Question about Franke Home
Insinkerator air switch
The button keeps dropping down on worktop instead of being flush as it was when new
The air switch on my whirlpool tub will not toggle, i must hold the button in to keep motor running.
What you are experiencing when you push the Air Button down and it engages the BATH PUMP but when you release the the Air Button is a bad Air Switch in the BATH PUMP.
When you push the air button down it sends a column of air to move a small switch in the BATH PUMP. When the switch in the BATH PUMP is bad it will not engage.
What you need is a new Air Switch model TBS-339.
Rod
US Parts Center
888-521-6183
Feb 28, 2013 | Home
No water being dispensed from my Insinkerator hot water tap following insallation of new filter
Probably debris from old filter got trapped in the line.
If the insinkerator has aerator, take that off and flush out debris.
Otherwise, the line will have to be taken apart and blown out.
Aug 11, 2012 | Water Heaters
Where is the reset button on the Badger insinkerator?
It's a red button on the bottom of the unit. Here is a link to the manual: http://www.insinkerator.com/pdf/US_ICU1.pdf
Look on page 10 for a diagram. Hope this helps.
Mar 13, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Tenant dropped a shot glass down the drain and it shattered. Will the Badger 5 chew up the glass, or do I need to get it out?
Yes it will. Turn it off and onn a few seconds until the thickest part is broken up and then run it with the cold water on several minutes to flush it out.
Nov 02, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I ran insinkerator last nite. This morning it
Unplugged the insinkerator and hit the reset button and then plugged it back in.
Oct 19, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Button does not work. Been difficult for a long time and finally stopped all together. Is there a bladder or something that can be replaced or does the entire switch need to be replaced? Not real...
The button assembly is just a little air piston that squirts air through a hose to the black box with the electrical switch in it. You should make sure the tube is connected good and not leaking. You'll be able to take the button off the sink by unscrewing the nut holding it to the bottom of the sink. You might be able to pop it apart and clean the gunk out of it, but you can search on ebay like http://shop.ebay.com/i.html?_nkw=insinkerator+button&_sacat=0&_trksid=p3286.m270.l1313&_odkw=insinkerator+replacement+button&_osacat=0 and find a new replacement button for about $12
Oct 13, 2009 | Emerson InSinkErator STC-BLK Sink Top...
Garbage disposal will not go on. Breaker is on, reset has been tried.
Yes. It is possible. Is the push button in with this switch box? Because the push button could be bad.
May 24, 2009 | Emerson InSinkErator STC-BLK Sink Top...
UNsermount sink with waste disposal
The easy mount disposal has a ring the (sort of) screws onto the insinkerator sink drain - the thing that is labeled insinkerator when you look down into the sink.
If this is a new install on a new sink, I recommend the EZ mount model. If there is already the sink drain (thing mentioned above) labeled insinkerator, you may be able to simply attach the new disposal to the existing drain ring.
Also: If you have a dishwasher to connect, this is a great time to install the "air gap valve" (available for almost free at any hardware store.)
May 05, 2009 | Dishwashers
Put together
1 Chrome Rail (for attachment to Worktop)
4 Self-Tapping Screws (to attach chrome rail)
1 CO2 Cylinder Support Stand
1 CO2 Cylinder (empty)
1 CO2 Regulator (high/low pressure gauges)
1 CO2 Air Line Hose (red)
2 CO2 Air Line Hose Connectors (black)
1 Beer Keg Coupler
1 Beer Tower Unit (complete with faucet, hose and wing nut)
1 Rubber Washer (to be installed inside wing nut)
1 Beer Tower (Quick Connect) Bayonet Attachment (beer tower installation)
4 Machine Screws (to attach bayonet to beer tower)
1 Gasket (beer tower base)
1 Pull Handle (beer tower faucet)
1 Beer Keg Stand (required for 30 liter keg installations only)
1 Protective Plate (refrigerator cabinet floor)
2 Cantilever Wire Shelves (conversion to all refrigerator application)
1 Chill 'n Tap Exterior Cabinet Plug (located on worktop)
1 CO2 Air Line Hose Plug (located exterior rear cabinet)
1 Plastic Drip Tray (2 piece)
1. Remove Worktop: Using a Phillips Screwdriver, remove the
three screws located on the front underside edge of the
worktop and the three screws located at the rear (back)
side of the worktop.
See Fig's. 1 & 2
Remove the worktop from the cabinet and position the
worktop on top of the cabinet so that the front corners
are staggered across the front corners of the cabinet.
2. Installation of Top Rail: Attach the chrome rail to the work
top using four self-tapping screws from the underside of the
worktop through the pre-drilled holes. (attach the front ends
of the rail first)
3. Re-Install Wo r k t o p : Install the front of the worktop onto the
cabinet, then lower the rear side of the worktop over the
backside of the cabinet. Secure using the same screws
removed earlier. (the smaller screws at the front the larger
screws at the rear)
4. Installation of CO2 Cylinder Support: Install the cylinder
support onto the four studs located on the exterior back
wall of the cabinet. (no tools required) Align the holes in
the cylinder support with the studs and push down firmly.
See Fig. 3
5.
Installation of CO2 Cylinder: Install your " fully charged"
CO2 cylinder into the support stand. IMPORTANT NOTICE:
ALWAYS EXERCISE EXTREME CAUTION WHEN
HANDLING PRESSURIZED C02 CYLINDERS:
6. Installation of C02 Regulator:
Attach the CO2 Regulator to
the C02 cylinder by screwing the regulator nut onto cylinder
valve and tighten (snug) using an adjustable wrench.
7. Installation of C02 Air Line Hose to Regulator: Attach one
end of the (red) air line hose to the hose barb connection
on the CO2 regulator. Secure hose by using one of the two
(self locking) black plastic snap on clamps provided.
(use pliers to snap the clamp tight to assure that there are
no leaks)
See Fig. 5
Fig. 1
Fig. 2
Fig. 3
Fig. 4
Fig. 5
CHI
See Fig's. 1 & 2
of the rail first)
screws at the rear)
See Fig. 3
5. Installation of CO2 Cylinder: Install your " fully charged"
6. Installation of C02 Regulator: Attach the CO2 Regulator to
no leaks)
See Fig. 5
Fig. 1
Fig. 2
Fig. 3
Fig. 4
Fig. 5
LL'N TAP ACCESSORIES (included with this unit)
Jan 07, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Home Logo
Top Franke Home Experts
Donni Steen
Gil Shultz
Freddy
Are you a Franke Home Expert? Answer questions, earn points and help others
