Question about Hitachi Electronics - Others
I HAVE PRODRIVENEXT VER 1.2.40.2 TO COMUNICATE WITH A WJ200-022HFC-M AND WHEN TRY TO CONNECT SAY THE MACHINE CODE (AREA CODE)OF THE INVERTER IS AN UNKNOWN CODE. CAN YOU HELP ME?
Scanner computer cant comunicate
What do you want Darrell?
Code reader or Professional scan tool?
I think your going to need a shop to work on it
Without wiring diagrams your done
You have to chase every wire from the under dash
connect to their ends, until you fix the issue & can
connect to the Bus & Data stream,we can't help with that
Jul 17, 2014 | Office Equipment & Supplies
Reset canon mx397
usualy computer cannot comunicate to devices that are turned off... so, its ok :)
May 07, 2014 | Canon Office Equipment & Supplies
Light on inverter blinks when running the game and it stays solid when other programs run
I am not familiar with this particular unit, but using other similar devises I am assuming you are refering to the use of the USB port.
When some devices connect to usb power sources they do not send correct protocol asking for a set ammount of power, they short with a particular resistor between command wires this is used to fool the power supply to give the maximum alowable power to the USB port.
The flashing LED may be the targus unit trying to comunicate.
If the question is refering to the 120v outlets ignore above.
If there is no apparent problem with your equipment I would ignore it as the manufacturer states the unit is protected for various issues including overload.
Nov 08, 2013 | Targus APV12US 150W Slim Line Mobile...
Mi dodge caravan se sube la temperatura arriba de lo normal ya cambie el termostato y el radiador es nuevo , y el ventilador si funciona
que tal amigo si te interesa yo tengo tu solucion comunicate conmigo acabo de arreglar una camioneta igualita y el mismo modelo mi numero es 664-317-98-41
con daniel...
Feb 09, 2011 | 2002 Dodge Caravan
How much oil goes into the fuel of the homelite 240 chainsaw
please check your manual,some are 25:1,40:1 but get the mixture right as you can damage the machine.
Sep 25, 2010 | Homelite Factory Reconditioned 26cc...
Alienware M17x - brand new machine. this machine continually locks up related to the video card. error says something to the effect of display driver stopped performing. machine goes black for second,...
normal troubleshooting would be
  1. Flash BIOS to current Ver
  2. Update Video Driver to current Ver
  3. If issues persist, try system with individual RAM modules
  4. Contact Technical Support
Sep 05, 2010 | Alienware PC Systems Area-51 m17x Notebook
Brother DPC-150 doesn't comunicate with my pc
1 st remove your old driver for computer and reuinstall driver.
may be printer port is changed it is in control panel printers properties in advanced option u see ports.
Mar 01, 2009 | Casio Office Equipment & Supplies
Cannot comunicate or connect to pc
Try to connect it to another pc. If it works, then reinstall the printer driver software. If not, then the printer may be bad.
Feb 21, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
Electronics - Others Logo
41 people viewed this question
Top Hitachi Electronics - Others Experts
Are you a Hitachi Electronics - Other Expert? Answer questions, earn points and help others
