Question about Refrigerators
Daewoo FRA-U21PC water keeps pouring out back
Water not filling the ice tray
locate the water fill valve,wiggle the connections to it as to clean these connections,then manually fill the ice maker with approximately 4 oz. of water,sometimes this will kick start the ice maker and it may take over from there
Jan 31, 2013 | Daewoo FRSU20IC (21.8 cu. ft.) Side by...
Water builup in bottom of fridge
If the problem is in the fridge 1: it could be moisture being drawn from unwrapped vegetables. 2: if you have a "wet wall" fridge check no food wrapping is touching the wet wall.
Mar 21, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
How to take out air from the engine for smart car
Open the temp gauge sensor (located in the back , top of the engine) and please make sure to open the lock and not to lose it as you will need it to tighten the sensor in its place. Open the water bottle and pour water in it and let the water come out from the back (the sensor) , you will see air bubbles coming out with the water , but keep on pouring water till you see no bubbles what so ever. put sensor back in its place while water bottle is full and while water is still coming out from the back to make sure that no air escapes inside with the water.You might need another person to help you pouring water while you are in the back.
Sep 30, 2009 | 2008 Smart fortwo
Water pouring out from under my washer as it fills...
hello mam please check the rubber sleeve of the drum if there is any crack it should be replaced and check the drum if there is any holes in it, so please call the engineer and make him to check these.
Sep 29, 2009 | Washing Machines
My freezer has water that leaks into the bottom and freezes but water also leaks out onto the floor
Inside the freezer at the bottom in the back there's a drain hole that must be clogged and the water from every defrost cycle freezes up and make it worse , so first pour hot water into the drain to melt the ice and keep pouring until it goes through .Keep the drain clean doing this every 3 or 4 months.
Aug 10, 2009 | GE Refrigerators
Leaking side by side
You have to unclogh the drain hole inside the freezer at the bottom of the back wall by pouring hot water into it until ice melts and keep pouring to make sure water goes through .Repeat this every 3 o 4 months to keep it clear.
Jul 27, 2009 | Frigidaire FRS26H5AS Side by Side...
Water keeps pouring into ice maker and doesn't shut off.
does water come into cabinet if the icemaker is unplugged? if so, the water valve is leaking thru and needs to be replaced
May 06, 2009 | Refrigerators
I have a 2000 Daewoo Lanos the trans don't have a dipstick, it had a leak and i fixed it but i need to know when it is full
If you listen inside the funnel while you are pouring the trans. fluid in you will hear the trans. pump sucking in air. Keep pouring slowly at 1 pint intervals until the pumps gets quiet(no air getting drawn into the pump). If the transmission doesn't slip, then your ok on fluid. Good luck
Apr 25, 2009 | Daewoo Lanos Cars & Trucks
Daewoo refrigerator water filter red light still on after replacing the filter
Press and hold "ICE MAKER LOCK" button, and while holding it shortly press "LOCK" button, and the light will change to green LED.
Ivan
Oct 08, 2007 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
