I got a Blue Way KYD35 portable airconditioner. Wondering if I need to keep the lids behind the unit open or closed. If I open them hot air blows up into the room defeating the airconditioning. I cannot close the lids either because am not letting the hot air go out. Is there something missing in the unit like a duct that takes the hot air away?? Thanks for the help in advance.
  • 499 Answers
Yes, hopefully it has 2 of them, 1 for removing air from outdoors rather than ejecting indoor air to the outdoors, again fighting itself in the process due to infiltration of outdoor air to compensate for the amount being ejected to the outdoors.
The old style portables were designed this way and were not optimal as they pull in warm air as they reject the hot air from condensing the refrigerant gas to a liquid.
With 2 hoses only outdoor air is used to condense the refrigerant and this same air is rejected back outdoors thereby avoiding the negative pressure created by the old single hose design.
You need to install the hose/hoses/ducts to reject the hot air outdoors at minimum.
Posted on Oct 10, 2013
  • Srihari
    Srihari Oct 10, 2013
    Thanks Keith for the quick help, appreciate it. Cheers
  • 105 Answers
SOURCE: Cool air when running; warm air when compressor is off.
It sounds as if warm outside air is being drawn back into the room when the unit is not actively cooling. Portable units depend on room air to carry the heat outside, & therefore will not work properly if the room is too airtight. Provide a makeup air passage by leaving the door slightly open, & see if this helps. Use a room thermometer to see if your desired temperature is being reached. Note that if the wind is strong & coming from the wrong direction, it may not be possible to prevent warm air drawback.
Posted on Jul 18, 2007
koolbreezes
  • 540 Answers
SOURCE: AC doesn't blow cold air
Threr are suppose to be two sounds comming from the window unit. One, the fan sound and the compressor sounds, (this compresses the refrigerants aove room temperatures (around 240*) & send it to the back coils and remove it to room temperatures and send it to the front coils which if enough freon, it will cool to at least 40*. Turn the thermostat all the way up or down while its off and see if you hear a clicking noise which tells you the thermostat is working which that what calls for cool. If it started loosing cools little by little, then you have a leak, and leaked all the freon out! If it stopped cooling all of once, then your compressor is not kicking in.
Posted on Jun 18, 2008
  • 230 Answers
SOURCE: Amana Portable Electronic Air Conditioner 9000 BTU
Unfortunately I am unable to find the Manual in our system. Here is the information that you can use to contact them directly. They should be able to send you a new one.
Consumer Affairs Address:
7401 Security Way
Houston, TX 77040
To speak with a Heating and Air Conditioning Consumer Affairs Representative from within the United States, please call 1-877-254-4729
Posted on Jun 27, 2008
  • 659 Answers
SOURCE: wont no water to empty or drain
Either the unit is really dirty or it is low on refrigerant. A unit tha is low on refrigerant will start off cold and withing a few minutes, start warming up. If you aren't seeing any water its because of one or both causes listed.
Posted on Apr 01, 2009
boysor2933
  • 293 Answers
SOURCE: Calculation of CFM discharge from an opening of a duct collar
There's a thumb rule in A/C air distribution. At 1 TR load, the air supply is about 400 CFM and the ideal diffuser size is 16" x 16" with an effective flow area of about 70%. Branch duct size for this outlet should be around 12" x 12".
Posted on Jun 20, 2009
SPT WA-1220H Portable Air Conditioner stopped blowing COOL air?
sounds like the compressor has died and is tripping its overload protection. Give it a good funeral, and next time, buy a brand name model.
Oct 06, 2014 | Kenmore Ac Airconditioner Remote Control...
Portable airconditioner keeps shutting down and is very hot behind the unit
Make sure that there is good air flow. Find the filter and make sure that it is clean.
Feb 06, 2011 | Heating & Cooling
Everstar mpm08cr bb4 will cool briefly then briefly blow hot air
check your filter and replace,, and that dont do it,, you need to clean coils,, and if that dont work it may be low in gas,, hope this help you
Sep 01, 2009 | Danby DPAC8020 Air Conditioner
Airconditioner only blowing hot air
there can be several situations going on from the capacitor powering the compressor giong bad or even the unit being low on charge and going off on high temp first thing i would do is check the air filter and then see if there are any batteries inside your thermostat and replace them if those are both ok i would recommend calling a contractor that specializes in your brand of airconditioner
Jul 28, 2009 | Heating & Cooling
Danby 12,000 BTU Portable Air Conditioner - Doesn't Cool Enough
put a xtra fan on you to blow the cooler air around. this might help. but i think you will find it is to small to cool what your trying to cool. good luck and good day
saw
Jul 09, 2009 | Danby Portable Air Conditioner
My airconditioner is blowing hot air on one side and cold air on the other side. I have a 2002 ford explorer
I am having the same problem in my Honda. I was told it could be the actuator motor to open up the flap changing the temperature could be stuck closed.
Apr 27, 2009 | Heating & Cooling
DeLonghi portable airconditioner leaking water
nbenz ,
Welcome to fixya.
I'm Huuum and happy to assist you,
Portable units are supposed to spray the water on to the hot compressor an evaporate the water!
If it is only 3 weeks old ,you have a 1 year warranty. call service and let them fix it for !
Please remember to leave a rating before you go!
Thank you
Aug 26, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Chest freezer lid
Vacuum is caused by contraction of air. If your temperatures are being maintained the difference in how easily the lid opens and closes is not a point to worry about. If the lid wont shut after it is opened you do have a problem. If the lid is staying open at one corner try, with the lid open give it a slight twist pulling on the corner that is not closing fully. This action should spring the lid back to its original sealing position.
Jun 12, 2008 | Freezers
Heating & Cooling Logo
81 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
