Question about Huawei U8800-51 Impulse 4G AT&T Android Smartphone
Set power storage
The phone is charging but not saving power on the battery
    New Friend:
Already did that
Posted on Oct 25, 2013
Change battery.
Posted on Oct 10, 2013
Samsung Galaxy S5 battery Won't charge in my phone, but charges in another! Also, seems to use battery up faster than normal.
The S5 has a 2 stage power saving feature in the setup menu. Go to settings and select the power saving option. You will have a choice of two levels of power saving. The Ultra option turns off all unnecessary functions. The other just reduces the brightness and turns off following functions to make the battery last longer. If this does not work, odds are the battery is aging and will require replacement.
Dec 30, 2017 | Samsung Cell Phones
How do i save music, photos, & videos in sd card of B15 CAT cellphone?
There is a setting in your phone under "settings" that lets you tell the phone how you want to save different media types. I don't know where it is on your specific phone but it is there. If you contact your provider they will help you out in minutes at no charge.
Apr 27, 2016 | Caterpillar CAT B15 IP67 Rugged Android...
How do I fix my samsung from slow charging
Before you try any of the steps / Methods provided below try this: Turn OFF power saving mode when charging. This is not mentioned anywhere online or in the user manual but works like a magic to resolve slow charging issues. If you still face the issue try various solutions here under.
________________________ Solutions for Slow Charging Problem on SamsungGalaxy S3 Method 1-System Dump System mode is a debugging panel where you can test, debug and execute different functions. There are also useful functions to give a boost to your network speed
>Open Up Dialer
>Dial *#9900#
>Scroll down, and Click "Low Battery Dump"
>Tap to Turn On
Method 2 Sometime slow charging issue on android devices occurs because of some software. So uninstall theunwanted software from your phone and then see if the problem is resolved or not. Another thing youcan do is master reset.
To master reset your phone, the steps you need to perform are Cache partition, Master reset and Safemode.
Cache partition- When you are facing slow charging issue on your Samsung Galaxy S3 you need to clearthe cache partition. It will clear different parts of your phone storage but will not delete any personaldata. To clean cache partition, turn off your phone and press the home key, power key and volume upkey altogether. When the phone starts vibrating, release the power key but keep holding volume up andhome keys. When you see the Android System Recovery screen, release both the keys. Now forhighlighting "wipe cache partition" press the volume down key. Select the option by holding power keyand wipe the cache. Highlight "Reboot system now" and press power key to restart the phone.
Method 3 Master Reset from Setting Menu- Master Reset may delete data from your phone's internal storage suchas images, content, apps, etc. But the data on SD or SIM remains saved. Back up all the data on internalstorage.
Then Tap the menu key> Settings> Accounts> Back Up and Reset> if desired, tap Automatic restore andBack up my data > Factory data reset> Reset device. If the screen is locked, then enter password and tapContinue> Delete all.
Safe Mode- Safe mode allows you to turn on your Samsung Galaxy S3 by disabling the third party apps.Then you can uninstall the apps that may be creating the Slow Charging Problem. To turn on the safe mode turn off your phone, then hold the power key. When you see "Samsung GalaxyIII" on the screen, release the power key and hold the volume down key.Keep on holding the key untilthe phone restarts. At the bottom corner of the screen, "safe mode" will appear and now release thekey.
Then uninstall the third party apps by going Menu> Settings> More> Application managers,Downloaded> tap the preferred application, then tap uninstall> Ok.
Then turn off safe mode by pressing and holding the power key> restart> Ok.
Method 4 Download and Install Greenify
Greenify is battery saving app that works best with battery boaster lite. Greenify places your appsin hibernation when not in used, this stop your phone from lagging and leeching the battery.
The Battery Boaster Lite is a power battery tuner application.It gives you full control of your battery andCpu. This app shows what is draining your battery and how to fix it.
Method 5 Sometimes slow charging problem occurs because of the apps that keep running in the background. So,though you charge the phone for hours after hours, it shows only 35% or less charge in the battery. Toclose those apps:
> Hold the home button and release it when you see the recently used apps screen.
> At the bottom, you will find the task manager button. Tap on it, then touch End all applications.
> At the top, you will find an option RAM, tap on it and clear memory.
These steps will close all the apps that are running in the background when the phone is charging, andthis is why it is slowing down the charging process.
Method 6 - Fix slow charging on android - Re-calibrate
How to Re-calibrating your android?
Remove the Battery from your Android
  1. Plug in original charger into your android without the battery inserted, VIA Power Supply .
  2. Leave it there plugged in for 30 Mins.
  3. After, insert the battery without removing the charger
  4. Let it charge to 100%
  5. When the battery is fully charged. Remove the charger
  6. Let your phone drains to 0%(Discharge) ( Do intensive CPU usage tasks, Playing games, streaming videos etc.)
  7. Repeat these step twice.
  8. The battery will subsequently receives it's charging cycle.
  9. By performing this every 3 times in per 6 months will keep your battery in good standing.
Thank n Regards
Laxman / Fixya
Mar 27, 2016 | Samsung Galaxy S3 16 GB White Smartphone -...
What is the function of the on/off switch. to save battery or to have on when charging and off when charging at the wall oulet?
On a cell phone it is to extend battery life when the phone is not required. Some phones will still retain some functions eg alarm clock, even when off. You don't need to turn the phone off when charging, but it will charge up faster if you do.
Mar 13, 2015 | Cell Phones
Phone keeps turning it self off
Not an easy answer without more info., however two common answers with most cells is either the battery is not charging or holding a charge - which means get a new battery OR go into your settings and check for a Power on/off setting. (mine is under-Settings-Other Settings- Initial Setup-Power on/off)Mine by default was turning off everyday as it is a power save option. I set power on and off times and it works fine now.
Nov 24, 2014 | ZTE Cell Phones
I installed new(not original) dockcell battery into my ibm x60s,it worked perfect for two months. now it charges to 100% and if i disconnect the power cord it will power the set off when it reaches 98%
Check your settings for power save and power management. I suspect the battery has been overcharged and has lost most of its power. Only charge the batteries when they go flat otherwise they will suffer storage loss as you now have.
Dec 24, 2010 | IBM Computers & Internet
Camera keeps loosing the time and date settings. When turning the camera on the lens does not open, then a screen asking to set the date and time settings appears - once date reset the camera works...
have you check the settings for time and date have you saved it? You can also try to remove the cam battry for 2 mins. then put it back in then turn on the camera and then after few secs. turn it off, then see if the issue persist.
Feb 21, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
How to save a picture on a i68+ touch screen phone
Hi friend,
Could you tell me where are the pictures from that you want to save? From MMS? Bluetooth? Or you downloaded from computer? If you want to save the pictures, you'd better insert a memory card in your cell phone, for the storage space of your cell phone is limited.
If you want to save the pictures that from the MMS, you'd better check if your cell phone itself has much enough storage space, sometimes, your cell phone can only save a certain amount pictures,if there doesn't have enough storage space, you'd better delete some.Or may be you can save them to the cell phone or the memory card (May be you can set the storage space when you receive from others,that depends on your cell phone).
If you want to save the pictures from bluetooth, first, you may need to set it as the following:Bluetooth-Power on -Settings-FTP settings-Shared folder-Phone/Memory card(You'd better choose the one which has much more storage space)-Then choose the folder which you want to save the pictures in.
If you want to save the pictures that you downloaded from your computer, you may need...to get much more information, you can visit here:www.1010store.com
Have a good day!
Oct 19, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Phone wont charge
You may try to do factory reset of your phone (save your data first!!):
'Home' > 'Settings' > 'SD card & phone storage,' then select 'Factory data reset.'
Dec 17, 2008 | HTC G1
Saving Settings
1) Make sure that you use your MP3 Player carefully. Don't drop it. and put it in a safe place. 2) Charge your Player only when its battery nearly empty. 3) leave some storage available, like 10% of your storage. 4) Unplug it from your PC when you aren't using it. 5) Use safe removal when removing it from your PC. 6) When you don't use it, Shut it down. Good Luck
Jun 03, 2007 | Rio Nitrus MP3 Player
Huawei U8800-51 Impulse 4G AT&T Android Smartphone Logo
65 people viewed this question
Top Huawei Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
john h
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
