Question about Hammock Source Pawleys Island FGN02 Large Quick Dry Comfort Hammock Courtyard Garden
Is there a way to cover glazed kitchen tiles with plaster and paint?
    Problem Solver:
  • 17 Answers
Yes... First you will need an orbital sanding machine, use 120 grade discs and sand all your glazed tiles, then clean everything down as clean as possible and your ready to paint over, or plaster first.
Posted on Nov 13, 2013
When aplying fresh paint with roller paint is peeling back of with roller
what is the substrate? (plaster, drywall, painted surface.... etc.)
if the surface is painted: can you tell the generic type of paint used before? and what is the condition of the existing paint, is it chalky? did you try to sand it?
if so, you might need to sand it and remove all flaking and chalking paint prior to application of a new coat. you might also need a compatible primer for best results.
Apr 12, 2015 | Tools & Hardware - Others
We bought homestead roof paint identified as terracotta colour. The paint turned out to be a dirty brown. Four coats were required to paint one tile. The paint is so inferior that the rain washes a lot of...
This is a chat room for automotive questions
Your in the wrong section & I doubt anyone
on the internet can help with your dispute with
a contractor or mechant
Aug 28, 2013 | Computers & Internet
I am replacing my sink, medicine cabinet and adding a small cabinet below the sink. I need to know how to remove the old and install the new.
The task you are embarking on is a great DYI project. But, be forewarned, it can get tricky. First, make sure the new sink will fit in the space of the old sink. If not do you have enough space for the new sink to fit securely against the wall? Next, remove the cabinet. There should be about four screws. You may also have to use a razor to cut calking from around the outside of the cabinet. Sometimes it's used to fill-in gaps between the tile and cabinet. Remove the cabinet. If the cabinet is setting in the wall, make sure you check and see where the support beams are located. If you are not putting in another wall cabinet, then you will have to know what kind of wall you have. Sheet rock, no problem. Plaster requires a bit more work. Measure the hole, and then you will need chicken wire, lime, plaster, paint, and matching tile. Fasten the wire to beams in the wall. The wire will hold the plaster in place. Let dry, sand smooth then paint. If you have sheet rock walls measure the hole cut the sheet rock to fit. Fasten it to the beams, use plaster or Spackle to cover the holes from the screws. You will need sheet rock tape to hide the space between the existing wall and the sheet rock patch. Smooth on cover the tape with Spackle, smooth by sanding.
To remove the sink: first, turn off the main water supply. Get a pipe wrench and remove any connections. If you're not familiar with plumbing you may want to get a plumber to attach the connections.
Putting a cabinet under the sink is the easy part. Make sure you have the right size cabinet. Get a leveler; make sure the sink and cabinet are level. Depending on your walls, you can just screw the cabinet to the wall. If they are plaster walls you will need wall anchors. That should do it. Enjoy
Feb 23, 2013 | Plumbing
How do you remove wall tiles
Follow following steps -
1.Decide where to remove the grout
2. Scrape the grout away with a utility knife
3.Try a rotary grinder instead.
4.Remove grout until the spacer lugs are visible.
5.Chisel tiles away from the wall.
6.Break the tile if necessary.
If the tiles are grouted, you will have to clear the grout away first. There are inexpensive tools designed specifically for grout removal. After removing the grout, use a small pry bar or a similar tool to pry the tiles away from the wall. Most likely, though, if the tiles were installed onto drywall, the drywall will be damaged during removal. Fortunately, drywall is relatively easy to replace. Once the drywall surface is ready, new tiles can be attached with tile adhesive or mastic. Regrout and seal the tile around the new tiles. *If the new tiles are natural stone they will be very porous and will need to be sealed and dry BEFORE installation.
Perbaiki lantai teraso Teraso cor di tempat Terazo and mosaic tile
Sep 14, 2010 | YouTube Videos
One tile in the first row up from the tub fell out and the wall behind where the tile came out is soft and not ridged at all to glue the tile back in place the wall is plaster nd lath im letting it dry...
Wetted plaster often dries out like dry sponge cake. When dry try a spray of 25% pva solution. This soaks in and solidifies and stabilizes the plaster.
Whatever you do keep it dry from further water
Dec 01, 2009 | Home
Hammock Source Pawleys Island FGN02 Large Quick Dry Comfort Hammock Courtyard Garden Logo
69 people viewed this question
Top Hammock Source Garden Experts
Dennis Key
Dennis Key
john h
Are you a Hammock Source Garden Expert? Answer questions, earn points and help others
