Question about Kenmore Refrigerators
The outside middle front & left hand side of the fridge were hot
Middle front by the door and left hand side of the fridge both on outside were hot and not making ice?
    Guru:
  • 1,524 Answers
The reason you feel heat by the middle of the door is because of the "mullion heater' or anti-sweat.
Check the temperature of the freezer, must be below 12*F for the ice maker to work.
Posted on Apr 23, 2009
The strip down the middle between the the fidge and freezer doors is getting hot. So hot that it burns when you touch it. The sides of the fridge are also getting pretty not. I have just bought the fridge...
I have exactly the same problem with my Westinghouse side by side! And it only happens when it's hot in the house. Would love to hear what's wrong. And the fridge is 5 years old. Bought new.
Jan 12, 2011 | Westinghouse Refrigerators
My side by side fridge door does not close by itself when released
It is likely that your fridge is tilted left or right, and possibly forward at the same time. Most refrigerator doors will self-close if the fridge is slightly tilted both back and to the handle. The fridge is raised or lowered by adjusting the front feet or rollers.
The problem you'll encounter with a side-by-side fridge is that if you adjust for the right-hand door to self-close, there's a good chance that the left-hand door will want to stay or fully open; if you don't check it while making the adjustments. It can take a little extra time to make sure the adjustments make the front both perfectly level left to right, AND slightly higher in the front than the back.
Please rate this reply if you found it helpful - good luck!
Aug 03, 2010 | Refrigerators
The frame where the doors close onto is hot to the
Hi Mr Hodjati,
No this is not normal. You have a failure of air flow in your condenser. I will explain how to repair if you wish to make the repair youself. If this is not addressed you will soon realize a reduction in cooling and a higher use of energy.
There is a fan that pulls air in from the lower right side front of the refrigerator grille located below the fresh food door, and exhausts the air on the left side of this same grille. Remove this grill and clean the coils with a vacume cleaner and a brush. Pull the refrigerator out so you can get behind the unit. Unplug the power cord from the wall. Next remove the screws from the panel behind the refrigerator near the bottom, the panel may look like a piece of cardboard, but it is a critical component. Once this panel is removed you will see the fan motor and fan blade, make sure nothing like a food wrapper or animal is stuck in the fan causing it to be stuck. If it turns free by hand (it will be real hot down there so be careful), then the motor needs replaced. If you send me the model number I can find you the replacement part number. Let me know if this helps.
Apr 18, 2010 | KitchenAid Architect 24.5 Cu. Ft....
Front metal , top heating element very hot
This should be OK. There are heat strips placed behind the door frame to prevent sweating around the door frame due to the metal being cold normally without the strips. Thanks, Sea Breeze
Jul 21, 2009 | Refrigerators
Maytag side by side fridge...water dispenser problem
If the water is visible in the front, more than likely the hose has become disconnected from the door, if you look at the lower left hand corner you should see the hose come from underneath the machine and attach to the door via a plastic quick connect, it is just a push lock connection. You may have to pull of the toe kick and the left hand end cap depending on the model to see this.
Jun 15, 2009 | Maytag MFI2568AE Side by Side French Door...
Overheating, seals on Roper side by side are hot to the touch
Hi, When that strip gets hot, it is a sign the temperatures are not cold enough. Put a thermomitor in the freezer. You should get a reading of 0 to 5 above. If not, let me know and we can try and get you through this.
Thanks
Vic
May 15, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Kenmore elite side by side: hot divider
This is normal. There is a heater in this panel to stop condensation sweating between the doors.
Feb 23, 2009 | Kenmore Refrigerators
Front between doors is VERY HOT
Had the same problem. I opened the "meat" lever controlling the "hole" between the freezer and fridge compartments (mine is next to the crisper trays at bottom) and put my finger in it to clear any blockage. It's been 24 hours and the center post is no longer hot. Think maybe I had a blockage or the hole was closed off and whatever is in that middle wall needs the cold air flow for cooling. If you discover some other remedy, please let me know.
Dec 29, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
232 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
