Question about Garden
My mahindra mkm tractor 3yrs old during 1st nd reverse gear ther is a sound, so wts d reason?
    Genius:
  • Garden Master
  • 2,096 Answers
-Too much clearance.
Mai Lor
Posted on Oct 10, 2013
SOURCE: automatic transmission sounds like it stuck in 3rd gear
You need to check the transmission fluid level, if it is low the tranny will not shift. If, however, the fluid is to the proper level then you will need a new transmission.
Try putting new fluid in and look for a leak in the pan gasket, then all you may need is a transmission service. When the service is done the mechanic will look for pieces of metal in the old fluid, if found this is very bad and you will need a new tranny.
You might consider a new or used car, you can definately find a good deal out there!
Posted on Nov 16, 2008
  • 2920 Answers
SOURCE: No 2nd, 3rd or overdrive. reverse and 1st ok
your transmission is out..you need to take it to a shop and ave it repaired or replaced
Posted on Jan 02, 2009
  • 186 Answers
SOURCE: sudden noise, whining in 1st gear, reverse jerky
Sounds like your final drive pin in your differential broke causing the main spider pin to tear through the case.Catastropic damage.Check for severe fluid leak under car.If no signs of leaks,check dipstick for greyish blk colored fluid.If this is the case you will need to replace transaxle & flush trans cooler.hope this helps
Posted on May 22, 2009
  • 850 Answers
SOURCE: When you put it 1st gear or reverse it pops out of
check the shift linkage as it may be loose or just need adjustment
or it could be worn selector in the gearbox
Posted on Jul 20, 2009
  • 142 Answers
SOURCE: No reverse and 1st gear only on a 98 chevy work truck 1500
sound like its time for a new tranny, reverse goes first and the 2nd gear
Posted on Sep 22, 2009
Testimonial: "Thanks for the advice.I was just confirming what i already thought."
Need to adjust my clutch on my Mahindra 3510 tractor. When I put it in reverse it keeps kicking out of gear.
That is not a clutch problem it is a selector problem in the gearbox you need to check the reverse selector dogs and fork
Apr 25, 2017 | Mahindra Cars & Trucks
I have a 20 hp mahindra tractor with front end loader the problem I am having is it will not go up a slight hill in forward or reverse what can I do thank you
If it is a hydro or automatic it sounds like you need to check fluid levels, if manual trans you may need a clutch or clutch adjust
Dec 12, 2016 | Garden
1st Gear, Reverse and one tire not spinning
bad motor, let me know if you need me to order you a new one
Apr 10, 2012 | Peg Perego John Deere Farm Tractor and...
Will not go into gear
a hydro uses a foot pedal on the right side , you push forward to go forward or rock the pedal rearward to go in reverse - a regular transmission has a shifter usually between your legs for reverse 1st 2nd or 3rd gear - you also said the blades wont engage . are they electric ( with a switch ) or do you manually move a lever .
Oct 23, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Bmw e46 steptronic box, up to 1 minute delay in taking up foward drive in the morning from cold. perfect in reverse, fine for the rest of the day.
How old is the gearbox oil? In some cases, older oil (higher viscosity when old) will be too "thick" in colder weather and inhibit the synchro on your gears from slipping into 1st gear. The reason it only happens in 1st, is 'cause the shifting mechanism on the forward change is finer than that of the reverse change.
POSSIBLE Solution: Replace the gearbox oil with a lower viscosity ie. "thinner" oil.
Oct 04, 2008 | BMW 330 Cars & Trucks
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
