Question about Air Tools & Compressors
We have a 2004 XAS 136 rotary screw compressor. The problem started suddenly. Engine starts and runs fine. On activating compressor, (blue button) there is a bit of exhaust smoke and engine seems overload. On opening ball valves, to use air, the engine revs fall, there is lots of exhaust smoke. It is delivering air, but obviously less as revs fall. Has anyone got any ideas of what problem could be? Thanks in advance.
  • A Duffus
    A Duffus Oct 10, 2013
    Hi - should have said 2004 Atlas Copco XAS 136
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 85 Answers
First check oil level in both the engine AND the compressor if it has an oil sump.
It ounds like the piston rings or cylinders are scored causing the engine to have no power under load and to burn oil, and the compressor may also be seized.
if there is the correct amount of oil in the engine then consider an oil change and add some
Ametech Engine Restorer Oil Additive
www americantechnology co uk
to both engine oil and the compressor oil (providing it also uses ordinary engine oil too)
Posted on Oct 20, 2013
3 Suggested Answers
  • 89 Answers
SOURCE: 1989 Ingersoll-Rand 185 cfm air compressor will not build up air
ITS A POSSIBILITY AND YOU BETTER HOPE ITS NOT SPINNING BECAUSE THE SCREW COMPRESSOR IS LOCKED UP. CHECK THE OIL LEVEL IN THE SUMP AND SEE IF THE ROTOR WILL TURN WHEN NOT RUNNING. TYPICALLY THE DIESEL ENGINE WILL TURN HIGHER RPMS WHEN IT HAS NO DRAG ( NO COMPRESSOR HOOKED UP ). YOU CAN GET THE PARTS FROM INGERSOL RAND OR ANY RENTAL YARD - UNITED, PENSKE, SUNBELT, ETC. THEIR MECHANIC SHOPS ARE USUALLY FOR HIRE AND CAN EVEN INSTALL IT FOR A CHARGE. ALSO MAKE SURE NOTHING BUILT A NEST IN THERE. IF YOU REMOVE THE SCREW, MAKE SURE AND WATCH FOR SHIMS. THOSE SHAFTS NEED TO LINED UP PERFECT TO REDUCE VIBRATION. GOOD LUCK
Posted on Apr 07, 2009
SOURCE: Have ingersoll rand p175 w-w
I have a similar problem with my compressor. Have you had it repaired yet/ If so, what was the problem??
Posted on Sep 15, 2011
My Ingersoll Rand UNI15-5-150-L rotary screw compressor only starts uo after trying to start between 10 and 15 times
image Regulator may difference on all set ups good luck
you may have a Regulator on Air-Compressor Mount on the Gauge or next to it this allow you to set a pressures from 0 - 200 psi this to helps you maintain steady and reliable operation of your air tools.
Apr 18, 2013 | Ingersoll Rand Stationary Air Cooled...
Ingersoll Rand SSR EP60 60hp Compressor w/ Intellisys 39817655 controller. Need to reset target pressure. What is the secret button sequence to access programming mode on this controller? I am aware of...
OK, Compressor should be shut down and showing (ready to start) in display. Press load/unload button once then press hidden right button within 3 seconds. This will let you access the set point program. It will include language, temperature and pressure, rated pressure,etc. Make sure you look at the data tag affixed to the unit and see what the rated pressure is for your unit. You can endanger yourself and equipment by over pressurizing the components of the compressor.
May 19, 2011 | Ingersoll Rand Stationary Air Cooled...
What does alarm start fault mean on the control panel on a ingersoll rand ssr ep-30 air compressor
I use to start up a 25 HP Ingersol screw type compressor. The only alarms I got were from power spikes which just needed the reset button to be pushed, then the on button - and the low oil sensor would shut it down and give an alarm when the tank was about half way down. They will blow up with no oil so there is a saftey margin on oil level.
Mar 28, 2011 | Ingersoll Rand Stationary Air Cooled...
My 1998 atlas copco xas 97 185cfm deutch diesel shuts down when i open full air
Check the Deutch diesel engine controls. Normally with
the compressor at full open, engine must continously run, sionce this is the point where the engine is not
heavy loaded. Check the injection pump as well as engine speed control and the air filter.
Nov 04, 2009 | Air Tools & Compressors
My 2004 mazada rx8 won't start, smells like its flooding out! turns over good. Pulled in one night -no problem. Went to get in and go next day and wouldn't start!
HI check your air filter make sure is clean, replace spark plugs if fault whit fuel ,if thats the case also replace your oil and filter
Sep 23, 2009 | 2004 Mazda RX-8
How to confirm the cfm of screw conveyor that
start with empty tank and stopwatch. start compressor and stopwatch. stop at certain value f.e. 5 bar the machine have pumpt 5 times tank in much seconds calculate time and liters.
Aug 27, 2009 | Ingersoll Rand Stationary Air Cooled...
Apr 06, 2009 | Air Tools & Compressors
ROTARY SCREW COMPRESSOR TRIPPING
Possibly water in the air tank ? Or Ice covering the inlet or screen into the tank? DOes it have a belt? or direct drive? Remove the belt and try to turn by hand. See if its the motor or the compressor is tight. If it rolls free possible a chack valve is hung up or has a broken spring OR yuo have a bad capicator or centrifical sw going to the start capicator. Check amp draw with no pressure on the compressor. tank open. If it runs extra time its somethign while under load. If it still cuts out you need to sepperate and discover if its a mechanical or electrical problem.
HOPE THIS HELPS PLEASE RATE ME ACCORDINGLY AND GOOD LUCK
Mar 03, 2009 | Ingersoll Rand Compressors 5-HP,...
Air Tools & Compressors Logo
100 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
