Question about Lenovo ThinkPad T61 Notebook
HI geekman i tried that already it seems my audio device is working fine and all my volumes controls are up
  • Chris Hingee
    Chris Hingee May 11, 2010
    If your audio is working fine, then what problem are you having?
  • 431 Answers
Hi I am Vortash see the solution I set for resnthaver this may also be your problem .... Regards Vortash
Posted on May 14, 2009
I have an HP Laptop with Windows 7 and I have correctly set up my Logitech LS21 speakers, but the volume control does not enhance the sound coming from my laptop. The speakers work fine, but the sound is...
There are 2 volume controls on the audio output in windows 7. one is the system volume the other is the device volume. make sure that they are both at full and then control the sound volume on your speakers.
Jan 20, 2013 | Logitech LS-21 2.1 Speakers
Hi, I'm having a problem with my sound. Windows says there's not an audio device but i have run the motherboard disc and installed Nvidia high definition audio and still it doesn't seem to
Go to Start - All Programs - Accessories - Entertainment - Volume Control and see if your Maste Volume is at minimum or mute. I had this problem but maybe you have the same problem.
Apr 28, 2012 | Asrock Computers & Internet
I have tried EVERYTHING but my audio will not work! i have downloaded realtek drivers, restarted my computer and still no solution! i even deleted recent downloads (none are viable to the computer) idk...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
if you dont have a motherboard disc you will have to download the drivers
if you nee more help with this post a reply with what you have tried
hope this helps you
Sep 01, 2011 | HP Computers & Internet
I have a set of Bose computer speakers and they seem to have just stopped working, everything on my computer says they are working fine and when I plug them into my laptop they work, so what could be the...
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
hope this helps
Jun 24, 2011 | HP Audio Players & Recorders
P5GD2 Deluxe motherboard in my PC. Recently I installed windows 7 (32bit) and everything seems to work fine except that there is warning that no audio device is connected
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 24, 2011 | ASUS P5GD2 Deluxe Motherboard
Sony vaio audio driver problem
if not anything open the system and check the connections sounds like you have hit on everything else besides that
Jul 21, 2009 | Sony VAIO VGN-FS840/W Notebook
Low sound at high volume. has worked fine until recently
Hi..
You need to replace the Volume control, the volume control is faulty already
Good luck !!!
Regards
PCmania
Jul 04, 2009 | Sony STR-DG1100 Receiver
My speakers won't work
Hi! It seems that your problem is in your computer system setting. You have to install the audio device DRIVER and install it. After that, problem solve. Good luck, THANKS
May 06, 2009 | Audio Players & Recorders
Laptop speakers not working
Hi you can try this:
From Start, go into Control Panel, then select Sounds, Speech & Audio devices, then Sounds and Audio Devices again.
On Volume tab, click on Advanced. Now choose Laptop stereo speakers. This may sort out the problem. Try the other options if they still don't work.
Jan 25, 2009 | Dell Inspiron 9200 Notebook
Lenovo ThinkPad T61 Notebook Logo
66 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
