Question about Saws
Slow start up when connecting to internet, and after sitting for awhile idle, system is unresponsive have to do hard turn off and turn system back on.
    Master:
  • 796 Answers
Do not try to connect your jigsaw to the internet.
Posted on Dec 18, 2013
My Sony Blu Ray was working fine. I bought a used blu Ray it skipped and froze(was completely unresponsive. I had to unplug it to power it off for awhile. It worked for a few minutes and then started...
Does the player work with other blurry discs? If so, then your new- used disc has issues. You can try cleaning the disc or buy a repair kit.
If that doesn’t work you can try a different player.
Nov 13, 2017 | Sony Televison & Video
Computer is slow and browser is unresponsive
your System may be slow due to following reason
- Too many programs running at startup or in the background
- Data Corruption, hard disk fragmentation
- Missing Windows updates or outdated drivers
- Not enough hard drive space, too many unused programs
- Left over programs, old cached and temporary files
So Follow these steps to fix computer freezes problem::
- Delete all the temp files
- Remove unused programs
- install latest drivers from the manufacturer site
- Install and run antispyware software
- Free up wasted space with Disk Cleanup tool
- Defragment your hard disk drive
If you are unable to perform above tasks then use a single utility tool like PC Fresher that will fix windows errors that cause of system slow and browser problem
Aug 31, 2013 | Computers & Internet
1996 GMC JIMMY, Hard starting after it has ran for awhile
could have a battery ground , check cables for corrosion.
could also be the starter or the solenoid.
you could also have a dead short in the battery itself, it will be ok if it sits but will give you fits for repeated starts
Apr 16, 2013 | Cars & Trucks
2003 chevy malibu, takes awhile to turn over and start, idle shoots up and down when started, also it stalls when i take turns
How long since a tune-up? Any applicable trouble codes? With extended crank, you can try cycling the key, on and off, a few times before you crank it. If that helps, have to check fuel system. Use a gage and check proper fuel pressure.
Check and clean the idle air system, see if it helps?
Sep 03, 2017 | Cars & Trucks
I have a 2008 KX450F. Starts on 1st kick when cold but really hard to start when hot. Also have trouble with the idle, it is idling very fast but will eventually slow down to normal idle if i let it sit...
There is no reason for the idle to take 10-15 seconds to slow to normal. perhaps you have a vacume leak. check all your seal and gaskets between the engine and the carb.also when it is running spray gummout spray or equivilent around the gasket edges between the engine and the carb, if the idle increases when you spray then you have a vacume leak. (intake leak). It may be that this is causing it to be hard to start when it is hot.(not getting enough fuel)
Nov 03, 2010 | 2004 kawasaki KX 250 F
Runs very slow... hard disk constantly running
You need to defrag your drive, make sure no unnecessary resources are running in the background and delete your temp folder as this fills with allsorts of rubbish you do not need and slows the operating system significantly.
Jan 05, 2010 | Toshiba Satellite A45-S150 Notebook
1993 Volvo 850 fuel issues
it is the fuel pump for sure. If you can hit the tank and get it to run it is the pump. this drain back (hard start after sitting) is a fuel pump issue as well
Nov 24, 2008 | 1994 Volvo 850
Saws Logo
24 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
