Question about 2001 Audi A4 - Sedan, chassis code B5 - Anti Roll Bars
How to find outputs of a 4 variable input truth table
  • 356 Answers
This link explains in detail how to sovlve your question.
http://www.wisc-online.com/objects/ViewObject.aspx?ID=DIG802
Posted on Oct 19, 2013
A program that will convert the given centimeter to its value in inches
It is just a Hello World program.
Define a real variable to store the input (call it x if you want)
Prompt for input.
Read input and store in variable.
Print to standard output x/2.54 inches
Dec 27, 2013 | Prentice Hall C Programming Language 2nd...
Receiver Not Working Properly with MB-2 CD
I believe your supposition is correct although I think your CD player is unusual if it has variable (audio) output. Most players have only low level output.
Dec 20, 2013 | Nakamichi RE-1 Receiver
Wiring diagram for powerstat type 116
Note this is a variable autotransformer. It is NOT ground isolated.
1 - common for input and output
3 - output (wiper)
4 - 1:1 input
2 - steps up input (max out is 132 vac)
5 - steps up even higher
Don Williams, Palm Bay, FL retired electrical engineer
Sep 07, 2012 | Heating & Cooling
I am working on an independent study. The problem I am trying to tackle is having my CEENBot step though a function that is inputted by the user. However, I am not sure how to input a graph from the user....
A function can be entered into a function as a parameter. For example if you named your function CEENBot you would ask for a parameter in the header like this:
CEENBot()
Func
EndFunc
the parameter can be any type of variable, but it must match the type entered when it is used, so you can't be telling the calculator you entered a function and trying to use rref( on it
To your second question the calculator does generate a table, however it's not really accessible (as far as I know) from a program/function. The table can be viewed by pressing (Diamond)+F5 but it only handles functions that are graphed. You can manually create a table if you want by using the function (for this example y1) with and giving it a list of X values (for this example listx) to output a list of Y values (yep, this one is listy)
y1(listx)->listy
from there you can construct your own table
Aug 05, 2011 | Texas Instruments TI-89 Calculator
Analog Audio Out signal has very high distortion. Signal wanes in and out, wanders from one channel to another, and develops high static. This happens when Audio Out is configured for Fixed Output. When...
The problem is more likely to be with the wireless headphone set rather than the TV. It makes no sense that the signal changes channels. The only difference betweent he fixed and variable output is whether or not the volume changes the output signal amplitude. The channel selection process is not handled there. The distortion is likely due to the input of the wireless being overdriven. If available, turn down the input gain on the wireless and try again. Please update this with the results.
Thanks,
Dan
Feb 28, 2011 | Televison & Video
Can i hook this amp to a 2 channle out put stereo?
Sure. Specs are listed below. I think it's designed for regular 2-channel input, isn't it?
Front Channels: 100 W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
  • Rear Channels: 25 W RMS x 2 @ 1.5 ohm-4 ohm(11V-14.5V)
  • Subwoofer Channel: 250 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
  • THD at Rated Power: <0.03% @ 4 ohm (F&R), <0.05% @ 4 ohm (Sub)
  • S/N Ratio (F&R): >108.5 dB below rated power S/N Ratio (Sub): >95 dB below rated power
  • Frequency Response (front and rear): 5 Hz-30 KHz (+0, -1dB)
  • Frequency Response (sub channel): 5 Hz-500 Hz (+0, -1dB)
  • Damping Factor (front and rear): >200 @ 4 ohm/50 Hz
  • Damping Factor (sub channel): >500 @ 4 ohm/50 Hz
  • Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
  • Differential-Balanced Input Topology: (3 pairs of inputs)
  • Front Crossover: fully-variable (50 Hz-5 KHz), selectable- slope BP or HP (12 or 24 dB per octave)
  • Rear Crossover: fully-variable (50 Hz-5 KHz), selectable- slope HP (12 or 24 dB per octave)
  • Sub Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
  • Preamp Output: 2-channel (full-range or LP)
  • Bass EQ: Variable boost up to 15db
  • Infrasonic Filter: defeatable 24dB/octave at 30 Hz
  • Left minus Right Ambience Circuit: ambient effect for rear channels
  • Front and rear speaker output connections: accept up to 8ga. wire
  • Dual mono subwoofer output connections: accept up to 8ga. wire
  • +12V and Ground connections: accept up to 4ga. Wire
  • Dimensions: 19.7"L x 9.25"W x 2.36"H
  • Dec 02, 2010 | Jl Audio 500/5 Car Audio Amplifier
    Is this a good amp
    I classify this as a sleeper of the car audio industry. it is powerful, well built, cheap, feature laden, sounds great! very comparible to the big names such as kicker, alpine, fosgate an all the rest. i would prefer this amp over any of them any day of the week! here are the specs for it incase u didn't have them.
    • Max. Power Output: 800W x2Ch.= 1600W @2 Ohms
    • Power Output:
      • 330W x 2Ch.(@2 Ohms) Less Than 0.5% THD
      • 220W x 2Ch.(@4 Ohms) Less Than 0.3%THD
      • Bridge: 660W x 1 Ch.(@4 Ohms) Less Than 0.5% THD
    • All Measurements Done @ 14.4V DC, 1 KHz Input Signal.
    • Dual VU-Meter
    • Dual Fan Cooling System.
    • LPF (Low Pass Filter) Variable 30Hz-250Hz
    • HPF(High Pass Filter) Variable 50Hz-l KHz.
    • Slope Adjustable 12-24dB.
    • Variable Bass Frequency(30Hz-120Hz).
    • Variable 0-18db Bass Boost.
    • High & Low Adjustable Level Input.
    • Dual LED Indicated Power Status (Protect/Power).
    • Mosfet DC-DC Switching Power Supply.
    • Built-in Protection Against Short Circuit, High Temperature & Overload.
    • Auto Power On/Oft By Remote (+12V).
    • Dimensions(mm) : 300(W) x 57(H) x 697(L)
    Apr 04, 2010 | Rockwood 4224RTX Car Audio Amplifier
    Compute the area of triangle
    Hi nanaeden
    Use the formula depending on what is given
    If one side and vertical height from that side to the opposite vertex is given, use the formula 1/2 of basexheight
    If 3 sides of the triangle are given use the formula
    sq root of [ s(s-a)(s-b)(s-c)] where a,b, c are the 3 sides and s is semi- perimeter.
    Familiarise with formulae to solve Maths problems.
    If it is helpful, please give a rating.
    Have a nice day
    luciana44
    Nov 25, 2009 | Cell Phones
    Does any one have the specs for a solid audio F2500D amplifier?
    Power Output
    RMS @ 4 Ohm: 700W x 1 Ch.
    RMS @ 2 Ohm: 1300W x 1 Ch.
    RMS @ 1 Ohm: 2500W x 1 Ch.
    RMS @ 1 Ohm: 4000W x 1 Ch @18v
    Signal to Noise Ratio: >100dB
    THD (IHF-A): 0.2%
    Input Sensitivity: 0.15V – 5V
    Input Impedance: 47KOhm
    Slew Rate: 10V/USec
    Damping Factor: 300 @ 4 Ohm
    Fuse Rating: EXTERNAL 200A Fuse
    Dimensions (in mm):
    Width: 240mm
    Height: 61mm
    Length: 570mm Features
    MOSFET Power Supply Amplifier.
    Double Sided Through Hole Epoxy PCB.
    Gold-plated Brass Set Screw Terminals.
    24dB/Oct. Crossover - Variable Low Pass Crossover (40Hz ~ 200Hz)
    Variable 24dB/Oct. Subsonic Filter 10Hz ~ 70Hz
    Variable Phase Shift
    5 Way Protections
    Daisy Chain Through Output RCA
    Bass Remote Control
    Power/Protection LED
    1 Ohm Stable Circuits
    Soft Start/Output Relay
    18V Operation
    Parallel Operation
    Nov 13, 2009 | Car Audio & Video
    No manual for my amp.
    • Class-D Monoblock Amplifier
    • Bass Boost Level and Frequency Remote Included
    • Variable Low-Pass Filter: 50 - 200 Hz (24 dB/Oct.)
    • Variable Input Sensitivity: 200mV - 5V
    • Phase Shift: 0° / 180°
    • Variable Infrasonic (Subsonic) Filter: 0/15Hz/25Hz (18 dB/Oct.)
    • High- and Low-Level Inputs
    • 1 Ohm Stable
    • RMS Power Output:
      • 500 watts x 1 chan. @ 4 ohms
      • 900 watts x 1 chan. @ 2 ohm
    • Preamp Outputs: 1 Pair
    • Bass Boost: 0 - 18 dB @ 40 - 100 Hz (Variable)
    • Dimensions: 15" L x 11-5/16" W x 2-3/8" H
    Oct 05, 2009 | Kenwood KAC-9152D Car Audio Amplifier
    2001 Audi A4 - Sedan, chassis code B5 - Anti Roll Bars Logo
    Top Eibach Vehicle Parts & Accessories Experts
    baire
    Robert Rankin
    ray012965
    Are you an Eibach Vehicle Part and Accessory Expert? Answer questions, earn points and help others
