Question about Philips 42FD9932 42 in. Plasma Television
Colour saturation pixels - Philips 42FD9932 42 in. Plasma Television
    Top Expert:
  • Philips Master
  • 74,383 Answers
This fault to plasma display can occur to many reasons. If you wish to get more details, check this link. It has illustrations to defective screen display to plasma screens, and possible reasons. If you're sound in electronics, you can follow.http://electronicshelponline.blogspot.com/
Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Posted on Oct 10, 2013
Pl advise how to get a dark print. We use a higher pixel but get line marks in the bar code
Line marks are nothing to do with colour saturation, lightness or darkness. They are indicative of dirty or clogged inkjet heads in an inkjet printer or depleted or clumpy toner in a laser machine.
Run a test page and check. If that shows banding, report back. Also let us know the make and model of the printer
Oct 10, 2015 | Office Equipment & Supplies
Accoustics solutions 37 inch tv colour fading and changing
Increase the color saturation to fight the fading and decrease brightness slightly. All of these settings are in the menu of the TV.
Jun 07, 2012 | Televison & Video
I have a problem with the picture on my Infocus IN1501. It has small squares on it and I see every pixel. How do I remove this?
Generally the screen is full of pixels, and thats a good thing.
It's a problem when you see the pixels that should be off, and don't see them when they should be visible.
So I presume that your pixel problem may be the first type where they appear when they should be hidden.
Now it would be good to know if the bad pixels are all one colour, or if you have chromatic pixelation problems.
Monochrome pixel problems are better than chromatic pixel problems. But alas all pixel problems come back to the DMD or the colour wheel.
Either way your machine is basically compost material for the garbage shredder, unless you want to pay big money to replace the faulty bits.
Ask the local serviceman or servicewoman to give you a quote to look inside the unit and see where the pixels have gone astray.
Mar 17, 2011 | InFocus IN1501 DLP Projector 3000 Lumens...
The scanner, which used to be fast, now runs extremely slow. It takes about a minute and a half for the Dell AIO Center software to load, nearly 3 minutes to preview, and 2 minutes to scan. So just to scan...
Scanners speed is influenced by the quality chosen in document productions. Selecting impressionful color saturation requires time to produce results. Use the menu buttons on the scanner to select least saturated color pixels.
Feb 02, 2011 | Dell 968w Printer
Very little colour in the photos
Yes, the soft color saturation and soft focus are major shortcomings of the SP800UZ. On previous SP series camera one could adjust both the color saturation and sharpness before taking a photo.
Nov 30, 2010 | Olympus SP800UZ Digital Camera
When i turn on my flatscreen tv the screen comes up pink and crackly
i had same problem.thought the tube or r light had gone.i looked internet & saw it could be 1 of many problems.simplest solution was colour saturation was wrong.i turned saturation down to -14 & hey presto it worked
Jul 26, 2010 | Philips 20 in. TV/VCR/DVD Combo Flat...
Can colours be adjusted manually? Some TV stations vary in colour content. How do I change the colour values?
you might find the colour & saturation levels controls. using your remote to set that up, check the tv manual... if you don't have one, you can likely find one on-line by doing a few searches.
Goog Luck... Ian
Oct 02, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
Copy problems
try to adjust color saturation :
Press Menu/Set, 3, 4.
2 Press ▲ or ▼ to select Red, Green or Blue.
Press Menu/Set.
3 Press ▲ to increase the colour saturation.
—OR—
Press ▼ to decrease the colour saturation.
Press Menu/Set.
4 Return to Step 2 to select the next colour.
—OR—
Press Stop/Exit.
Jun 26, 2008 | Brother MFC 210C All-In-One InkJet Printer
Ultrazoom pixellation problems
No, it isn't to do with white balance. Instead it is due to a combination of noise swamping (or at least modifying significantly) the exposure measured by the pixel, and the interpolation algorithm in the sensor processing chips that "guesses" the colour of a pixel based on the readings from nearby pixels. These algorithms are better at rendering certain kinds of image elements than others. Large areas of darkish colour often fool the algorithms into attempting to produce detail that doesn't exist.
Sep 13, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Philips 42FD9932 42 in. Plasma Television Logo
32 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
