Question about Denon AVR 2808Ci Receiver
I connected, mistakenly , my denon 2808ci to a 240 volts power outlet i opend the top lid of he receiver and checked everything . liek fuses etc. everything i sok. but the switches not powerin up and system is dead. i got a burning smell for few seconds but now gone. please let me know where to check and hwat might have gone bad. thanks
  • 3 more comments
  • sudarshanarao
    sudarshanarao Oct 11, 2013
    hi i researched further, here are the points i could make out.kindly help diagnose the issue.
  • sudarshanarao
    1) the power connections from th e power board( first inlet board) are tested when the two wires that go to transformer are taken out, positive and negative are showing correctly, that is tester is glowing at only one fo the two nodes. but when i connect the wies( ble socket) then both ends are gloing. i guess this is short ciruit in the tranformer?
  • sudarshanarao
  • sudarshanarao
    2) when the power switch on the receiver is pressed in, the circuit at the power switch end shows no lights glowing in the tester. but when it is switched off( prssed out) it is not showing any lights in the tester.Is this siwtch board/switch gone?
  • sudarshanarao
    sudarshanarao Oct 12, 2013
    more clarification: There is a board to where the main power inlet is connected. out of which there are two outlets. BLUE and RED plastic power plugs, each with one negative an done positive poles. th BLUE one goes to POWER SWITCH at the front and the RED one is going to transformer( from which the voltage is being reduced to different level and will be sent to different circuit boards) Now when i PRESS the POWER SWITCH "IN", and put the tester at the firts node of blue plug, it Glows. Now i put the tester at the second node of the same Plug, it is not glowing. and then i put the tester at the other end of theBLUE PLUG wires( at the switch)NOTHING GLOWS. and now I PRESS TEH SWITCH "OUT" ( usually this should be OFF position), the Nodes at the switch BOTH are Glowing. and also the Nodes (both) at the other end( near the circuit board ) are glowing. I think this is a short circuit? if its short circuit it should give a blown out sounds and sparkseverytime i connect it to power right? but it is not. teh SYTEM is DEAD silent, no light glowing , neither any display nor any smell now. I knwo its an OLD 2008 receiver. but it never gave me any problem what so ever an di feel really bad to bring it to this stage due to my negligence. I shouldnt have connected it to a 220 Volts supply when itjust needs 110 volts. BUT again iam really surprised that DENON didnt have this basic protection mechanism of blowing out fuses it the voltage goes to more than 110 volts etc. Now coming to the point of fuses. I checked physically every Fuse . I could see two ear main power cirsuite board, 4 below this board and 2+2 on th eother boards. I see no fuse on the font display panel circuit. I only opened th etop lifd an di see only these fuses. I didnt check them elctrically, but physical examination showed all fuses intact. KINDLY HELP. Thank you
  • 163 Answers
First you need to check standby power supply- i think the small transformer is gone as well as some surrounding components.
Posted on Oct 16, 2013
Testimonial: "Thanks for the reply paul...the vertical circuit board is obtaining power from main power socket, then one set of wires from it goto switch and another set of wires goto big transformer. i guess proble is here only. how can small transformers o wrong when current is not yet into them? pardon my ignorance but i am not very knowledgeable in circuits. thanks"
  • 2 more comments
  • sudarshanarao
    sudarshanarao Oct 26, 2013
    Paul, Today i took it to a repairer( Denon people refuse to do a repair as they say costs will be expensive and tis a waste of time to repair it. They advised me to throw it and buy a new one. Well i dont own a Denon to do that kind of thing...so i took it to a local experience person. HE checked an dfound exactly what you said...he confirmed main transformer was working. and that the snadby or control circuit( small transformer) might be gone. H edoesnt have a circuit diagram to check( he is a old timer and so not conversant with iinternet etc) . Could you please let me know where i can download a service manual to get the snandby/control circuit diagram of denon 2808 Ci? THANK YOU SOMUCH
  • sudarshanarao
    sudarshanarao Oct 27, 2013
    thanks Purchased it from SR manuals. Need to check how am i goign to get parts if any part is to be replaced. I just saw int he manual that there mentioned a reset sequence. is this going to help if i press the buttons as mentioned? or if the power circuit is gone, this is nto goign to help? the two clicks that come after the set is on are nto there....
  • EBC ELECTRONICS Oct 29, 2013
    if the standby transformer is dead you can not reset the unit. You need to restore standby circuit- check power transformer for continuity, check standby power supply diodes and regulators. there should be ac after power transformer and dc after bridge diodes. there is also small electronics fuse wich usually get bad and you can temporary short it. what do yo mean when you say that the meter glows? you need multimeter to repair this not an electritian tester. thanks.
  • sudarshanarao
    sudarshanarao Nov 09, 2013
    Thanks Paul, The technician noticed that the standby power transformer is gone. I ordered one from DENON USA. It will be shipped o a local address ( friend) and he will be shipping it to me. Will let you know once this is fixed. thank you somuch for the kind help.
When connected to Denon 2808ci receiver i get humming noise.Since there is no ground wire to connect,how do get rid of the hum?
Sometimes the earth lead in the power cord can be the cause, either connect or disconnect it. Also check the earth connections on the cartridge.
Oct 13, 2013 | Stanton T.92 USB Turntable
I mistakenly gave 220volts to my DENON 2808CI. There was a burning smell and denon is no powering up. What must have burned? i opend th etop lid and checked eveyrthing is fine except th epower transformer...
fuses only fail from excessive current and not wrong voltage
take it in for a proper diagnosis but with twice the required voltage , the results will be --junk it and next time used the correct adaptor for the voltage
May 25, 2017 | Denon AVR 2808Ci Receiver
How to change fuses on denon 2808ci played it loud
Sorry to read about your problem, I hope this helps you out.
you will need to take off the covers, and replace the pop out fuse's
Look around, where the power wires come in.. they look like clear class with metal on each end or white cerramic..
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Denon AVR 2808Ci Receiver
I have a denon avr amp it powers up then goes in
disconnect all connections cycle power if the power stays on reconnect equipment one at a time cycling power after each peice reconnected. If the power goes back to stand by with nothing connected the reciever needs repair
Jul 18, 2009 | Denon AVR 2808Ci Receiver
When I turn on my receiver, it automatically turns off and the power button flashes red. Prior to shut down, the receiver display notes "Tuner Ext. In" What's the problem? It has worked p
Protection circuit turns off the unit because of critical conditions- wrong power supply voltages or one of the power amplifier channels is bad. First, visual inspect the power amp board near the heat sink for burned resistors, test outputs for a short. If there are no problem you may try to turn the unit on and you have several second before it shuts down to check power supply voltages and power amp output voltages and bias, then ... Long story you'd better take it to a repair shop or repair at ebcelectronics.com
May 09, 2009 | Denon AVR 2808Ci Receiver
Subwoofer Connection Problem
why don't you both return these units and call Denon for replacements without these problems?  Sqeaky hinges get the oil.
Nov 12, 2008 | Denon AVR 2808Ci Receiver
Only 1 of the power outlets on a Denon UTP-250 is live so the CD player and the power amp do not power up. I ma trying to get cover off and removed 4 screws - it seems stuck. i am looking for internal...
There are 6 screws, 4 at the side and to at the rear panel. After removing theses screws you can take of the lid.
Next to the transformator there are two glass fuses. The 500mA fuse is obviously broken, so just replace it and the power is bach up.
Tom
Oct 20, 2008 | Denon Audio Players & Recorders
Help required for dumbo on Amps Denon AVR 2808CI
Your unit was probably damaged in shipping. Denon is a nice unit! Do you hear any clicks when you hit the power button??? You should hear two relay clicks. You should hear the power relay click at power on and 3 to 5 seconds later you should hear the speaker protection relay click if your audio amp section is ok. If you hear both relays click then your display circuit is at fault. Open the unit and look for breaks on the front pcb (behind the display) and on the main board in the power section ( where the fuses are ).
Good Luck!
barneyluc
Oct 10, 2008 | Denon AVR 2808Ci Receiver
Can Denon AVR-1403 take 250 volts AC power?
no it will be damged need hi end monster power strip hd700 or better off ebay that will go 1st and alarm will sound on it
Jan 10, 2008 | Denon AVR-1403 Receiver
Denon AVR 2808Ci Receiver Logo
108 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
