Question about Watches
Where can I get watch strap for Ben Sherman R220 model,please?
escapement
  • 2334 Answers
SOURCE: i cant find my manual for my ben sherman r424
You will not find BEN SHERMAN watch manuals online. Visit www.bensherman.com and click on CONTACT US or SUPPORT tab. There you'll be given contact phone number.
Posted on Mar 30, 2010
SOURCE: nike triax watch strap needed wg48 4000 grey strap
I'm having the same problem with the same model. Were you able to find a replacement strap? Thank you.
Posted on Jul 27, 2010
SOURCE: CANNOT REMOVE LINK FROM BEN
If it's similar to my Ben Sherman watch it will have what looks like a screw on one side. It is in fact not a screw but the 2 sides of the split pin - which you simply push out using a map pin, small strong screwdriver, or similar. If you look inside the links you should find arrows to indicate which direction to push the pins out - usually pushing the end opposite the "screw" end. Note: It takes a fair strength to get the split pins moving.
Posted on Feb 28, 2011
  • 3 Answers
SOURCE: set time on Ben Sherman
Press and hold the top right button till it beeps. Then press the bottom left button to scroll throught the hh:mm:ss, use the top buttons to increase or decrease the number. Finish by pressing the bottom left button until you cycle through back to the time display.
Posted on Mar 28, 2011
  • 3 Answers
SOURCE: wanna set time on my
I need a replacement brown leather strap for Ben Sherman watch R472
Hi call watchsupermarket .co.uk 0845 600 1511 for availability ...cheers
Jul 15, 2017 | Ben Sherman Watches
Set time on Ben Sherman R424
Mar 27, 2011 | Watches
CANNOT REMOVE LINK FROM BEN SHERMAN WATCH
Jan 15, 2011 | Watches
How do you remove a watch back
Locate a very small tab (or recessed area) on the edge of the back cover. This is the access point for removal. You can find this sometimes by running your fingernail around the back rim, as this tab or indentation can be hard to see. Pull out the stem, which releases the back on some watches.
Get a small flathead screwdriver it needs to be a thin inflexible tip. Use a kitchen knife as a last resort. Wrap the hand you are holding the watch with in a towel or protect your hand in some manner so you don't injure yourself if the screwdriver/knife slips.
Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). Do not attempt to insert the point of the knife. Use the length of the blade.
Get under the tab or recessed area and gently but firmly turn the blade upward, popping the cover off.
When you replace the cover, make sure you line up the stem slot on the cover with the stem of the watch.
Or take to a local jewelry store/watchmaker!!
Aug 16, 2010 | Ben Sherman Strap Watch
Wanna set time on my ben sherman R424
I cant find my manual for my ben sherman r424 watch. it only has four buttons. why cant i figure this out?
Mar 30, 2010 | Watches
I bought Ben Sherman R424 watch from Amazon Marketplace. It has arrived with no manual, and I cannot figure it out. Any help please??
Solution 1 seems a little off for mine it's the bottom right button you hold in which brings up the date and then the country its set to starts flashing. Then the bottom left hand button to move to the time. Use the top right button to scroll and left bottom to move to the next input. When your done push the bottom right once.
Hope this helps.
Feb 25, 2010 | Ben Sherman Strap Watch
Nike triax watch strap needed wg48 4000 grey strap
Feb 13, 2010 | Nike Oregon Series WA0019-001 Wrist Watch
Need replacement strap for F33FOBGKVK
Try these guys; http://www.wristwatch.com/contact.aspx They sell most of the new Field and stream models and should hopefully be able to help Hope this helps, please post again if not :)
Mar 12, 2007 | Field and Stream F61GD Wrist Watch
Watches Logo
180 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
