The heat pump wont turn on - Heating & Cooling
  • 499 Answers
First step is go to your thermostat and turn the Fan switch from AUTO to the ON position, if the indoor blower runs you have proven that you have both high and low voltages and no need to check breakers, and fuses both high and low voltage.
If the Fan does not come on then you need to determine whether you have high and low voltage, the high voltage may have a time delay fuse as well as a beaker, these fuses are located at the electrical disconnect typically within 3 feet of the unit, inside it in a plug/fuse holder that must be replaced in the correct position as 180 degrees off = OFF or no power.
If you do have high voltage the next thing to check is the 24 volt control voltage from the transformer in the heater.
There will typically be a 3 to 5 amp automotive type fuse located on the circuit board located in the heater, this is often the reason for no 24 v control voltage.
These 2 diagrams demonstrate a heat pumps wiring. if split type system.
Posted on Oct 10, 2013
Heat pump won't turn on and keeps flashing with a green light on the heat pump it's self does this mean it's out of gas do they have gas ??
Turn power off for a few minutes and back on , it will take several minutes to restart , be patience if it wont start after 10 min it could be a drain clogged , or if it starts and shutt of , could be out of gas or not enough water circulating if is a water cold unit if is a split system heat pump could be the board or is of on high pressure , either fan motor outside not working or a restrccion in ref lines
Jul 16, 2017 | Heating & Cooling
My hottub wont heat. I press the heat button and the bubbles come on
Check to see if there is an open limit (high temperature) switch that can be manually reset.
Feb 08, 2015 | Pool & Spa
54075 heater turns off
bad recirculation pump
Apr 28, 2017 | Pool & Spa
Heat pump compressor wont come on in heat mode, works fine in cool mode, we get heat occaisionally for about 2 min, then the compressor shuts off. it is a fridgedaire window unit.
Try setting the thermostat at a normal heat setting. By raising the temperature too high the unit thinks that the heat pump won't be effective and go into strip heat mode.
Nov 17, 2013 | Frigidaire Energy Star Room Air...
The furnace wont turn on even though it says it is
not all digital thermostats are compatible with the manufacturers circuit control boards in the furnace. Hunter has had this problem several years ago. Other than that you may have miss wired the unit. usually the furnace is used as backup heat (during defrost) or emergency heat if your heat pump konks out. Are you switching to emergency heat for a furnace call?
Nov 24, 2009 | Hunter Fan Company 5/1/1 Programmable...
Combi bioler heats water but wont heat the
There are 2 Heat Exchangers and 2 Water Pumps on a Combi, at least the one I had when I lived in the UK did.
There is a Thermal Cut Out on both. They look like a Disc, that is Soldered [with provision for connecting the wiring] onto the Hot Water Outlet from the Exchanger to the Pump, to Supply either the Domestic Hot Water, or on the other Exchanger, Central Heating.
If 1 of these fails, the System will start up and when the temp reaches a certain point will trip out the Burner, and continue to Run the Pump until the Temperature drops, and then Stop.
The type I had, had Pumps with a Black front facind nut, this unscrews anti clockwise to release that center, that could be pulled slightly, and used as a Key to turn the Pump Impeller, in the event that lack of use would make it stick, when powered up.
There shouId be a Diagram, inside of the Front Panel, that shows the layout for the whole Internal Water flow, Pipes, Pumps, Safety devices etc. I hope this has helped you.
Regards,DT
Nevada, USA
Aug 29, 2009 | Heating & Cooling
Amana Package heat pump wont turn off
i can help with this. call 1-888-855-9987. The problem is on the board.
Aug 12, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
