Question about Refrigerators
Keeps leaking water - Refrigerators
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
Leaking water from where?
Posted on Oct 10, 2013
Water pump leaks out weep hole in water pump when plugged in otherwise doesn't leak! Does this mean water pump seal is out?
Yes. Water pump seal is leaking. The weep hole keeps the water from getting to the bearing in the water pump.
Dec 19, 2016 | Cars & Trucks
Jeep patriot leaks water intermittenly
This could be what is referred to as a cold leak. That is a leak that only is present when the temp. drops, and the metal pipe shrinks. Also it could be the a/c leaking water. Is there coolant on the ground under the vehicle or is just water?
May 25, 2014 | 2008 Jeep Patriot
My hamsters' water bottle keeps leaking, what can I do to fix this?
It could be that thelittle ball that stops the water from leaking is broken, you will need to get anew one so for the time being put a little bowl of water in the nest, make sureyou change the water regular though as it will get bedding in it.
May 13, 2012 | Pets - Others
Keeps overheating
if your car keeps over heating, then it means the fan blowing the radiator is weak or might not be working at all.
Also, your water pump might be damaged, which can cause it to leak water. Put water into the radiator and check under the car to observe if there would be any leak of water.
Make sure the above is checked and fixed because thing overheating problem can damage your gasket which can make your can engine to knock.
Water as to be leaking from somewhere which is making the car overhear frequently.
Good luck.
Jan 02, 2011 | 2005 Nissan Sentra
The fridge keeps leaking water underneath,the freezer part keeps iceing up down the bottom under the draws,the water is the main problem.
Water in the drain overflowing can be the reason for the water spilling,it can be the defrost overflow or the leak from the evaporator tubing's to the drain. So drain off and check perhaps more condensation is the result of the overflow.
The icing can be related to water formation from the food or leak from the evaporator, high frosting can blow the water inside the freezer.
So set the freezer temp a little lower so that the freezer shuts off than to make it run continuously.
Sep 30, 2010 | Samsung Refrigerators
It is leaking water from some where and the oil light comes on
MAKE SURE OIL LEVEL IS CORRECT, NOTHING TO DO WITH LEAKING WATER
May 19, 2010 | 1998 Cadillac Catera
Water keeps leaking out onto countertop, even when off. Doesn't matter if reservoir is at max or min.
I had the same problem.. I took the clear rubber grommet piece off and added an additonal o ring I had left over from a pur water filter kit and it stops the water from leaking. What does annoy me is that it only pushes water cleanly through for about 30 sec then it drips very slowly for the remaining brew to fill two full shots (I like mine big).
Jan 17, 2010 | Hamilton Beach 40714 Espresso Machine
Water leak. light keeps coming on and I have to
if you cant tell where the leak is coming from you will have to get it inspected before major damage occurs
Nov 30, 2009 | 2000 Volkswagen Jetta TDI
7kg J845 frontloader keeps leaking water even
check and see if the float moves freely , could be sticking and causing too much water to enter the dishwasher.
Sep 13, 2009 | Washing Machines
Ge top load washer keeps filling with water
most common leak point for washers is the level sensor connector on the lower part of the tank, a small plastic hose.
Not a solution, something to check
Jul 23, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
