GE Trivection JT930SOH1 Oven, touch screen not lighting up
The thermal fuse in your GE Trivection JT930SOH1 oven is likely located behind the touch screen control panel. In order to access the thermal fuse, you will likely need to remove the control panel.
Before attempting to access or repair the thermal fuse, it's important to ensure that the oven is unplugged and that you have taken proper safety precautions, such as wearing gloves and eye protection.
Instructions to access the thermal fuse may vary depending on the specific model of your oven, so it's recommended to check the owner's manual for your oven or contact GE for instructions.
However, in general, you may be able to access the thermal fuse by first removing the control knobs and screws that secure the control panel in place. Then, you'll likely be able to lift the control panel off of the oven to access the thermal fuse.
It's important to note that the thermal fuse is a safety device, and it's designed to blow if the oven overheats. If the thermal fuse is blown, it will need to be replaced. If the fuse is not blown and the touch screen is still not lighting up, it could be a problem with the touch screen itself or a problem with the wiring or other electrical components of the oven.
It's recommended to contact a certified technician to diagnose and fix the problem.
