard with 10/100Base-TX Ethernet connectivity Standard paper input capacity: 800 sheets Maximum paper input capacity: 3,000 sheets Finisher/stacker/stapler/hole puncher capable of handling up to 1,000 sheets Maximum duty cycle up to 150,000 pages per month What comes in the box show/hide contents Color toner cartridges (capacity: 9,000 pages each 1 ) Black toner cartridge (capacity: 15,000 pages 1 ) Imaging units (capacity: 30,000 pages per color 2 ) Waste cartridge (capacity: 30,000 pages 2 ) Fuser (capacity: 100,000 pages 2 ) Transfer unit (capacity: 100,000 pages 2 ) Finisher ships with 5,000 staples Power cord Software and documentation.
Aug 13, 2009 | Xerox Phaser 7400/N Printer
Faint horizontal dark line about 2 1/8 inches down from the top
You can easily fix this yourself, one of the quickest ways to fix it is to print 10 doublesided blank pages and it will clean the inside of the machine for you and the line will vanish.
For further print quality problems on this machine follow these instructions to troubleshoot.
When troubleshooting image quality problems, it is important to understand the situations in which the problem occurs.
Print a copy of the color test pages to determine whether the problem is in one color or more than one color.
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Color Test Pages], and then press the [OK] button to print the test pages. If the problem occurs with one color on the test pages, perform the solutions for this problem. If the problem occurs in more than one color on the test pages, restart your search and select a case for the image quality problem occurring through all colors.
Mar 27, 2009 | Xerox Phaser 7400/DXF Laser Printer
Fan Failure Error 54
1 of 2 things.
You need to clean or replace the fan.
You have to remove the back, right side and top cover to access that fan.It is near the back just behind the fuser module.
It could also be the low voltage power supply fan. Most likely the fuser fan.
Once you remove the fan, there is a label on it, remove the label, There is a rubber plug behind the label, remove the plug and drip some lubricant into the fan. Reassembly and it should be ok.
I would recommend replacing the defective fan though.
Here is a very reliable part source.
https://www.partsdrop.com/store/
If you call ask for Britt and specify the model number and that you need a fuser fan and probably order a Power supply fan, Neither are very expensive.
Have both on hand to be 100 percent sure the problem is resolved, But its a 90 percent fuser fan failure code. It operated in a heated area and can dry out faster.
Mar 27, 2008 | Xerox Phaser 7700 Laser Printer
Xerox Phaser 8500N front control panel LCD died
Want to resolve your printer issues online then, dial Xerox Printer Support Phone Number1866-877-0191 anytime as you like. For further Info Click:https://goo.gl/Co2Bom
Nov 26, 2007 | Tektronix Phaser 860DP Thermal Printer
Xerox Phaser 8400
There is a flag sensor on the registration assembly that is possibly broken.
Sep 07, 2007 | Xerox Phaser 8500/DN Printer
Xerox Phaser 7400/N Printer Logo
85 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
