Question about HP 22"LE2201w Widescree LCD Monitor
I have a burned resistor on the Power board of a HP LE2201w Monitor. I need to know what the vaule of that resistor was. It's location is either R316, R616 or R816, It's burned on the board so I can't clearly see it.It is right (left) next TP804. Thank you.
  • Savage_Amusement
    Savage_Amusement Oct 10, 2013
    It is a 2k resistor just in case if anyone ever has this issue. It is also a R816 and should match the R815 resistor.
    New Friend:
    Problem Solver:
  • 6 Answers
Lego
Posted on Oct 10, 2013
2 Suggested Answers
palaboy
  • 5807 Answers
SOURCE: Hello. I have a problem with a resistor in the
R616 = 4.7K OHM
Part Number = 61L0603472
GP. CHIPR
Posted on Aug 02, 2012
Sharp tv model 21v-fx300s no power burn resistor
in most of the case as your description, the burned resistor is located on the power supply board, you may do a trouble shutting to replaced the burned components, or replace the whole board.
Nov 01, 2017 | Sharp Televison & Video
I have a Westinghouse LCM 19v7 monitor that stays on for a few seconds and picture goes off. I know about the capasitor replacement but there is another conponent that I need to replace. It is the pow
That is the correct value. That resistor just gets very hot and discolors the PC board around where it is soldered. You should be able to remove all of the old solder and scrape the resistor leg to get it bright, resolder the leg to the copper pad and you should be good to go.
Oct 09, 2012 | Westinghouse LCM-19v1 Monitor
Should I,change just the resistor that is burned?
Normally if a resistor has burned you will need to locate the cause or a replacement resistor will surely blow instantly in most cases? Is your model the HD52W59 RCA with the ITC222A chassis? If so let me know the resistor board location number such as RP256 etc.
Oct 15, 2011 | RCA HD52W59 HDTV Projection Television
Hello there is problem with my monitor LE2201W... there is lot of vertical and horizonyal lines in all colours mostly blue and dark red,picture is changing constantly,for second is OK after again blured...
There is a large board attached behind the LCD panel, the video enters and is processed on that board and distributed to the display screen, when there is a disruption in the processing it involves the panel that is tied to the main itself. If the video cable is detachable from the monitor and computer you can try to sub it for any change. Problems of this nature usually exceed the price of a new monitor and better just to replace it for a new one.
Jan 28, 2011 | HP 22"LE2201w Widescree LCD Monitor
HP vs19e Flat Panel Monitor. model HSTND-2LO7, product# EN632AA made March 2006. I have no power indication. Checked internal power supply connections and PC mounted fuses. Tested operation with another...
If it's under warranty, then take it back for repair or replacement. If it's not under warranty then plan to buy a new one. Unfortunately, in the modern world, faulty electronics without a warranty on them are becoming increasingly known as "throw away items". This has started to happen with monitors. They call them throw away items because it typically costs just as much or more to have it repaired as it does to replace it with a new one. There are several things that could cause the monitor to go black: Bad inverter, Bad back-lights, Bad throwback (transformer), Bad LCD, & etc. Look for any burned resistors or popped capacitors on the circuit boards also. I've had a few monitors where all I had to do was replace the faulty resistor or capacitor and it worked fine.
Mar 22, 2010 | Computers & Internet
Kds vs-f14
There is usually an identical resistor somewhere else on the circuit board, so if you cannot read the colors of the burnt one, you can read the colors from an identical resistor on the same board. If you just replace the resistor, it will probably just burn out again or damage another component, you have to find the cause of the resistor burning out, most likely an electrolytic capacitor failing. Look for bloated or seeping capacitors and replace those as well. Also look for broken or burnt toroid coils.
Jul 15, 2008 | BenQ FP731 17" LCD Monitor
Burnt resistors
Researching resistors---
What caused the resistors to burn?? Have you already fixed
that? If so, what exactly was it ???   let me know...T.
Oct 18, 2007 | Philips 60PP9352 60" Rear Projection...
Nec multisync 2080 monitor
You don't really need to replace the power supply, you can repair it by replacing the bad capacitors. I've done it to 2 Nec monitors and it works. However I do not believe its you power supply because you are getting the power on light.
Oct 16, 2007 | NEC MultiSync LCD2000 Monitor
HP 22"LE2201w Widescree LCD Monitor Logo
353 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
