You need to use a rod to knock out the stuck pellet. A brass rod, available at your local hardware store can be used to good effect. Use a small hammer to tap it out.
The best way I found to fix this is to break the gun down. Once you've done that you can slide the barrel out and use a push rod to remove jammed pellets. To stop this issue, I've read to not use short skirted or pointed pellet.
I hear that the ammo has alot to do with that. .BB on a unrifled barrel gun are not as good as pellets. Lead pellets ride on the rifling in the barrel. And also your sites could be out of line. One man took the inner barrel out of the outer barrel and bent it over his knee slighty.His rifle was shooting high. On his daisy model # 880 Powerline.. But I would not go that far.A unrifled barrel is best for BB's.only.Hope I can help you out.Yours truly Joseph Alexander Bagli.
if you dont have a cleaning rod for it you can go to your local bass pro/cabelas/outdoors store and get a cleaning rod for a .17 caliber for fairly cheap. you should be able to push the pellet out or clean it if there is dirt or grime in it. and make sure you use the right caliber pellet! (:
This gun is a break barrel or break action gun. Hold the stock in your left hand and pull down on the barrel with your right. Once the barrel is down you feed your pellet right into the chamber. Pull back up to set the barrel ready to fire.
Get a wood dowel that will fit snugly but still loose in the barrel. Spray a little PB blaster in the barrel and let it sit on the pellet for about 30 minutes,then use the wood dowel with a small mallet to drive the pellet out.
