Question about Vehicle Parts & Accessories
WINDOWS CLOSES BUT OPENS BY ITSELF AGAIN - Vehicle Parts & Accessories
    Problem Solver:
  • 9 Answers
The switch has a short or one of your wires is shorting, remove door panel inspect the wire's for burnt areas and depending on the vehicle replace the swich.
Posted on Oct 10, 2013
Dometic thermostat turns off and comes back on by itself Dometic thermostat model 3314080
Most thermostats operate this way.
Instead of dropping the voltage a thermostat opens the circuit when the set temperature is reached, after which it closes again to redo the cycle again. The principle can be based on heat, time or pressure.
The animation, if the GIF runs, shows the basic principle for a thermostat switch in a heater/geyser, but can be modified to operate via a pressure diaphragm as used in ovens and fridge compressor relays. Strip heats/opens then closes.
Dec 24, 2017 | Dometic Heating & Cooling
What does the Therm-O_Disc that's on the motor of my Kenmore Elite washer do
The limit switch is a temperature activated overload switch. When the motor over heats, the switch opens to turn off the motor. A few minutes later, after the motor cools off some, the switch closes to restart the motor. If the motor over heats again, the switch opens again to shut off the motor again. This process can repeat itself over and over again until eventually the motor will burn itself out.
Jul 23, 2015 | Kenmore Washing Machines
Refrigerator ice dispenser flap opens and closes itself
You need to replace the PCB located in the back of the refrigerator. Took me about 20 minutes after I got the part. Then you will have to program the code back into it. Costly but rather easy.
Feb 10, 2015 | Maytag MFI2568AES Stainless Steel Bottom...
Rear door will open partially and then shuts itself again
Sounds like a sensor is not working properly. Check to see if there are any obstructions in the way or excessive dirt around the latch or contacts
Jul 20, 2014 | 2007 GMC Yukon XL Denali
360 tray opens and closes by itself
broken faceplate or broken dvd tray. Call MS support.
Mar 20, 2010 | Microsoft Xbox 360 Console
Game console opens and closes when it wants to
This is more than likely a faulty logic board and possibly a samsung drive??
i recommend you either swap the logic board (dont forget to get your security key) or swap the entire dvd drive for a new one (still need security key).
www.xboxrepairkit.co.uk
Sep 17, 2009 | Microsoft Xbox 360 Console
Cd tray opening and closing all the time
Dear friend, my sony dvd drive tray opens and closes itself, it is mostly a problem related to hardware. in my case I removed the IDE Data cable connected to the dvd drive and reconnected it again. now my dvd drive works well, I think the problem was the IDE data cable, may be a loose contact.due to this loose cantact,a jung signal goes to the dvd drive, which opens and closes the tray frequently without our knowledge.
Jun 03, 2009 | Technics SL-PD687 5-Disc CD Changer
Cd drawer opens and closes by itself
the sensor that tells it when door closes under door theres a guide that flips a slide switch as it goes in is failing. bad hardware!
Nov 11, 2008 | Philips PCRW (PCRW404) CD-RW Burner
Tray opens / closes on its own and will not play
Your open/close button might be stuck, you can try and unplug it and spray it with silicone lubricant and push it over and over again for a couple of minutes and then turning it back on after about 30minutes so the lubricant dries down first.
If all else fails, have a local appliance technician take a look at it...
Dec 09, 2007 | Hitachi DV-P323U DVD Player
Vehicle Parts & Accessories Logo
19 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
