MY LG INTELLOWASHER WD1265FD IS FAULTY.WHERE CAN I GET PCB FOR FRONT CONTROL PANEL BOARD
  • 38 Answers
SOURCE: faulty main pcb board , test cycle showing
as the guest above says do not remove the board there is no fault on it 4 sure good luck
Posted on Sep 08, 2007
SOURCE: LG intellowasher (front-loading washing machine) is starting to squeak.
I suggest u buy another washing machine. This one's had it!
Posted on Apr 23, 2008
localwonder
  • 6784 Answers
SOURCE: LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Posted on Jun 21, 2009
SOURCE: My LG Tromm WM2277HB washer shut down during a
Well I for one would go along with your prognosis, it seems logical to me.. this IS a common occurance when this type of thing, a power surge happens.. Remember Occam's razor.
Posted on Feb 05, 2010
  • 343 Answers
SOURCE: main circuit board faulty
SE is 'sensor error' This could be anything from a loose wire to a faulty Hall sensor or even a main board failure......You probably need an LG technician. Your machine sounds like it's worth repairing.. Get quotes.........Good luck...Nomess
Posted on Jun 02, 2010
Testimonial: "thanks so much for your help"
What does a pcb look like i want to make sure i am right
PCB means printed circuit board.All the boards in your TV are PCBs, Please specify which board. example YSus, ZSus, Power Supply. Control board, YDrivers etc
May 17, 2014 | LG 42PC3D 42 in. Plasma Television
Lg intellowasher wd 10160f
Check the Lid Switch Assembly with an Ohm meter for continuity, these switches are a common problem. Replace the switch assembly if faulty.
Mar 18, 2014 | LG Washing Machines
LG dryer DLE 3733S control panel inop but light on in drum. 3 years old intermittent problem, is this electronics panel going bad? if so, do we replace PCB Main or PCB Assembly? Thanks!
Check the power to the display panel after you have it removed. If there is no power check the lines to the control, If the power is present with no action on the panel then you will have to replace the board. It may be as simple as cleaning the board off, since it has been a intermittent problem in the past. hopes this helps Tim
Nov 25, 2010 | LG DLE3733 Electric Dryer
Main circuit board faulty
May 30, 2010 | LG WD-16115FD Front Load Washer
LG front Loader Intellowasher 7kg WD-8015c has been on a quick 30 mins cyle and is still going after 1 hours just keeps spinning and won't turn off
I have the EXACT same problem wit the LG 8015C. After numerous attempts, I finally found the problem. A set of wires attached to the drum body vibrates against th erear panel, wears off the plastic insulation, shorts and blows the circuit board. All because of sloppy workmanship ! It took 4 years of easy work for this to occur. Will NEVER buy an LG or Front Loader again
Sep 18, 2009 | Washing Machines
Hi tv comes on then go to sb no picture if control pcb is disconnecte s/b light stays green volts ok have replaced control pcb z sus was short and have replacecd
I understood that the TV goes on protect mode (standby) when the control pcb is connected.
Please provide details on TV model and details on control pcb. If control pcb is a control board with touch button , look for components shorting with the chassis. If you are talking about digital controller board (big main board) then one of the parts connected to board is faulty.
Aug 25, 2009 | LG Televison & Video
HOW DO i REPLACE THE LARGER RUBBER SEAL ON A lg INTELLOWASHER 7KG WD 8013f . The seal is mildewed
I have this problem and have been told the following.
You have to take 2 Cir clips off. one on the front which is achievable by opening up the spring that holds it in place. The second one is behind the front panel.
You need to take the top off first. Undo two screws on the back top. Then you can take the top off. Then take any detergent tray our and also the front control panel. Then you gain access to some screws which hold the front panel onto the chassis.
After you take the front panel off you can apparently access the rear cir clip and spring.
once this is removed you can remove the front seal for replacement.
Jun 15, 2009 | LG Washing Machines
It doesn't let me choose a cycle - doesn't work
the control pannel faulty needs replace ment. press the cancel/pause button and clean button together to reset the board.check it if gets reset then it will work orther wise replace control board.
Mar 07, 2009 | LG Washing Machines
Washing Machines Logo
Top Washing Machines Experts
