Question about Electrolux Garden
I have a hedge trimmer I have not yet used I cant find the manual can you please help the details are model hg550. pnc 953900593. ml 02.serial number 51106209. type 020. engine code ht2501b many thanks paul
    Master:
  • 492 Answers
Goggle to find out the company that built it and see if they will send you a copy or if its available for download. This is a common problem with private sales without all the manuals that come with it. Sometimes you have to look up each appliance or model. Start with a phone number to the manufacturer and work from there. Also you can find someone that is selling one like yours and call them to see if they can send you a copy from their manuals.
Posted on Oct 18, 2013
boscia
  • 163 Answers
SOURCE: Black and Decker 16 in Hedge Trimmer
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Posted on Nov 28, 2008
sparksflyin
  • 47 Answers
SOURCE: fuel line replacement
pull the lines off do only one at a time one should stick in the tank 1/4 inch which is your return the second one is your pick up which has a filter in the tank attached to it take a piece of stiff wire or a clothes hanger and bend a tight hook on the end just big enough for the fuel line to fit in it fish the wire in the tank and try to hook the fuel line then pull it out of the tank to take the filter off it might take a few tries but you will get it after that pull the line out from the top not the filter side take the new line and feed it through if you cut a 45 degree angle at the end of the line it makes it easier to feed once you get it in all the way use your piece of wire to hook it through the filler and pull it out then attach your fuel filter then shove it back in the tank like i said it may take you a few times but you will get hope this helps
Posted on Feb 08, 2009
  • 28 Answers
SOURCE: Husquarna petrol hedge trimmer starting problem
it could be extremely flooded with way to much fuel. in the motor.take out the sparkplug turn the ignition switch OFF and pull the starter rope...if there is a lot of fuel blowing out of the cylinder...thats your problem.....buy a new sparkplug and try starting it with no choke and full throttle with the new sparkplug fitted....see how you go.....or its warn out and has no compression to fire up the fuel.....in this case ..its time to upgrade
Posted on Aug 06, 2009
  • 203 Answers
SOURCE: I need coil and spark plug gap settings for echo
0.026 inch, or 6-8 mm is the plug gap.
The ignition coil air gap range is 0.012 - .016"" or .3 - .4 mm. This is the gap between the flywheel and the ignition coil.
An easy way to gap your coil is use a normal business card between the coil and flywheel, tighten the screws and remove the card.
Posted on Oct 23, 2009
agent91
  • 2100 Answers
SOURCE: Defective hedge trimmer with a lifetime warranty. How do I file
Contact Us, Warranty and FAQs
We want to hear from you! We are always looking for the best way to stay in touch with you. If you cannot find what you're looking for, feel free to call us toll free at the number below. Our customer service specialists are available Monday – Friday 8 a.m. to 5 p.m. CST, excluding national holidays.
1.866.348.5661 WARRANTY CLAIMSTo request a warranty replacement, please either:
  • Email warranty@fiskars.com with a SINGLE photo, showing your whole product in the picture. Please make sure we have your full name, mailing address (no PO Boxes) and telephone number.
  • Mail your defective/broken item OR a photo of your defective/broken item back to us:
    For Garden Products:
    Fiskars Brands, Inc.
    Atttn: WARRANTY DEPT
    780 Carolina Street
    Sauk City, WI 53583
    USA
    Hope this helps.
Posted on May 06, 2010
Serial number stihl products
Older Sithl equipment was lazer etched on to a part of the housing. Newer equipment is marked on a sticker. 25162103-bayk02caeo4w4mp1wppi0da4-5-0.jpg
Sep 30, 2014 | Stihl Trimmer Hedge Pruner Kombi Loop...
Craftsman 22 in. electric Bushwacker hedge trimmer handle is broken where can I get part number?
Call your local sears store for their national parts department 1/800 toll free phone number.
Then write down the MODEL number [and a serial number if available]. Then call the parts department, give them the model number and they should be able to give you the part number.
Just to be as fully prepared as possible, have the actual trimmer with you during the calol so that you may be able to answer ID questions the parts tech may ask.
Apr 23, 2014 | Craftsman 22 In. Electric Hedge Trimmer
Stihl power pruner serial number
The serial numbers on the FS130, HL90K,HT101 and BG55 would be on stickers if they are still there... The MS250 serial numbers are located on a 'flat' by the side of the exhaust and sprocket cover. (depending on the year of manafacture)
Jun 27, 2013 | Stihl Garden
How do i replace the line in TB575EC trimmer?
Your manual will have diagrams and instructions in detail for restringing. You can use the following link to get it.
Both the model number and the serial number for Troy Bilt Trimmers are 11 characters in length. In your case, 41ADT41C966 is the model number, not TB575EC. You will have to find and provide the 11 character serial number. Input both of these on the following page and a manual is yours.
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001&langId=-1#
May 07, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Does anyone know where I can dwonload a users manuel for a Weedeater hedge trimmer model ght225
Hi!
Yepp, i can help you! There are 5 diferent ones of that GT225
I dont know witch one you have so i'l give all five here:
HEDGETRIMMERWEEDEATER --> GHT225 ( 952711803 )
Manual: View
Parts Manual: View
HEDGETRIMMERWEEDEATER --> GHT225 LE ( 952711803 )
Manual: View
Parts Manual: View
Manual: View
Parts Manual: View
Manual: NO MANUAL AVALIBLE
PArt Manual: View
Manual: View
Parts Manual: View
Or you can go to this site and type GT225 in the search window:
http://www.poulanpro.com/poulanpro/manualSearchPrepare.do
Good luck
Nic
Apr 21, 2009 | Poulan WeedEater Hedge Trimmer 25cc Engine
Looking for owners Manual for Echo HC 1500 Hedge Trimmer.
Go to this web site http://www.echo-usa.com/ and on the right hand side of the page click "TECHNICAL DOCUMENTS"
Then when the next page comes up type "HC-1500" and click search.
Now this is important: You have to keep track of your serial number, your model number and
your engine type.
Even when your looking for parts such as the ignition coil keep track of your serial number.
When you pull the side bar down you'll find the different manuals you can copy. I hope this helped.
Apr 02, 2009 | ECHO, Inc. 20 In. Double Sided Hedge...
Placement of switch mechanism
Go to www.toolpartsdirect.com and in the search box select brand and enter your model number and you should be able to find a break-down of your machine which will give you an idea as to how it goes together.I tried the GT249/H1 and GT249 as the model number and it didn't come up so you will have to look for a tag with the model and serial number on it for the correct number.
Feb 16, 2009 | Black & Decker Hedge Trimmer
Garden Logo
71 people viewed this question
Top Electrolux Garden Experts
Phil Walker
Phil Walker
John
Are you an Electrolux Garden Expert? Answer questions, earn points and help others
