Question about HP veer 4g at&t unlocked quad band gsm phone - webos-18493
Hp veer asking apn settings in unlocked phone
Life wireless apn settings for at&t kyocera duraforce e6560
The best place to get these settings is from your service provider. Call up on their customer care hotline and ask. They'll send an SMS containing the settings.
Jun 20, 2017 | AT&T Cell Phones
How do i change the apn settings straight talk
Easiest would be to ask the operator to send you the settings.. otherwise go to settings and then go to mobile network and then provider settings..
Aug 06, 2014 | Samsung I9000 GT-I9000 Galaxy S 8GB...
Interent in samsung galaxy s duos2 only open wifi not from the sim
create a new APN
ask your SIM provider for Access point Number(APN) settings
Feb 26, 2014 | Samsung Galaxy S Duos S7562 White Dual SIM...
Apn settings
I have a S4, not sure if its the same but here's what i do to get to APN settings:
First go to settings and tap on the connections tab at the top of the screen. Then tap on "More networks" under the "network connections" subsection. Once there you should see a button for "mobile networks". tap on it and it should bring you to another screen with a button called "Access Point Names (AKA APN). Tap on that and you're there!
Like I said, this is for a Galaxy S4 but I think it would be a similar if not identical procedure for the S3. Hope this helps :)
Jan 22, 2014 | Cell Phones
How to open line
To openline the HP Veer 4G phone from network lock,Use unlock code.Visit the site
Unlock-zone.com/hp-veer-4g/rs5wp9/ get the unlock code and Openline or unlock from network lock easily.
Sep 26, 2012 | HP Veer 4g - 8gb - White at&t Smartphone...
Change apn setting nokia 6350
Please refer all the APN settings from the link provided below :
http://broadbandforum.in/bsnl-3g/64177-apn-settings-for-all-network/
Jun 20, 2012 | Nokia 6350 Cell Phone
I need to unlock my mytouch slide 3G
See instructions below:
1. First you need to get your unlock code. You can easily get the code from our website www.FreeYourHTC.com . Turn off your phone.
2. After you receive your unlock code from us, insert Non T-Mobile SIM card which you have planned to use with myTouch Phone.
3. Turn on your phone, a prompt for Enter Unlock Code will pop up, enter the code that we provided you . (Entering Wrong Unlock code more than three times may permanently lock your phone.)
4. After enter your code, return to Main Screen Menu and Access APN Settings.
5. A list of preset APN will be shown, you need to click on New APN button
6. Now Scroll down on New APN setting Screen and enter following details
MCC (Mobile Country Code), and MNC Mobile Network
or you can see this video for unlock
http://www.youtube.com/watch?v=0lkCvpr3s6w
good Luck, and do rate the solution if got help
Dec 08, 2010 | Computers & Internet
How do i get free unlock code for g1 google phone
Dear,
  • 1. Side out the Keyboard / Open Left Hand side Notch to unlock Battery Panel.
  • 2. Insert TMobile SIM Card and Battery.
  • 3. Press MENU Button Constantly and Switch the Phone using Red Talk End / Power Button but do not Release the Menu Key.
  • 4. This will put on the Phone in Safe Mode.
  • 5. Press to Emergency Dial Button, Windows dial *#06# and this will show IMEI Number: note it down and also Recheck IMEI with Box.
  • 6. Give IMEI to Unlock Code Provider www.unlock-tmobileg1.com and get the Unlock Code.
  • 7. Now Return to main Screen and Press MENU Button this Will popup APN Button, Just Press it.
  • 8. Go to APN Setting. There will be so many APN already Preset. Again Press MENU Button this will show NEW APN Popup Button again Press.
  • 9. Remember to put Right MCC (Mobile Country Code), and MNC Mobile Network Code, G1 Matches SIM card Data of MCC / MNC with these Setting and then try to use that. Settings.
    All World MCC / MNC codes is available here:
    http://en.wikipedia.org/wiki/Mobile_network_code
  • 10. Now Switch off the Phone and Wait for Unlock codes.
  • 11. Insert the Non T-Mobile SIM Card which you intend to use it with G1 and switch G1 on. (Your SIM must have
    Data plan / GPRS Activated so G1 will able to contact google.com for Activation)
  • 12. HTC G1 will ask for Unlock Codes. Type unlock code carefully, typing wrong code thrice may make Phone Hardware Locked.
  • 13. Once Unlocked your GPRS / EDGE / 3G Data Service will be active as per APN Setting we did before.
  • 14. Type Google User name / Password in Signing Window and this will Activate the Unlock G1 Device on your SIM Card.
  • 15. Make other remaining Data Setting like MMS / Home Page / Port to Active other Data Service
Thanks
Sep 14, 2010 | HTC Google G1/Dream Cell Phone Black...
Black berry storm unloked
Check with the settings first then chk with manual guide to change the settings or not then fin whether it ak for any unlock info if so means get the unlock instructions from free instructions
Aug 12, 2009 | Cell Phones
HP veer 4g at&t unlocked quad band gsm phone - webos-18493 Logo
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
