Question about Dell Vostro 1015 Laptop
Bios file bin file - Dell Vostro 1015 Laptop
We need bios bin file ,i have download 5mb bin fle, but how can i partition 1mb and 4mb?
A bios system file is quite small and is downloaded only from your laptop manufacturers web site. Download the file and when you click on it, it will auto install but make sure you have your anti virus programme switched off!
Nov 04, 2015 | Computers & Internet
Where can i get bios "bin" file for my laptop,dell inspiron 15r 5520
Normally, .bin files of BIOS are not published for public on websites. Contact a chiplevel technician. BIOS.BIN files are the asset of a technician. So you may need to pay.
Feb 16, 2013 | Computers & Internet
I recently upgraded my BIOS and that ruined my laptop. Now I need the original .bin BIOS files to flash the laptop and get it to work. I can not find them anywhere online. Would someone be so kind as to...
Try the manufacturer's website and click on Support.
If the BIOS .BIN file is not available, many companies will send you the file for about $25.
Not shutdown
i think you do not now how to flash the bios.
first you need the program "wbflash.exe" also you need the xxx.bin file (thad are the bios data) in the program you have to select the xxx.bin file for update the bios if you have done the program screen wil checq the bios and ask for saving old bios if you say yes than thad wil be done after thad you can update the bios with the new one (xxx.bin)if this are done you computer wil restart and the yob are fixed.
NOTE LOOK OUT !!!! if you do not have the right or rong bin file and you update your bios with it the computer wil restat and wil not turn on than you have a bigger problem and it are not reversebile .
only update the bios if you have problems with the computer other wise leave it.
Dec 13, 2009 | Sony VAIO VGN-SZ740N5 PC Notebook
Bad Bios upgrade on Dell M1330
If you cannot start the laptop, you cannot flash the BIOS. You can ship the unit to me, and I'll recover the BIOS. You can email me at buffalonymann@yahoo.com
Nov 02, 2009 | Dell XPS M1330 Laptop
I want bios driver (bin file) for my intel destop board d915gav/d915pgn
The BIOS bin file is a BIOS upgrade file. It is used to flash the BIOS to upgrade the BIOS version.
This file is has to be downloaded from the motherboard manufacturer's WEB site.
Jul 24, 2009 | Intel D915GAV Motherboard
Gigabyte Motherboard wont flash bios
your bios has been corrupted.
The AWARD BIOS has a similar procedure to AMI. To recover an AWARD BIOS you will need to create a bootable floppy diskette and add the desired BIOS file (we recommend using the most recent). Award BIOS's generally are in .BIN format, where as AMI was .ROM format. You will also add an AWARD flash utility (usually awdflash.exe) and an AUTOEXEC.BAT file.
The AWARD BIOS does not automatically restore the BIOS information to the 'system block' like the AMI BIOS does. You will need to add the commands necessary to flash the BIOS in the AUTOEXEC.BAT file. The system will run the AUTOEXEC.BAT file, which contains the flash instructions.
Note: 12345678.BIN represents the name of your BIOS.
Step by Step:
1. Create a bootable floppy diskette or bootable dos cd /usb drive
2. Copy the BIOS file and flash utility to the disk
3. Create an text file with any standard text editor and add the following lines
@ECHO OFF
awdflash 12345678.BIN /py/sn/f/cc/r
Exchange the awdflash with the name of whatever flash utility you are using, and replace the 12345678.BIN with the name of the BIOS file you are using. The parameters are explained here:
py = program yes
sn = save no
f = flash
cc = clear cmos
r = reboot
Remove disk and restart computer
If you found this useful , please rate below
Kind Regards
1234s282
Jul 02, 2009 | Intel Gigabyte GA-8S648FX-RZ Socket 478...
How can i update bios
hiya
first goto the website of your board maker then download the updated bios, make a bootable floppy disk copy then exe file and the bios file it normally a .bin or .rom file when booted from the floppy run the flash utility with the exact name of the bios file so for instance it wud be
amiflash a123456.bin
hopw this helps
Rik
Feb 25, 2009 | Gigabyte Computers & Internet
BIOS BIN Files
I think Ur pc is ibm ok then go to the website and download for ur product bios and install .
ur in operating system download as exe file (or) download as iso image and then bootable for the bios in ibm.
http://www.ibm.com/support/in/en/
Check the site.
Feb 02, 2009 | IBM NetVista PC Desktop
Pcsx2 software
This is because you're using either A.) The wrong bios file for ps2 emulation ex.SPCH1000.bin (this is a playstation 1 bios) or B.) The bios you (obtained) is corrupted.
Here is a few pieces of info you should note about the bios's in question.
SPCH 30004R V6 (PAL EUR) Bios.bin
Filesize: 4,096kb
SCPH 100000.bin (***)
Filesize: 4,096kb
SCPH 39001.bin (standard US)
Filesize: 4,096kb
As you can see they adhere to a certain file size. All of the above bios's can be located by using google or by using bittorrent sites like this one .::HERE::.
Final Note: You're really at the mercy of the person who made the bios file as to whether or not he did it correctly. As you can see by the info I posted above and untampered bios will be 4,096kb in size. This does not mean that a file larger or smaller will not work. I'm just stating what the norm is. Also note that a PS1 bios file will not work in the PS2 emulator, and for that reason it will not play playstation 1 games at all. (or so the creator of PCSX2 says)
Jul 10, 2008 | Sony PlayStation 2 (PS2) Console
Dell Vostro 1015 Laptop Logo
209 people viewed this question
Alun Cox
