Question about Philips GoGear SA178 MP3 Player
Usb cable for gogear hdd 1620/05 - Philips GoGear SA178 MP3 Player
What type of cabble do I need to hook my gogear MP3 player to a 2014 chev silvarado? I can't get it to work threw the usb cable. The gogear goes to the charging screen and the vehicle dosen't recognize the...
be aware, some firms sell cheap USB charging cables for the use on cell phones. These cables don't have all wires inside to put through all the signals and are not shielded.
My guess is your MP3 player has a micro USB connector. Just lent a "real" USB cable to test if that works. If it works, buy a real USB cable.
May 19, 2014 | Car Audio & Video
How do I download songs onto my phillips gogear cam
  • Charge your Philips GoGear ViBE for at least three hours before turning it on.
  • 2 Insert the small end of your mini USB cable into your GoGear ViBE. Insert the other end of this cable into one of your computer's USB ports. Turn your GoGear ViBE on by pressing and holding the "Power" button for two seconds.
  • 3 Insert the Philips GoGear ViBE software disc into your computer's CD-ROM drive. Follow the onscreen prompts to install it.
  • 4 Open "Computer" from the "Start" menu and locate the GoViBE icon to make sure it has been successfully connected to your computer.
  • 5 Navigate to your music files. If you're unsure about their location, start by looking in the "Music" folder under the "Start" menu.
  • 6 Drag and drop your music files from their folder onto the GoViBE icon in your "Computer" window.
  • 7 Right-click the USB icon with the green arrow, located in your taskbar, to disconnect your device. Click "Safely Remove hardware," then wait until your computer confirms that it's safe to remove the device. Disconnect the USB cable from both your computer and your GoGear ViBE.
  • 8 Select the musical note icon from the main menu of your GoGear ViBE to open your music files. Navigate to the sub-folders section, and select a song from either the artist, album, track list or genre. Press the "Play/Pause" button to begin playing a song
Oct 07, 2011 | Philips GOGEAR SA6045 MP3 Player
How do I delete songs and pics on Philips GoGear Aria mp3 player?
Connect the supplied USB cable to the MP3 player and then plug the other end of the USB cable into the USB port of a working computer. The computer will see this as an external storage device, you can then open the various folders and delete the unwanted files.
Apr 14, 2011 | Philips GoGear ViBE Digital Media Player
Format
  1. If you have not already installed the Device Manager, download the .exe file to install the latest version of the Device Manager application from http://www.philips.com/support. Enter your language preference and the model number e.g.hdd070. Select Software under Product Support on the left of the screen. Scroll down and click on the .exe file of your preferred language under the category PC software. The program will install both Musicmatch® Jukebox and Device Manager in one go automatically.
  2. Connect the hdd to the power supply with the AC/DC adapter.
  3. Launch the Device Manager at Start->Programs->Philips GoGear HDD->Philips GoGear HDD on your PC
    IMPORTANT: All music & content of your micro jukebox will be erased once the factory setting is restored.
  4. A dialogue box will pop up; click Restore and OK to confirm and start restoring the unit to its factory setting.
  5. Follow all screen instructions to complete the restoration.
  6. The Device Manager will close automatically once the success message is displayed. Safely remove your GoGear micro jukebox by clicking on the EJECT HARDWARE icon in your task tray bar. When prompted, "The USB Mass Storage Device can now be safely removed from the system", click OK and unplug your micro jukebox.
Mar 18, 2011 | Philips GoGear HDD075/17 MP3 Player
The philips gogear wont go to USB mode it just stays there like nothing is going on...
PLA - disconnect hdd from computer, reset the player by holding play and volume + at same time, then reconnect the player; if that doesn't work, write me back
Cynthia - use Windows Media Player to transfer songs - if you get an error message or run into snags, write me back
Mar 05, 2008 | Philips GoGear HDD6330 MP3 Player
Not wanting me to deconect usb cable
Sounds like you'll need to reset the firmware. You can do this with a program called Philips GoGear HDD which will do this for you. It is available from Philp's website.
Dec 17, 2007 | Philips HDD070 MP3 Player
Cant connect to usb port
the connection to your gogear will be smaller than the usb to your pc, it's the same with all peripherals, you should have been supplied a cable with it, standard usb one end and a thinner or squarer conection at the player, see below for examples http://www.directusbstore.com/cnb/shop/directusbstore?op=catalogue-products-null&prodCategoryID=55
Sep 13, 2007 | Philips GoGear HDD6330 MP3 Player
Philips Gogear HDD6330 AC adaptor / Sync cable
I know its not the answer that you really want, but these power supply/usb units do come up for sale on ebay quit often.
Sep 10, 2007 | Philips GoGear HDD060 MP3 Player
Philips HDD 1630 won't charge
I have the same problem I think that the internal battery died... is it possible to change it?
May 22, 2007 | Philips HDD1630 MP3 Player
Philips GoGear SA178 MP3 Player Logo
22 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
