Hi
The problem appears to be with the scanner unit
Scanner home detection failure
- When the power switch is turned ON or a scan operation is completed, detecting the home position fails.
1 Turn OFF and ON the power switch.
2 Check the connector between M3-MFPB P101 for proper connection and correct as necessary.
3 Check M3 for correct drive coupling and correct as necessary.
4 Check the connector between CIS-MFPB P102 for proper connection and correct as necessary.
5 M3 operation check.
6 Change M3.
7 Change CIS. 8 Change MFPB.
You can find the page here, and it gives other error codes and their solutions as well.
Error Codes Konica Minolta bizhub 195 page 2
Hope this is helpful, if so would you please register that with Fixya
Cheers
