Sir Myself Raj, My Sony Tv Projection Model is kp
Sir Myself Raj, My Sony Tv Projection Model is kp -es53me1. We are using this tv since 8 years. Now recently we are facing a problem with it. The problem is, The Picture quality is not good. Total screen & pictures are appearing as blur. Would you please give the solution for this?
Posted on Oct 13, 2013
ctf1800
  • 4402 Answers
SOURCE: KP-46S4U lose picture after a few second blink of brightness
does the from led blink if so how mant times pause then blink again?
Posted on Feb 12, 2008
ginko
  • 19396 Answers
SOURCE: Sony KP-51WS520 Stand by flashes 5 times
When a Sony TV flashes five times, that means that there is an AKB circuit fault.
This means that there is something wrong with the video.
When you get this error, several IC and components concerning the video signal must be tested and eventually replaced.
Posted on Dec 01, 2008
SOURCE: Sony KP-53V85
My unit is 9 years old, almost 10 (in 2 months) and started the same a couple of months ago. The only way to fix it is to have them serviced by a tech and replace the projectors. Its just the age/use of the unit catching up with it.
Many resellers sold them with an offer to sell you an optional maintence service where they would fix/clean/replace the projectors for upto 5 years after purchase. I'm not sure if they even have the parts anymore since these tv's are no longer produced. After market repairs are likely to cost as much as or nearly as much as buying a new flat screen tv.
Posted on Dec 04, 2008
Wise Frog
  • 13 Answers
SOURCE: Sony wide screen projection tv model kp-57wv600.
I found this solution from SONY's website.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
I hope this helps.
Posted on Aug 05, 2009
greenspan
  • 1734 Answers
SOURCE: Sony projection Tv KP-65XBR10W has no picture or sound
Looks to me as an serious (but not uncommon) PSP board problem with Panasonic plasmas. Contact a Panasonic service center.
What problems have people had with quality control on these displays? Are they covered under warranty?
  1. Certain displays emitted an extremely loud buzz. This was covered by warranty repair.
  2. Certain displays had a problem with the Y/C delay on their S-video input. This was also correctable.
  3. One person reported red vertical lines on his display.Was this covered by warranty? Was it an input problem or a pixelproblem?
  4. Afew bad pixels here and there are not covered underwarranty. Largeclusters are generally covered. It's up to Panasonic'sdiscretion. Onthe plus side, however, bad pixels are becomingincreasingly rare. Mostpeople are reporting no bad pixels at all!
CALIBRATINGWhat needs to be calibrated on a plasma?
You needto calibrate most of the same things that need to be calibratedonother displays. About the only things that don't need to be doneareconvergence and geometry. You can usually tinker with picture sizeandposition, but there's no need to deal with keystone orpincushionadjustments, etc.What is white level? What is black level?How are they adjusted?
Theadjustment for white level is usuallylabeled "Picture" (as onPanasonics) or "Contrast". "Brightness", on theother hand, refers tothe black level. Yes, this is apallinglycounterintuitive. This FAQuses the terms "white level" and "blacklevel", since they betterdescribe what you're actually adjusting, andthey're the terms used byAvia and Video Essentials.
How do I adjust hue and saturation?
In anothermysterious choice of terms, hue is controlled by the "Tint"setting,and saturation is controlled by the "Color" setting. This FAQuses theterms "hue" and "saturation", since they're the terms used byAvia andVideo Essentials.
How do I set the white level on a plasma?
Youset the white level by adjusting the "Picture" setting. You willneedto use a different test pattern than you would for a CRT. Forbothplasma displays and LCD displays, you should use the 10 IREgrayscalestep pattern. There are two criteria you want to match on yourplasma.
First,you need to make sure the white level is low enoughthat your displayisn't thresholding (or clamping) bright levels. Youshould set thewhite level low enough that you can see each of the 10IRE stepsdistinctly. The Panasonics seem not to exhibit clamping (in mylimitedexperience), even at factory defaults, so this criterion may notbeterribly useful.
Second, for the health of your display (e.g.to avoid burn-in), you should turn down the white level. Just becauseyour display can display blindingly bright pictures doesn't mean that it should.Plasma displays should be set between 21 fl and 25 fl light output; thePanasonics comeout of the factory at about 30 fl. On one ISF-calibratedPanasonic, 23fl was roughly equivalent to a Picture setting of -20 (inthe usermenu, not the service menu). To set this precisely you'll needto bringin a calibration specialist, but you can do a lot of good byjustdialing down the white level a lot. After seeing the display at 30fl,23 fl will see very dim. But after a while, you'll find that 23 flisplenty bright.
How do I set the black level on a plasma?
Youset the black level by adjusting the "Brightness" setting. You canusethe same test pattern you would use for any other display.
How do I calibrate grayscale (calibrate the color temperature)?
Unfortunately,this is one you can't do yourself. You need specialequipment tomeasure the color. In fact, most ISF technicians lack theequipmentspecific to plasma calibration (a $15K gadget known asaspectroradiometer). But even the standard color measurementequipment(which calibrationists do have) will do a great job.
Thatsaid, one person who had his Panasonic display calibrated by anISFspecialist said that the Cinema / Warm setting was reasonably closeto6500K out of the box. Using that setting is probably the best you'lldoon your own.
If you're really determined to screw up yourdisplay,the RGB drive and cutoff settings in the service menu are usedto adjustthe color temperature.
How do I adjust the color decoder?
Thereareseveral issues here. Generally speaking, the Panasonic decoder seemstopush blue a bit. The R-Y Axis Angle and B-Y Axis Gain in theservicemenu are used to correct this behavior.
There used to beaproblem on some Panasonics with the Y/C delay on the S-video input.Seethe Quality Control section for more information.
How do I adjust the gamma?
On the industrialmodel, there is a set of Advanced picture settings. Goto the Picturemenu, turn Advanced on, and then hit the down-arrow. Inthe subsequentmenu you can adjust quite a few parameters, includingselect from a fewgamma settings.
This advanced menu appears to be missing from the consumer model.
How do I calibrate my consumer model given these missing menus?
Thereis apparently a way to activate these menus. Perhaps you can findacalibrationist or Panasonic technician would can turn them onlongenough to do the calibration.
What's the overall calibration procedure?
In general, the order Avia sets out is the correct one. A more complete list is:
  1. White level (picture)
  2. Black level (brightness)
  3. Repeat (1) and (2) until you have a good balance.
  4. Grayscale (requires special hardware and mucking about in the service menu)
  5. Sharpness
  6. Hue and Saturation (tint and color)
  7. Color decoder (requires use of the service menu)
  8. Repeat (6) and (7) for red and green until you have a good balance.
SERVICE MENUHow do I access the service menu?
In a word, don't. See the service menu warningabove.If you're bound and determined to make use of the service menu,buy theservice manual. It contains more than enough information foryou to ruinyour display and/or kill yourself.
Posted on Aug 18, 2009
I have a Sony KP-61XBR-300 rear projection tv---- Picture went out. Is this the light bulb and if so where is located. Can I get it out myself?
This is a projection TV: it uses cathode ray tubes instead of bulbs. If you have a black screen, but still have sound, then the problem is on one of the circuit boards. Very few parts are available for this model.
Dec 05, 2010 | Sony KP-61XBR300 61" Rear Projection...
Sony 51" Rear Projection TV is blurry with colored ghost images
Thats caused by a convergence failure. The Sony type 1 convergence repair kit from www.tvrepairworld.com will usually correct that issue the kit contains the components and the CD with repair instructions so you can repair yourself.
Dec 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
PIP and direct tv
Can you provide the exact model, i work for 8 years With Sony.
Oct 18, 2017 | Sony KP-65XBR10W 65" Rear Projection...
Sony 5 projection tv kp-51ws510 no pic, light flashs 8 times
I have the same model TV and have had that same problem (*8 flashes) The FLYBACK TRANSFORMER on the D circut board is the most likely cause and will need replaced) the part is around $70.00 USD!
Please rate my response
THANK YOU!
Jan 22, 2009 | Sony KP-51WS510 51" Rear Projection...
Tv shutting off!
replace the high voltage block
the part number is (8-598-955-32)
comen problem for you model number.
regards,
daniel.
Jan 13, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
Sony projection tv
8 blinks is usually the error for a bad flyback. you can get a replacement at the following link and if your not sure which one your model uses click on the sony flybacks one at a time and it will tell which model they fit. Heres the link.
http://servicemanuals.vstore.ca/
Sep 30, 2008 | Sony KP-51WS510 51" Rear Projection...
Our Sony Rear Projection TV keeps turning on and off.
sony 46inch rear projection tv keeps turning off, flashing, loosing color, How can I fix this problem myself. It cost me $500 last year when the same thing happened.
Aug 21, 2008 | Sony KP-57WS500 57" Rear Projection...
Power surge may have blown tv- Sony KP-46WT500- worth fixing?
Take a look at my post on Convergence IC replacement..Thank you GURU JAY
Feb 18, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony TV Repair
It is really hard to say what could be your problem, so let me know exactly what it is -Does your set play-and has no sound and can you go into menu to audio?let me know i will try to help you.Thank You for using FixYa and Have a Nice Day
Feb 27, 2007 | Sony KP-51WS510 51" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
