Question about Husqvarna Garden
My yth 170 cutter is always on, the switch does not disengage cutter. Checked all connections and got a new switch still cutter cannot be turned off until engine is turned off.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
I would venture to guess you have a bad pto clutch
Posted on Oct 20, 2013
Husqvarna yth 170 problems when engage blades clutch nothng happens
On the 170 there is an electrical clutch that enables the blades to engage. This of course is an important safety feature.
If the operator is not sitting in the seat the switch located beneath the seat will not actuate. It is possible that the weight of the operator is insufficient to activate the switch. Other possibilities are the connection to the switch has become disengaged, or the switch has failed.
There are other possibilities of why the blades do not engage but I would evaluate the seat switch first and the relay (operator presence relay) that the seat switch activates second..
Nov 28, 2015 | Husqvarna Garden
Cannot start YTH 170. Turning starter key gives rattle from engine but no apparent spark. Belt plug OK.
Unless you damaged engine this may just be an electrical problem. a starter bendix will "rattle" if there isnt enough power to turn the starter. make sure the battery is charged, tighten battery cables and any larger red wire connections AFTER you temporarily disconect the red or positive battery cable
Jan 11, 2015 | Garden
Paper cutter
You should try replacing the cutter assembly with a new one. They are rather inexpensive ($50) to purchase and easy to install.
The only other thing I can think would cause your problem is if something is stuck in the groove by the cutter guide that would cause it to disengage while cutting.
Jun 07, 2013 | HP DesignJet 500 InkJet Printer
Husqvarna yth 170
What size motor and edge is Husqvarna YTH170? What is the price reasonable?
Mar 27, 2013 | Husqvarna Riding Lawn Mower 42 Inch Cut...
YTH 4228 HUSQVARNA BLADES WONT STAY ENGAGED
could be a safety switch add a light to the plug that goes to the clutch and see if it goes out when the blades shut off this will tell you if its before or after the switches
May 10, 2012 | Garden
Hi, I have a westwood t1500 with B & S engine which starts fine also runs fine with cutter disengaged,when cutter engaged it sends out clouds of white smoke and idles to a halt. Any ideas Regards ...
Sounds like the cutter is not turning free causing the engine to drag down and stop, I do not think the B&S engine is the problem. I have rebuilt dozens of these engines and most of the problems with a Briggs engine was dirt in the gas or carburetor that needed needle valve cleaned . If the cutters turn free, check for a bad or out of adjustment safety kill switch that engages and stops the engine as the cutters are engaged.
Sep 06, 2011 | Garden
Have YTH 150 motor turns not starting.
If I understand, you were mowing and it just stopped running. The motor didn't sieze up, it turns over. Okay and you have spark, and you have gas, have you checked the safety switches. there is one under the seat, the blades, the brake pedal when starting. Make sure that these safety switches are working properly. that is the next step I would take.
Aug 07, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Cutters on Elna 744 serger won't cut
is there lint or thread caught between blades preventing them from meeting?
scott
Jul 26, 2009 | Brother 929D Mechanical Sewing Machine
I have a TM u220 printer. I can't get it to auto cut. Any ideas? Is there a code?
TM 220a and TM 220b should come with auto cutters
You have to unscrew the metal tab under the printer, you will find two sets of DIP switches. upper one is DWS 1 and the lower one is DWS 2. On DWS 2 you need to have jumper #2 ON. this enables or activates the auto cutter on printers. Good luck...
m
Jun 29, 2009 | Epson TM-U220 Matrix Printer
Garden Logo
44 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
