Question about Tomtom GO GPS Receiver
I have connected to my computer but nothing happens.
I tapped "yes,I want to connect to my computer" on the sat nav screen but nothing happens after that on the pc screen or sat nav screen.
I had a similar problem with a GO 720 which I had connected to the PC via a USB hub. The problem was solved by connecting the Tom Tom to a USB on the PC (rather than connecting to the USB hub).
Posted on Jun 09, 2009
  • 12 Answers
I presume that you are using the docking unit, so plug it into a usb with the tomtom turned off, then when you turn it on it should boot up the tomtom home prog.
If that doesn't work, remove any existing tomtom home prog from your PC and try again.
Download tomtom home from your CD or from the website.
If you have aquired the unit second hand it may be blocked due to security reasons.
The only way to sort it then is to mail TomTom and give them your serial number and an explanation !
Posted on Apr 25, 2009
I have been told that I need to update the maps on my sat nav
then go to their website and get them we can not do it for you.
Jan 04, 2017 | GPS
Hi my sat nav ran out of charge. After re-charging it it won't switch on.
HI YES ,I HAD SAME PROBLEM ..THE CONNECTION IN SIDE FOR BATTERY CONNECTION TO CHARGE IT HAS GOT TO BE CONNECTED ,,MINE HAD COME AWAY ..OPEN BACK CAREFULLY AND RESOLDER ..OR TAKE TO SOMEONE WHO DOES ELECTRICS ,IT IS EASY THOUGH ,,HPE THAT HELPS ,-)
Apr 27, 2015 | Mio Spirit 485 GPS Sat Nav with UK and...
Garmin 1200 suddenly stopped loading up....
I am haveing the same problem
poky345@yahoo.com
Can not seem to find any reason?
Mar 31, 2010 | Garmin nuvi 1200 Car GPS Receiver
Sat nav just stopped working today in perth wa, not picking up any sat signal. any way to fix this? is it my sat nav or the sats?
It isn't the sats. They're fine.
Try resetting the unit. Use a paper clip to press the button in a small hole on the bottom.
Try to reset the sats. To do this:
Tap the satellite bars in the lower right-hand corner.
Then, on the next screen, tap the satellite bars in the right-hand margin.
On the next screen, select "Configure." Choose a different configuration. Tap "Done," then "Done" again on the next screen.
Did that help?
Nov 03, 2009 | Tomtom GO 300 GPS Receiver
Tomtom one sat nav 18 months old is now taking upto 5 minutes to get a gps signal. When desination is entered the calculation is done tap done and continue then it says gps signal was lost and takes...
try downloading tom tom home to your computer and use your dock or cable to connect it to your computer, switch on your tomtom and allow it to connect to your computer and updates should automatically happen, this should fix it, good luck
Aug 26, 2009 | Tomtom One XL GPS Receiver
I have a Myguide 3100. It has worked up until now but it powers up only shows the initial face page. Nothing then happens and the screen goes blank. I have tried it connected to my computer, charged u
i have the same thing happening to me. Every time im turning the sat nav drom ireland to UK it makes same beep noise and stays at ireland can you help me please
May 30, 2009 | MyGuide 3100 GPS Receiver
Garmin sat nav not working
Do you have screen with cable plugged in a computer? is yes then your charger (power) is not connected to Garmin properly or lose.
If your answer is NO than check your charger may be it's not working.
Apr 30, 2009 | Garmin nuvi 255W GPS Receiver
Buttons and screen not responding on via michelin x-950t sat nav
stick a pin in the reset hole in the back.that should fix the problem.
Mar 01, 2009 | SNK ViaMichelin Handheld GPS Receiver
Navman F10 wont function shows sat nav connecting to computer on screen
Try holding down on/off button till screen clears,switch back on and it should be working normally,this worked on mine,it had picture of laptop ,navman usb cable and a red cross,hope this helps.Cheers.
Jun 10, 2008 | Navman F20 GPS Receiver
Tomtom GO GPS Receiver Logo
201 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
